#101 |
Member#: 99289
#102 |
Member#: 50304
NESIC
Vehicle:97 TJ, 04 Matrix XR70R, 03 Gas Gas 250 |
Welding? Who knows, at least they employ a bunch of Americans.
#103 |
Member#: 101117
NESIC
Vehicle:2009 WRX 5 door Blue |
Don't be - a LOT of products are being "onshored" or "reshored" because.
1. Shipping costs are going through the roof. 2. Lead times for Chinese products have been too long and unreliable. 3. Chinese quality is indifferent. If you can automate the processes to hold down labor content, US manufacturers can compete by being a lot closer to the market. |
#104 | |
Member#: 12408
VIC
Vehicle:2006 Legacy GT Silver |
You should see the crap they do with offroad trailers (skip to the ~3:00 mark): |
#105 |
Member#: 53066
South East
Vehicle:work bum look a lot alike, daddy. |
I bought the same HF trailer and haul my ATV on it. So far I've taken it out to camp twice - 77 miles each way, about 65 of that on the highway. I find it rides great at 75mph. I think I need to have the tires balanced, the fenders bounce like crazy. My ATV weighs about 500lbs wet.
As a bonus, the trailer tilts if you leave the pins for where the tongue folds out. Drive the ATV right on, once you get the technique down. And I have 3M stair tread asphalt traction stickers in the mail because the ATV tires slide on the untreated plywood. I didn't even put the lights on it, as in GA, if the tow vehicle's lights are visible, you don't need trailer lights, and I don't have a trailer harness on the Pathfinder anyway. |
#106 | |||
Member#: 50304
NESIC
Carry On got back to me via email: Quote:
I really like my little carry on. I want bigger tires for it, but that's only because I now tow it behind a lifted Jeep. |
#107 |
Member#: 23676
NESIC
Vehicle:. |
Yeah my fenders bounce like crazy too. I think it may be my wheels/tires not being completely true. Im gonna have them balanced and see if it helps. If they are not straight, Im gonna call HF for replacements. They are really good about that sort of thing.
#108 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Also I would argue the higher capacity point. This trailer is 5X8 and it has sides. (I built sides) Larger tires would be nice, and like next summer I plan on going to 5 lug hubs and doing 12" car tires on cast alloy wheels. Although I may have to scrap that idea if it is way heavier, because it would make folding it and standing it up less realistic. I am also going to weld the joints, and I am going to get some thin sheet steel and make the center beams a box instead of a C beam. That should only add about 5lbs. It would only be 2 3"X48" strips of like 1/16th. |
#109 | |
Member#: 23676
NESIC
Vehicle:. |
#110 | |
Member#: 93193
South East
Vehicle:'90 Ishtbox Corolla maroon, as in, I hope not |
I used to live in Camarillo, CA, where HF's HQ is, and back in the day they used to have an annual "garage sale" where they would sell all of their scratch and dent stuff and other returns for cheap. My dad and I got a number of killer deals there over the years. At some point they realized that they could make more money selling that stuff in lots, and now all of that stuff ends up on eBay after it's been bought by somebody that's bid on an entire lot of returned items. </hijack> |
#111 | |
Member#: 53066
South East
), I'll be buying ramps. |
#112 |
Member#: 50304
NESIC
Just notch a set of 2x6's at the end.
Edit- Forgot all ATV's are small cars now... for that you may want to get these- http://www.ebay.com/itm/Aluminum-Loa...-/110877101863 |
#113 |
Member#: 7719
Dave,
At least paint or sticker up the plywood deck. |
#114 |
Member#: 53066
South East
My ATV is small. 300cc, 2WD Kawasaki Brute Force, about 500lbs wet weight. My issue with buying/making ramps is that then I have to attach them to the trailer somehow for transport.
#115 |
Member#: 50304
NESIC
Drill hole through them and deck, use something found here-
http://tsc.tractorsupply.com/search?...archButton.y=0 |
#116 |
Member#: 93193
South East
Attach boards across them and use the stake pockets on the trailer to stow them.
#117 |
Member#: 159636
MAIC
Vehicle:2007 WRX -18G EWG WRB |
I had a lot of trees fall because of Sandy, and needed something better than my crappy lawn mower trailer. Since I have the HF 4x8, I figured I would make it work. Picked up an ATV hitch adapter from harbor freight and some hitch parts. I had found out from my brother that installing as-is would bend the tractor hitch. I welded up some supports to stop it from turning, and support the extra weight. It worked great and I was able to clean up the whole yard in one trip. The best part is, when i buy soil admendments or other things, i can un hook my car and hook up the tractor.
#118 |
Member#: 53066
South East
Yeah, I definitely plan on towing mine with my ATV to make food plots in the spring
#119 |
Member#: 159682
NESIC
Vehicle:1995 WRX |
I finished mine today. It's the 40x48 with 8" wheels. Got it on sale plus 25% off coupon.
He's the money breakdown. Trailer $145 Plywood $20 Bolts $7 $172 total I took it for a test spin today, pulls nice can't even tell it's back there. Then I stained the deck wood to protect it. I'll probably put removable 2x12 sides on it eventually. ![]() ![]() ![]() |
#120 |
Member#: 47036
NESIC
Vehicle:07 FJ 02 RSX |
HF has this for $270 for the next few weeks. Thinking about buying one to tow my motorcycle behind my RV.
