Old 10-02-2012, 12:35 PM   #2251
1FSTREX
Member#: 109348
05 STI
Originally Posted by KartRacer3 View Post
Trailbraking at its finest
Where was this event at??
Lack there-of. Went way too hot into the corner. Tried to trail brake but it was too late. Instead of straighten out i dug deeper. Still learning lol.
Originally Posted by scby rex View Post
Looks like snow plowing to me.
Touche!
1FSTREX is offline   Reply With Quote
Old 10-02-2012, 06:20 PM   #2252
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Touche!
What exactly is trail braking? I'm my hpde they just say NO.
Louie is offline   Reply With Quote
Old 10-02-2012, 07:07 PM   #2253
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Short term summary, its braking while your in the turn/apex in order to set your car up in position to come out of the apex in the area you want it too.
On topic: Anyone here have some RSM9's or RP03's? I love the look of these especially and just wanted to see if anyone else has them.
Old 10-02-2012, 11:35 PM   #2254
1FSTREX
Member#: 109348
05 STI
Agreed.
Old 10-06-2012, 11:25 AM   #2255
04Silverex
Member#: 77322
SSM
Originally Posted by 04Silverex View Post
Will 18x 9.5 38 offset Enkei rpf1s clear 2006-07 wrx front 4 pot calipers without spacers?
Anyone know the answer?
04Silverex is offline   Reply With Quote
Old 10-06-2012, 11:56 AM   #2256
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Yes, only brembos need a 10mm spacer
Let's Spool is offline   Reply With Quote
Old 10-09-2012, 02:45 PM   #2257
White Owl
Member#: 298128
07 STI
SWPM
About to order some RPF1s today and wanted some opinions from you guys. They will be my "track wheels" for autocross.
Reason: I want light weight and wider than stock without extensive fender modifications. I need some input on what size tires to run and widest possible wheel.
As of now I want to order the RPF1 in SBC 17x8 +43. I will be going with Toyo R888 in 245/40/17.
This will be going on an 07 STI lowered on Eibach sport springs. First of all any comments on the fitment or what will be required to fit them are welcome. Second, should I opt for a 245/45 instead of a 40 series?
I am currently running 245/45 on my stock BBS and they fill the fender wells nicely and no rubbing even in autox. So I assume I would still be able to run a 45 series on a slightly wider wheel? Is the shorter sidewall more desirable for autocross?
Just want some feedback on this before I go spend well over 2k on something to find out I should have done something else.
Also, it is my understanding that an 8" wheel is the widest you can go without fender mods? I know this has been covered before but I want to go widest possible in a 17" without extensive modifications so please help me stay on the right track. If I were to go to a 8.5" wheel how much fender mods would need to be done?
Before someone tells me to research. I have been researching for months now. I've read thread after thread and have learned a lot. I am now down to the wire and just want to verify my research has lead me in the right direction.
White Owl is offline   Reply With Quote
Old 10-09-2012, 03:10 PM   #2258
1FSTREX
Member#: 109348
05 STI
Check out Drew's blog: http://t3hclap.com/
Contact him, he is one of the smartest guys i know about STI suspension/wheel/tire combos. He ACTUALLY knows what he is talking about and most of it is from personal experience or through the experience of others that he has personally witnessed. He personally helped me with my autocross set up.
Also check out IWSTI, there is a lot of good info on there.
Will
Old 10-09-2012, 03:41 PM   #2259
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
I'm not sure where you're finding 17x8 +43mm SBC, it may have been a custom run. I know there is a 17x8 +45mm and 17x8.5 +40mm.
have you read my fender mod articles? this is the one you'll need if you opt for the 17x8.5 +40mm with a 245/40/17.
T3hClap.com Fender Mod 05-07 STI
Follow that step by step and you'll be rub free without issue.
The stock wheels are 17x8 already so going to a 17x8 +43(or 45mm) will only lower the offset of your current setup not change the width.
The +45mm on stock fenders and standard lowering springs can work with a 245, but some people still require fender work depending on their specific vehicle, rear camber, and driving style. (current status of springs/struts have something to do with it too).
feel free to shoot me a PM or email if you want to get into more detail.
-t3h_clap
Old 10-10-2012, 12:58 PM   #2260
White Owl
Member#: 298128
07 STI
SWPM
-t3h_clap
Bad info from my wheel supplier. I was also incorrect in thinking my factory wheels were 7.5".
So thank you clap for saving me from that bad decision. Ill send you a PM now
Old 10-12-2012, 12:37 PM   #2261
deanwrx
Member#: 188997
2007 STI
RPF1 17x9 +35 (5x100) with Federal RSR 235/40/17. Mounted them last night at Broken Motorsports in Union City, NJ. Will get more pics this weekend.
I wanted to add that I'm lowered on Mach V springs (mild drop) with rear fenders rolled flat. I'm running stock camber and I have zero rubbing. If I went to a 245/40 Star Spec or AD08 I may rub just slightly since they are a little wider than my Federals.
And thanks Drew!
deanwrx is offline   Reply With Quote
Old 10-12-2012, 05:55 PM   #2262
jgardner9000
Member#: 219549
2009 STi
Fresh powder!
Satin candy teal
jgardner9000 is offline   Reply With Quote
Old 10-12-2012, 06:06 PM   #2263
03boxer4
Member#: 66622
2002 WRB wrx - Sold
Big White Jeep Unlimited
moar pics now!!!!
03boxer4 is offline   Reply With Quote
Old 10-12-2012, 06:37 PM   #2264
eMatt
Member#: 147196
2003 Evo
WW
Not a Suby, but enkei wheels. I like them sometimes, and sometimes I don't. I hope you don't mind!
IMG_3570.jpg by Butter Snaps, on Flickr
eMatt is offline   Reply With Quote
Old 10-13-2012, 02:04 AM   #2265
20wrx05
Member#: 177861
1999 Built! RSTI
FP Red, E85, IM FAST!
Looks great man nothing like a Wiked White evo with RPF-1s cant go wrong plus it has a 4g63 which was handed down by god so your in the right in alot of ways hahahaha great car, I just put s set of 17x9.5 rpf-1s on my freinds 05 evo ill post a pic
20wrx05 is offline   Reply With Quote
Old 10-13-2012, 03:13 AM   #2266
SG02WRX
Member#: 151814
deanwrx post profile pics
SG02WRX is offline   Reply With Quote
Old 10-14-2012, 02:28 PM   #2267
KevtronZero
Member#: 216291
2015 Subaru WRX CWP
2002 Subaru WRX PSM
Enkei NT03+M 18x9.5 +40 5x100, 245/35/18 Federal RS-R
KevtronZero is offline   Reply With Quote
Old 10-15-2012, 04:20 PM   #2268
TheStig_22B
Member#: 208510
05 STI
my newly acquired RPF1's. gonna be putting them on next spring. 17x9.5 +38
IMG_3053 by Deebsr6, on Flickr
TheStig_22B is offline   Reply With Quote
Old 10-15-2012, 04:25 PM   #2269
04Silverex
Member#: 77322
SSM
What color are those?
Old 10-15-2012, 04:37 PM   #2270
TheStig_22B
Member#: 208510
05 STI
just the regular silver. I may powder coat them though before I put tires on them. Not sure yet.
Old 10-16-2012, 07:37 PM   #2271
deanwrx
Member#: 188997
2007 STI
17x9 +35 RPF1 in 5x100 (got from Dezod Motorsports)
Old 10-16-2012, 08:50 PM   #2272
Chaos_Performance
Member#: 333980
2004 WRX Impreza Wag
San Remo Red
Not on a car but got two older Enkei RS7 rims, they are 5x114.3 and 4x110 i believe 17x7 idk the offset.
Chaos_Performance is offline   Reply With Quote
Old 10-16-2012, 08:55 PM   #2273
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Loved those wheels!
Old 10-16-2012, 09:48 PM   #2274
Chaos_Performance
Member#: 333980
San Remo Red
im trying to sell them but its soooo hard to sell two rims!! lol im practically giving them away! lol
Old 10-17-2012, 01:32 AM   #2275
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
yeah craigslist them. good luck.
The Official Wheel Thread. Teh Legacy Legacy Forum 32 Yesterday 07:02 PM
The Colored Wheels Thread WRXSIG Member's Car Gallery 2882 03-08-2015 06:34 PM
The wheel thread aakrusen Member's Car Gallery 92 10-13-2013 07:20 PM
The BBS Wheel Thread CTI-Distributing Wheels/Tires 7 02-17-2005 09:23 PM
The Gold Wheel Thread adam555 Member's Car Gallery 39 03-05-2004 03:15 AM
