Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 10-09-2012, 01:21 PM   #1
FundamentalyConfused
Member#: 313722
1990 Legacy L
Red
Default Looking for a nearby Select Monitor
Does anyone around the Flint, MI area have a Subaru select monitor with cruise control cartridges for a 1990 Legacy?
My cruise unit has been acting wonky. There's days it works fine and then there's days it kills the setting as soon as I set it. I've check all the things out of the service manual that I can without that blasted select monitor.
I'm willing to travel if necessary.
FundamentalyConfused is offline   Reply With Quote
Old 10-11-2012, 05:54 PM   #2
Member#: 313722
1990 Legacy L
Red
What about any shops somewhat nearby?
Old 10-23-2012, 09:18 PM   #3
Member#: 313722
1990 Legacy L
Red
Ok how about anyone in the mitten of MI?
Old 10-24-2012, 03:41 PM   #4
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
You can build an SSM reader with a laptop and a special USB cable. Total cost: $20
tooocool49723 is offline   Reply With Quote
Old 10-24-2012, 05:07 PM   #5
Scooby921
Merci Buckets
Member#: 88606
2015 GMC Sierra
'13 JCW
^ Care to elaborate? Stating it's easy and costs less than $20 is great, but it would be nice if you'd share the rest of the information and perhaps solve this person's problem
Scooby921 is offline   Reply With Quote
Old 10-24-2012, 05:17 PM   #6
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
I'm still working it all out on my own, and I'm sorry if this doesn't quite belong in this thread.
However, here's what I've figured out so far.
I've got an EG33 swapped impreza, and it's now got a USB cable in the glovebox that will give me data, but I don't have all the settings right in the hex to be able to interpolate that data.
You can do some reading here: http://www.alcyone.org.uk/ssm/ports.html
Most of my info is going to be for the SVX, as that's what I've been working with, but would apply to most subarus with an SSM port as well.
Basically SSM uses a TTL signal, which you can convert to a USB signal, and then use software like VWRX or EvoScan or Rom Raider to read and interpret. (http://www.alcyone.org.uk/ssm/software.html)
Furthermore, the VWRX software does have support for 92 subaru NA, which I can only assume to be the legacy (Impreza didn't come out until 93).
http://www.vwrx.com/index.php?pg=selectmonitor
So, it may take some playing around and learning hex, but it's doable.
Or you could make friends with the dealership, because they'll probably have one that hasn't been used in years sitting around the shop that would plug right in.
(also, damn I haven't been on in a while, Mods with member numbers higher than myself?! Makes me feel old.)
Old 10-24-2012, 08:45 PM   #7
Member#: 313722
1990 Legacy L
Red
Unfortunately that method doesn't pull cruise control info unless someone's cracked the pulse signal issue.
