Old 10-09-2012, 09:38 AM   #26
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Originally Posted by growling_boxer
like I said, going with a narrower tire will buy you some clearance, but just going from an 18 to a 17 on it's own has nothing to do with that, unless you are getting a narrower wheel. you can can also get more clearance going to a shorter overall diameter tire. but staying with an equal tire and going from an 18 to a 17 (e.g. 245/40R18 to 245/45R17), will not buy you clearance.
Yes if u r comparing same width (245/45/17 vs 245/40/18) but if u compare 225/45/17 vs 245/40/18 the 225/45/17 will have a smaller diameter due to the shorter width u need to remember the wider the tire the taller the tire will be with the same series but varies from brand of tire.
My dedicated winter tires r blizzak lm60 225/45/17 vs my 245/40/18. Since I have the performance winter tires and even though they're a 45 series r a smaller diameter by about 1" giving more wheel well clearance.
trev762 is offline   Reply With Quote
Old 10-09-2012, 09:53 AM   #27
growling_boxer
Member#: 165744
2000 LGT
2007 STi
so, you're getting more clearance because you are going to a shorter overall tire diameter (as well as narrower). it has nothing to do with being on a 17 vs. 18, which is what you claimed, and could be very confusing to someone who doesn't understand how this works. I am trying to make it as clear as possible for the OP here. he could just as easily have decided that 225/50R17 was the right size because it is closer in overall diameter than a 225/45R17, especially if he doesn't want to lose 0.38" in ride height. and that 0.38" is also the amount of extra clearance you have above, although the narrower tire helps you get in there at an angle.
let's be clear here for the people that don't understand how it all works.
growling_boxer is offline   Reply With Quote
Old 10-09-2012, 10:00 AM   #28
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Exactly what I stated from my very first post that over all thinner and smaller diameter so what's not so clear/
Edit: as far as ride height goes if u r at stock height is not going create any issues as appose to having very little wheel well clearance for buildup of snow and ice.
Old 10-09-2012, 10:08 AM   #29
growling_boxer
Member#: 165744
2000 LGT
2007 STi
I didn't go back to read your original, where you did make a specific tire size suggestion:
Definitely go with a 17" with a 225/45/17 winter tire but make sure u go with a performance winter tire H rated or better.
But I did remember you writing:
Smaller wheel more fender well clearance to allow for snow and ice buildup plus easier to knock off access snow and ice.
...which is what I had discounted in my original reply to you. so, whatever. it should hopefully be painfully clear at this point.
Old 10-09-2012, 10:20 AM   #30
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Lol that is why before u post anything should read all the posts bin there done that. Yes I think its painfully clear at this point.
Old 10-09-2012, 10:42 AM   #31
growling_boxer
Member#: 165744
2000 LGT
2007 STi
dude. reading all of your posts, you still told him that an 18x8 reduces clearance, and that a smaller wheel will give more clearance. and you never explained that the tire size you initially suggested was why he would get more clearance.
Old 10-09-2012, 11:23 AM   #32
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Huh:/
I said an 18x8 245/40/18 with snow tires will reduce clearance and a 17x7 with a 225/45/17 will give more clearance r u confused/
Old 10-09-2012, 11:30 AM   #33
growling_boxer
Member#: 165744
2000 LGT
2007 STi
Huh:/
I said an 18x8 245/40/18 with snow tires will reduce clearance and a 17x7 with a 225/45/18 will give more clearance r u confused/
No, I'm not. But I am done. In case you forgot what you wrote...
Winter tires on 188 u r defeating the purpose of good grip in slippery conditions not to mention risking damage due to fender well clearance issues from snow and ice buildup
Originally Posted by VicsSTi1288 View Post
What are the advantages of doing a winter tire setup (smaller wheels) vs just swapping out the tires ?
Old 10-09-2012, 11:37 AM   #34
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Lol and u forgot to add my first post hence 17x7 with 225/45/17 vs 18x8 with 245/40/18. Meaning smaller all around!!
As anybody can see in your first post recommending a 17x8 wheel lol.
Old 10-09-2012, 04:32 PM   #35
VicsSTi1288
Member#: 323203
2007 Cobalt SS/SC
Suburst Orange
Thanks for all the info guys!!! I'm sure you helped a lot of others too.
I'm very excited to get my car .... It's been a long wait .. Should be here mid-November ... Hopefully !!!
2013 WRB WRX STi 4door sedan w/Navigation
VicsSTi1288 is offline   Reply With Quote
