Old 10-09-2012, 10:25 PM   #1
tigburns
Member#: 305043
Default Dyno Tune: 2.5L + Blouch 20G XT-R makes 358whp
Event: dyno pull
Location: Mach V Motorsports for dyno pull Sterling, VA
Ambient Temp: 80.96 degrees Fahrenheit
Elevation: 300ft
Weather: cloudy, 29.64 in-HG, 27% Relative Humidity, SAE 1.0
Tires: Dunlop SP Sport 600 245/40R18
Car: 2012 STI
Tuner: Dan, Mach V
http://forums.nasioc.com/forums/member.php?u=12029
http://fastwrx.com/
Dyno Info: Dynojet Research
Transmission: 6spd stock gearset
Gear: 4th
Peak HP at RPM: 358.29 @ 6500rpm
Peak Torque at RPM: 360.77 @ 3750
Baseline hp/tq for a stock on same dyno: 243.86hp @ 6300, 245.21tq @ 3000
Target Boost: Max boost 21 psi, tapers to 20 psi.
Target AFR: AFRs are in the mid-11's. Around 11.1-11.2 at redline
Fuel: 93 octane
Engine/Power Modifications:
AEM Cold Air Intake for 08+ WRX/STi
Cobb Downpipe, fiberglass wrapped
Cobb Accessport, Mach V custom tune
SPT Catback 3" exhaust from factory
Invidia WRX/Sti Header, large tube, fiberglass wrapped
ETS top mount intercooler
Denso Iridium spark plugs, 1 range colder
Fuku Works turbo inlet pipe
Mach V 3-Port Boost Control Solenoid
Blouch 20G-XTR Turbo Upgrade Ceramic Coated
Deatschwerks Top-Feed Injectors 750cc
Grimmspeed Ported and Polished TGV Bypass, ceramic coated
Grimmspeed PNP Throttle Body, ceramic coated
Grimmspeed PNP intake manifold, ceramic coated
Grimmspeed 3mm phenolic spacers
Driveline Modifications:
Suspension Modifications:
Cartboy pitch stopper
cartboy short shifter and shift bearings
STI Type N Engine Mounts
Other Modifications:
tigburns is offline   Reply With Quote
Old 10-10-2012, 07:14 AM   #2
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
sweet numbers, but i think you got the rpms mixed up...
Originally Posted by tigburns View Post
Peak HP at RPM: 358.29 @ 3750rpm
Peak Torque at RPM: 360.77 @ 6500
thisisntjared is offline   Reply With Quote
Old 10-10-2012, 08:20 AM   #3
spintheground
Member#: 239638
2007 WRX TR UGM
^Yeah I'd say so.
Did you ask for a "high number" tune? Because that graph looks like it. Haven't seen a lot of 20g-XTR graphs so maybe I'm wrong.. but I'd assume you could get a flatter torque curve.
spintheground is offline   Reply With Quote
Old 10-10-2012, 09:29 AM   #4
tigburns
Member#: 305043
fixed, thanks
Old 10-10-2012, 09:36 AM   #5
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Congrats OP! And great job Dan!! 11 sec street car making peak torque under 4k.
Originally Posted by spintheground View Post
^Yeah I'd say so.
^it's rare you see an uncorrected chart posted in PPB. For reference I made about 285whp on Dan's dynojet when I was stage 2 (can't remember the correction factor but probably the same) and trapped 108mph in the 1/4.
I think the torque drop is an illusion due to the RPM's on the chart being so close together. Horsepower doesn't start to drop until 6500rpm which tells me the torque is fairly flat. Perhaps the high peak torque is due to an initial boost spike?
Old 10-10-2012, 09:48 AM   #6
spintheground
Member#: 239638
2007 WRX TR UGM
I wasn't refering to the correction factor or the number's being 'high'. Just that the graph shows high peak numbers vs a tune with less peak power but more usable power.
Maybe it's just how the turbo performs, I don't know.
I'd like to see the boost plot.
Old 10-10-2012, 10:27 AM   #7
tigburns
Member#: 305043
Thanks! Keeping the peak tq low was a goal, along with maintaining good throttle response. This is my DD, so wanted to keep it drive-able with a fairly wide power band. Dan & Matt @ Mach V were very helpful in guiding me along and making final "adjustments".
Old 10-10-2012, 10:48 AM   #8
MrTbrew8
Member#: 329811
Sounding good
MrTbrew8 is offline   Reply With Quote
Old 11-07-2012, 12:34 PM   #9
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Nice setup man. i just got tuned with a 20gxt by dan and also had almost identical numbers as you.
i bet its fun.!
mrjcotten is offline   Reply With Quote
Old 11-08-2012, 01:18 PM   #10
MMY MSL
Member#: 335135
2007 WRX
WRC blue
Congrats on the power, nice chunk over stock! What inlet size and hotside does that XTR have?
MMY MSL is offline   Reply With Quote
Old 11-08-2012, 01:40 PM   #11
Badler
Member#: 133597
I think it's throwing you off because it's not stretched like most of them.
Nice setup OP. Looks like stock spool until 3500rpm and then it just takes off! Great street setup IMO. This thing would wail on e85.
Old 11-11-2012, 05:13 PM   #12
tigburns
Member#: 305043
8cm inlet, not sure about hot side. Whatever it is off the shelf, I didn't make any changes.
Old 11-11-2012, 10:44 PM   #13
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Most people would rather have a faster car than purposely give up power in search of a flatter torque curve.
I run this turbo on E85 and it's a lot of fun!
8cm is the hot side. The inlet is either stock (2.4") or 3". I think turbo is usually a 2.4" inlet.
Old 11-12-2012, 11:48 PM   #14
roger280zx
Member#: 265665
I'm no subbie guy, but sense when does peak tq at 3750 equate to a "high numbers tune"? Tq curve looks pretty grunty to me. I'm sure it drives like a beast of a DD.
roger280zx is offline   Reply With Quote
