Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 01-16-2012, 03:32 AM   #1
RISubieRex
Member#: 307060
2004 Impreza WRX
Unhappy Bad Idle After Replacing TGV Driver Side
New here, appreciate all help!
Just replaced my driver side Tumble Generator Valve (TGV) as well as the actuator and sensor. I removed my top mount intercooler, air intake, and my intake manifold to do this as well as my fuel injector and fuel rail. After everything was put back in these were the results.
-Car leaked gasoline from the injectors due to faulty o-ring seals
^^Replaced that
Car Idles like complete CRAP. Idles at 1000RPM and shakes Rough.
Car never idled nowhere near this bad before the installation and I am throwing misfire codes as well P1086 TGV Circuit Low Input
Checked almost everything has far as vacuum leaks or lose hoses, 12 hours into this nightmare im thinking about breaking in and bringing it to a dealer
Any ideas? ILL LOVE YOU FOREVER
RISubieRex is offline   Reply With Quote
Old 01-16-2012, 03:34 AM   #2
RISubieRex
Member#: 307060
2004 Impreza WRX
Also the car sometimes stalls when I start it if I don't give it some gas.
Old 01-16-2012, 09:20 AM   #3
quazimoto
Member#: 70395
Did you put the TGV position sensor on correctly? You need to preload the spring inside.
Old 01-16-2012, 09:29 AM   #4
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
http://forums.nasioc.com/forums/show...ighlight=p2021
I just did this on a Saabaru last night.
The sensor needs to be preloaded as quazimoto said.
To preload the spring you need to attach the sensor to the peg on the end of the TGV axle WITH THE ELECTRICAL CONNECTOR FACING UP then rotate a little greater than 90 degrees clockwise untill its in its position to be bolted down. Then screw it down and plug it back in.
It seems like if that sensor isn't working, the TGVs stay closed all the time. If the TGVs stay closed all the time that bank doesn't get any air or fuel.
Since your primary O2 is on the other bank, it never makes any AFR corrections based on it as it doesn't realize this. If you take this to its natural conclusion you get tons of #2 and #4 misfires, can't build full boost. Car feels slow, sounds funny, won't idle, etc.
Dirty25RS is offline   Reply With Quote
Old 01-16-2012, 09:49 AM   #5
RISubieRex
Member#: 307060
2004 Impreza WRX
Ahh did nothing of the sort, I am on my way to work now I'm going to try it and when we say sensor we aren't referring to the actuator correct?
Old 01-16-2012, 09:53 AM   #6
Dirty25RS
Member#: 56731
I am referring to the sensor correct. the thing on the front.
not the actuator, the thing on the back.
Old 01-16-2012, 02:34 PM   #7
RISubieRex
Member#: 307060
2004 Impreza WRX
Trying it out now thanks for the advice
Old 01-16-2012, 02:54 PM   #8
RISubieRex
Member#: 307060
2004 Impreza WRX
Ok so, I put the connector facing up as I'm winding the spring on the sensors it stops before I bolt it in, the tab on the tgv doesn't turn a full 90 degrees
Old 01-16-2012, 02:59 PM   #9
Dirty25RS
Member#: 56731
It did on the EJ205 I was working on last night.
I had to remove a bolt at about 5 o'clock relative to the TGV axle to get a full 90 degree turn out of it.
Old 01-16-2012, 03:03 PM   #10
RISubieRex
Member#: 307060
2004 Impreza WRX
Nevermind got it putting everything back together
Old 01-16-2012, 03:07 PM   #11
Dirty25RS
Member#: 56731
nice!
Old 01-16-2012, 03:12 PM   #12
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Get rid of them and do deletes lol.
07wrx84 is offline   Reply With Quote
Old 01-16-2012, 03:45 PM   #13
RISubieRex
Member#: 307060
2004 Impreza WRX
Tried it twice still getting a ridiculously crappy idle
Old 01-16-2012, 04:56 PM   #14
Dirty25RS
Member#: 56731
probably boost leak test time then.
Old 01-16-2012, 05:38 PM   #15
RISubieRex
Member#: 307060
2004 Impreza WRX
Probably but I never had this problem problem prior changing the tgv I have no power and it doesn't rev past 4000 it also sounds very quiet like almost a clogged cat it felt like it was starving for fuel it would sometime bogg down
Old 01-17-2012, 08:14 AM   #16
quazimoto
Member#: 70395
Probably because the TGV is stuck closed.
Old 10-10-2012, 05:14 AM   #17
danger1138
Member#: 279525
04 rex luger!
Did u get this problem resolved? Maybe u accidentally pulled out the connectors to one of the coil Packs. I know that has happened o me several times .
danger1138 is offline   Reply With Quote
Old 10-10-2012, 06:07 AM   #18
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
tgv gasket to head has a leak..take a spray bottle and spray
around the base if tgvs. if the spray gets sucked in..leak..
Old 10-10-2012, 07:50 AM   #19
quazimoto
Member#: 70395
This thread is from January.............
FS : 04-07 WRX/STI Drivers side mirror UNPAINTED spongerrich Exterior/Styling 3 01-26-2012 01:58 AM
2006 Tribeca replacing the drivers side low beam again STight Tribeca Forum 8 08-08-2011 10:48 AM
DFW - Help me replace a driver side fender 05 wrx z4g63 Texas Impreza Club Forum -- TXIC 0 01-12-2011 03:14 PM
how do I replace a drivers side window on a 99 legacy rboutin Newbies & FAQs 1 05-01-2010 06:55 PM
Bad idle after fuel pump install?? patrick smith Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 02-23-2010 06:55 PM
