Old 10-10-2012, 10:47 AM   #1
ARGPAB
Member#: 305152
2012 WRX 5-Door WRB
2000 Corvette C5
Default Stage 2 Build
This may not be the right place, if so please direct me. I have a 2012 WRX, with AP V3, and Invidia Q300 stage 1. I want to have a stage 2 setup. What would be the best/most reliable stage 2 setup to have? Please list what you have done.
ARGPAB is offline   Reply With Quote
Old 10-10-2012, 11:26 AM   #2
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
Default stage 2
For stage 2 you need a aftermarket downpipe. Either Catted or not.
Then I'd suggest bulletproofing your top mount and getting a good professional tune (a protune since using your accessport).
Then you are set.
CTSparky is offline   Reply With Quote
Old 10-10-2012, 11:35 AM   #3
ARGPAB
Member#: 305152
2012 WRX 5-Door WRB
2000 Corvette C5
I will be getting an Invidia catless dp next week. As far as ECBS and BC is that necessary? I will be doing a Forge BPV. What do I need for the top mount to be bullet proof?
Old 10-10-2012, 03:01 PM   #4
ARGPAB
Member#: 305152
2012 WRX 5-Door WRB
2000 Corvette C5
Bump for help...
Old 10-10-2012, 03:07 PM   #5
rymaggi
Member#: 253442
Do not get a bpv or a bov. Down pipe. Then tune. Done. Your stage 2
The less "garbage" your throw on (bov bpv etc.) the less there is to go wrong.
rymaggi is offline   Reply With Quote
Old 10-10-2012, 03:09 PM   #6
rymaggi
Member#: 253442
Cobb OTS maps are kinda weak sauce. Fork out the money for a protune.
Old 10-10-2012, 03:16 PM   #7
ARGPAB
Member#: 305152
2012 WRX 5-Door WRB
2000 Corvette C5
But wouldn't I need a BPV to make it run more solid? what about cracking the tmi?
Old 10-10-2012, 03:36 PM   #8
WrxFtw02
Member#: 231192
PROs Tuned 270/251
This is going to cost a lot, are you sure you can afford it? I mean catless downpipes are like $300.
WrxFtw02 is offline   Reply With Quote
Old 10-10-2012, 03:40 PM   #9
st205wrx
Member#: 193253
08 wrx 322/352
wrb
p&l short ram intake
grimmspeed ebcs
Downpipe of whatever brand you'd like
up-pipe
you dont need a diff bov (i am running 322awhp-352awtq on stock bov)
walbro 255 ( dont need it too much for just st2)
IPR top mount is cheap but good
if youd like headers equal length= more torque
this should be more then enough to get you a little bit past stage 2 hope it helps
st205wrx is offline   Reply With Quote
Old 10-10-2012, 03:41 PM   #10
rymaggi
Member#: 253442
I got mine for $100 Invida used. Look for unibombers BOV FAQ. They make all Subarus run like ****. Except for those select few that are boosting out of the stock bpv efficiency range.
You do not need one. No ifs, buts, when's, or why's,
Old 10-10-2012, 03:42 PM   #11
ARGPAB
Member#: 305152
2012 WRX 5-Door WRB
2000 Corvette C5
Yup I can afford it. I don't remember you being my financial consultant. Run along little one.
Old 10-10-2012, 03:47 PM   #12
WrxFtw02
Member#: 231192
PROs Tuned 270/251
Are you sure? Last time I checked you were begging for jobs and looking for money.
Old 10-10-2012, 03:48 PM   #13
WrxFtw02
Member#: 231192
PROs Tuned 270/251
Plus you couldn't afford my cost to be your financial consultant.
Old 10-10-2012, 03:51 PM   #14
ARGPAB
Member#: 305152
2012 WRX 5-Door WRB
2000 Corvette C5
Yup, we all have financial struggles at one point. Its called responsibilities. Now that those responsibilities are met I can play. Why don't you kick rocks and mind your business kid.
Old 10-10-2012, 04:04 PM   #15
ARGPAB
Member#: 305152
2012 WRX 5-Door WRB
2000 Corvette C5
So St205WRX, I was thinking how does this sound.... Dp, DW65 fuel pump, Cobb SF intake forge BPV. GS ECBS and PW or Spearco, and obviously a protune.
Old 10-10-2012, 04:05 PM   #16
alva8193
Member#: 318755
2012 Phatbotti Tuned
dont waste the money on intake, everything else sounds good. EBCS*
alva8193 is offline   Reply With Quote
Old 10-10-2012, 04:08 PM   #17
st205wrx
Member#: 193253
08 wrx 322/352
wrb
I would get a lager diameter intake with a bigger inlet.. you'll love it i give you my word. As far as the bpv... like i said i am running a stock one and putting down nice numbers. everything else sounds good. now just start saving for a new clutch
Old 10-10-2012, 04:08 PM   #18
ARGPAB
Member#: 305152
2012 WRX 5-Door WRB
2000 Corvette C5
Sup pajerito....so no intake really? Is it gonna heat soak that bad? Perrin film?
Old 10-10-2012, 04:11 PM   #19
rymaggi
Member#: 253442
Stock intake is good for more whp than your stock turbo is even capable of producing.
Old 10-10-2012, 04:12 PM   #20
alva8193
Member#: 318755
the sf is a box of metal aka a hot box, intakes are aluminum and dissipate about as quick as plastic but absorb heat more I wouldn't get an intake until im BT and need a KStech bigger maf intake. Its loud and if you think its worth it for the noise go for it but id put that money into suspension
Old 10-10-2012, 04:16 PM   #21
alva8193
Member#: 318755
also reduce engine bay temps, see here http://forums.nasioc.com/forums/show...=fun+with+heat
best investment u can make and they arent very expensive
Old 10-10-2012, 05:15 PM   #22
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
You can add bolt-on's still you're blue in the face. Higher flow injectors and fuel pump, TGV deletes, larger intercooler, MBC and/or EBCS, intake, exhaust, external wastegate, etc. The list can go on and on. If you just want to lean on your stock turbo while not setting records, I'd go with a full TBE, panel filter and a hallman MBC. Drive car and enjoy.
Old 10-10-2012, 05:34 PM   #23
ARGPAB
Member#: 305152
2012 WRX 5-Door WRB
2000 Corvette C5
Is there a specific tune from the AP for the panel filter or is there no need to tune for it?
Old 10-10-2012, 05:45 PM   #24
RancerEvorution
Member#: 235190
2011 STi
stock airbox + k&n drop in filter
hallman mbc
dw65c drop in fuel pump
catless dp
el headers
ewg up pipe with 38mm ewg
TMIC
Good tune
done. should be good for a mid to low 12 second pass if you can drive. 108-110 traps
would also invest in a boost gauge and AFR gauge and a cobb ap to monitor feedback knock. if you dont monitor any of those three you are deff more likely to mess something up
RancerEvorution is offline   Reply With Quote
Old 10-10-2012, 07:56 PM   #25
2011boostdwrx
Member#: 263470
Look at my build, I have been through enough heart ache on my11. May I suggest you stay at stage-2 with a good fitting TMIC (AVO fits best), I ve been through the IPR/Perrin headache. Go stage-2 get a good pro tune.
I would do the following:
Catted DP, CDE
EBCS (grimmspeed) - optional
Forge BPV (Subaru specific model)
TMIC of choice (mine is AVO) -Optional
AEM intake
AP OTS stage-2 (for now)
Call it a day. You could wait on the TMIC, but to get max potential it should be tuned on the car.
