#426 |
Member#: 330970
Got the front of the fender welded solid. Also threw a coat of filler on it so I don't have to worry about surface rust.
#427 |
Member#: 330970
Working on some ideas with how I want to finish out the shape of the fender. What do you think of this? It is just one of the ideas of how I am thinking of doing it.
#428 |
Member#: 164
Vehicle:1997 Legacy GT-T |
#429 |
Member#: 330970
Nope, I just sanded a minimum amount of distance to limit surface area I would have to worry about priming before I am done. But is was all bare metal when welding.
#430 | |
Member#: 331947
Vehicle:1998 Legacy Outback Red |
#431 |
Member#: 160325
Vehicle:98 Legacy DSP |
#432 |
Member#: 331188
Installed Perrin EL header. Invidia devirced dp
#433 |
Member#: 115154
Vehicle:2003 Legacy L Turbo silver |
claybar and waxed the car yesterday...then it rained today.
#434 |
Member#: 330970
Been a pretty busy weekend and fighting with the scattered storms. I removed the rear exterior door handle and just had time to weld in the plate when it started to rain so it looks like crap. I did not have a chance to grind down the welds; I barely had time to hit it with primer.
![]() ![]() I also spent some time working on different ideas for how to bring it back into the door. Here is the first and I really did not like it. ![]() ![]() ![]() Here is the second. I liked it a lot more then the first but just did not feel like it worked with the rears looks enough. ![]() ![]() Here is the last one I got done today and I am leaning in its direction. Very agressive like a porsches rear fenders. Not 100% yet. I made the metal template for this design and if the rain had not come it would be on it right now ![]() ![]() ![]() |
#435 |
Member#: 115154
I like 1 and 3 myself...
#436 |
Member#: 245268
TXIC
Vehicle:1993 Impreza L Wagon Blue |
I pulled out the ej22t yo get rest for a fresh rebuild.
#437 |
Member#: 332086
installed my aem uego wideband now i feel safe driving
#438 |
Member#: 313722
Vehicle:1990 Legacy L Red |
I took out the HVAC controls to replace them.
#439 | |
Member#: 331947
#440 |
Member#: 313722
I cursed at my cruise control until it started working!!
Bloody thing, I hate my manic depressed cruise unit!! |
#441 |
Member#: 57366
Vehicle:1999 Legacy-Sleeper Burgandy |
... discovered I have a bad fuel injector on cylinder three and the annoyances of getting my buddy to get his dealership pricing on the replacement =) ...
#442 | |
Member#: 57366
#443 |
Member#: 160325
#444 | |
Member#: 160325
For the hazard and fog switch they use little twist lock bulbs. I put a LED in my hazard switch. I got it from superbrightleds.com. Its a NEO-3. |
#445 |
Member#: 305000
Vehicle:2005 Legacy GT 5MT Bright Silver Metallic |
today i worked on the legacy GT a bit and had some hood-up time.
my 2005 5MT wagon is at 98k miles and needs a major svc that ive pushed to a later date. so today the power steering was making noise and had weird feel through the wheel. topped up the PS fluid reservoir. car is burning oil like crazy. about 1qt per 1000 miles at this point. admittedly, i drive hard. after getting synthetic this summer about 4th of july, car was nearly bone dry when checked two wks ago. engine was running hot but i did not see it bc my garmin blocks temp gauge. [oops] radiator also needed fluids badly. my key point: service your subie. im always amazed at how much better it drives after a service. i am cashpoor ATM. at the moment lastly, and what i had pics of: New DIY honeycomb grille, painted and nearly installed. debating what badge to use. thoughts about this old one i recovered VS the traditional blue stars...? ![]() subaru legacy gt - DIY honeycomb grille by tommyburkart, on Flickr or ![]() IMG_0445 by tommyburkart, on Flickr Last edited by burkart; 10-11-2012 at 02:35 PM. |
#446 |
Member#: 330970
Had a little time today before the rain. So I cut and bent the piece I wanted for the door. Got it welded in place just before it started to sprinkle so I quickly did as much grinding as possible and primed it. So excuse the images, it is not finished at all. Did not have time to make to top piece or the bottom piece. Also it is not trimmed for the door and not cut level across the bottom.
#447 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
Sunday - Won SM at the local auto-x and set the 2nd fastest raw time. Coulda/woulda/shoulda caught the faster time, but the 2nd heat (which I was in) only got a single dry run in before it started raining.
Tuesday - Rolled 220,000 miles. As 98legwag said, it's almost certainly the bulbs. It is very common for them to go out, and buying a 16-year-old junkyard HVAC probably was not a step in the right direction. |
#448 |
Member#: 331947
thanks to legwag98 finally got my hvac lights working. Feel like a kid on christmas
#449 |
Member#: 330970
Got home from work this afternoon and had a little time to make and weld in the piece for the top of the door. Had to run back to work and by the time I got home I only have time to grind the welds and put a coat of primer on it.
#450 |
Member#: 330970
Got a little time today to work on the car once the sun came out. Cut out the front fender and then tacked in the rear and front piece. I will close up the top over this week.
| Thread Tools | |
| Display Modes | |
| So what mods have you done to your baja? | 2003Baja | Baja Forum | 22 | 07-16-2004 03:31 PM |
| What mods have you done to your WRX? | Diesel7 | Canada Region Forum | 3 | 11-02-2002 12:16 AM |
| What have you done to your RS lately? | CosmoTheCat | North West Impreza Club Forum -- NWIC | 8 | 03-27-2001 10:55 PM |
| What have you done to your impreza? | Hades69 | General Forum Archive | 2 | 02-17-2001 07:39 PM |
