Old 10-06-2012, 04:38 PM   #1
Dr. Ninja
Member#: 54782
2004 WRX
blue
Default Oily residue - what is leaking and should I fix it?
There are two spots under my engine that have an oily residue and have attracted a bunch of dirt. One is where one of the IC hoses connects to the turbo inlet, and the other is on top of the PS pump (I think). I'm not sure if the pump is leaking or what, but the top of the bump has a lot of oily stuff on it.
Pics, although it's hard to see with the shadows. You get the idea:
Anyone had this happen? Should I be concerned or is this normal?
Dr. Ninja is offline   Reply With Quote
Old 10-06-2012, 04:52 PM   #2
ya got a lil leak there at the ps line attach point
Old 10-07-2012, 12:15 PM   #3
Dr. Ninja
Member#: 54782
2004 WRX
blue
Yeah that's what it looks like. What about the vac line from the IC? Is it normal for some of the gasses and accompanying oil to escape?
Old 10-07-2012, 01:13 PM   #4
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
No, usually you will see gunk built up like that around the pcv but not on that hose. It looks like the ps line is causing what you are seeing.
2gnt2wrx is offline   Reply With Quote
Old 10-07-2012, 06:29 PM   #5
Dr. Ninja
Member#: 54782
2004 WRX
blue
Weak. I've got so many PS leaks. It leaks from some of the lines under the car as well, but it's so slow I only have to add like .2qt every 6 months.
Old 10-09-2012, 11:41 AM   #6
you DO know that the system takes dexron atf and NOT 'power steering fluid' and adding ps fluid may be what is making it leak
Old 10-09-2012, 11:47 AM   #7
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
You have an 04. It's your PS pump. The internal o rings are old and cracked. Time to replace the pump or rebuild it. Plenty of threads on this. Check the one on iwsti.com
WRXSD is offline   Reply With Quote
Old 10-09-2012, 12:12 PM   #8
Dr. Ninja
Member#: 54782
2004 WRX
blue
Yeah I only use Dexron ATF. It started leaking from the rack when I hit a curb like 6 years ago. I've added about a quart of ATF total to the reservoir in that time span replenishing it.
Old 10-19-2012, 10:25 AM   #9
Dr. Ninja
Member#: 54782
2004 WRX
blue
So I cleaned the thing up and found where the PS pump is leaking. I don't have any pictures, but it's leaking from where the two plates meet (the separation that runs the circumference of the pump). After driving I can see some spots appearing at the top.
I've read the thread about opening the pump up and replacing o-rings. Would new o-rings fix this based on where it's leaking or should I just replace the damn thing with a reman?
Also, the hose running from the IC to the turbo inlet is on there super loose so I guess it was leaking. Threw a worm clamp on it.
PS I realize this thread should probably be in brakes section given its content now.
