Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 10-08-2012, 12:14 PM   #1
zashoe
Member#: 329523
2002 Impreza WRX
Default Boost Issue
2002 WRX. just replaced turbo <1k miles ago. I THINK I'm having compressor surge. I boost fine at ~18psi until 4k rpm. then boost drops to 9psi and rebuilds to 15-17psi by redline. I'm not sure whether it's compressor surge, waste gate issue, boost leak somewhere, etc. I thought it was the stock bov. tries turboxs hybrid to no avail. the car has roughly 134k miles. I data logged if it will help anyone to view the results.
zashoe is offline   Reply With Quote
Old 10-08-2012, 01:16 PM   #2
wrxlaunch
Member#: 181298
02 , Vf43 Inside..
12 seconds at a time
Kinda turbo did u replace with and what was on there before? Have u checked for leaks?
Old 10-08-2012, 05:47 PM   #3
zashoe
Member#: 329523
2002 Impreza WRX
just stuck with a td04. I can't find and obvious leaks. not to say it's impossible..
Old 10-08-2012, 05:53 PM   #4
tebriel
Member#: 244190
2004 BRP WRX Wagon
2004 JBP WRX
that's gotta be a wastegate issue.
tebriel is offline   Reply With Quote
Old 10-08-2012, 08:54 PM   #5
zashoe
Member#: 329523
2002 Impreza WRX
I'm not sure how to tell if it's waste gate. I datalogged so I'll take a look when I get home from class and see if I can make sense of it.
Old 10-09-2012, 08:28 PM   #6
kgrander
Member#: 323584
2004 wrx
rally blue
wastegate.
kgrander is offline   Reply With Quote
Old 10-09-2012, 11:49 PM   #7
zashoe
Member#: 329523
2002 Impreza WRX
it turned out to be launch control! it was interfering with the BCS!
Message Board Statistics All times are GMT -4. The time now is 08:35 AM.
