Old 10-08-2012, 05:22 PM   #1
iLLmattic
Member#: 321371
2004 wrx
black
Default 2004 Subaru Wrx "whining" noise (video)
Hello and thanks for looking.
My car is a 2004 subaru wrx. The car is stock other than Bc Racing coilovers and Cobb Cat-back exhaust. The problem is I'm hearing a whining noise coming from what I think is the water pump. This could be a normal noise, I'm not sure. Any input is appreciated. If you need more info about the car to make a guess on the noise, please ask.
thanks.
<iframe width="560" height="315" src="http://www.youtube.com/embed/RkqS_qCM9To" frameborder="0" allowfullscreen></iframe>
iLLmattic is offline   Reply With Quote
Old 10-09-2012, 02:41 AM   #2
Saskatchatoon
Member#: 297802
2005 WRX
Are you sure it isn't the alternator? You could take off the alternator/ p/s belt off and idle it for a bit (don't leave it running too long and drain your battery), and if the noise is gone then my guess would be the alternator. Sounds like it has bad diodes. And if the noise doesn't change while turning the wheel then it won't be the p/s pump.
Saskatchatoon is offline   Reply With Quote
Old 10-09-2012, 07:46 AM   #3
pebelz
Member#: 268632
2015 XV
Could be the idler pulley, especially if you still have the stock plastic one.
pebelz is offline   Reply With Quote
Old 10-09-2012, 09:13 AM   #4
Saskatchatoon
Member#: 297802
2005 WRX
Haha, ya forgot about that, give that a spin with the belt off and see if it makes any noise, or feels rough. but to me that doesn't sound like an idler.
Old 10-09-2012, 03:18 PM   #5
iLLmattic
Member#: 321371
2004 wrx
black
the noise isn't coming right from the alternator but i will definitely try it because sound does travel, ill give that a shot today. I'm not sure if it is the stock idler pulley, the previous owner didn't say anything about it and i cant find a record of it being replaced with the paper work he gave me. Ill give it a shot and thanks for the help guys.
Old 10-09-2012, 04:43 PM   #6
cmiovino
Member#: 134005
2004 WRX Premium
Try blowing some of the red-ish dust stuff off around the A/C pulley. I've heard that works when researching my 2004 WRX whining noise in the same area.
I changed the timing belt, water pump, and idlers.... and no more noise. It was due anyways.
Old 02-15-2014, 10:53 PM   #7
jtharvey
Member#: 294795
Did you ever figure out what the noise was? I've for the same noise that started all of a sudden last week and I'm trying to figure it out.
jtharvey is offline   Reply With Quote
Old 02-26-2014, 03:56 PM   #8
GscoobM
Member#: 382746
Explain more on where the reddish dust came from? I had plenty on my front left wheel and non of the others. It wiped off black
GscoobM is offline   Reply With Quote
