Old 10-10-2012, 08:02 AM   #1
waltah
Member#: 317856
Default Highest elevation in your WRX/STI
Going up whiteface mountain today and can drive up to about 4700ft I believe. Just curious where others have driven at high elevation. I've driven up mount Washington 6200ft but not my STI
waltah is offline   Reply With Quote
Old 10-10-2012, 08:26 AM   #2
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
I live at 6,062 ft.
WRB19 is offline   Reply With Quote
Old 10-10-2012, 08:53 AM   #3
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
12,xxx out in CO a few years back. Turbo at altitude is so much fun...
Beanboy is offline   Reply With Quote
Old 10-10-2012, 11:43 AM   #4
STi410
Member#: 158800
2010 STi
6,100 ft in NC, car ran perfect
STi410 is offline   Reply With Quote
Old 10-10-2012, 12:23 PM   #5
Evanston Subaru
Member#: 217382
I did this as well in CO with a 2006 WRX Wagon. Turbos really don't suffer at altitude like NA cars do. It was a blast!!!
Evanston Subaru is offline   Reply With Quote
Old 10-10-2012, 12:32 PM   #6
seaneddy11
Member#: 330431
2005 STI
Took my car from 2,000 to 7,000, much slower in the higher
seaneddy11 is offline   Reply With Quote
Old 10-10-2012, 12:39 PM   #7
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Don't worry about it. Gone up Mt washington with mine just few months ago. It will make it no problems.
Got to remember turbo cars are not like NA when it comes to things like altitude. The turbo will still compress air into the engine even if the air is thinner. So you won't lose that much power or anything at all, compared to NA.
That being said, will say MPG is horrible going up, great coming down though lol
talvai is offline   Reply With Quote
Old 10-10-2012, 12:41 PM   #8
seaneddy11
Member#: 330431
2005 STI
If car is protuned for a lower elevation would that make a difference going higher?
Old 10-10-2012, 02:23 PM   #9
MorganJ
Member#: 203823
2009 WRX STI
2001 V7 JDM STI
I stay at sea level mostly
Never had it up too high above 1800ft. I do notice a difference in fuel mileage though. At sea level I get better fuel mileage.
MorganJ is offline   Reply With Quote
Old 10-10-2012, 02:33 PM   #10
rkramer
Member#: 118209
2015 WRX Limitec
no... at least not unless it was a piss poor tune to start with. The ecu does altitude and temperature compensation.
rkramer is offline   Reply With Quote
Old 10-10-2012, 02:36 PM   #11
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Regularly our Forester sees 6,000 +. Highest was 10,500.
Old 10-10-2012, 03:23 PM   #12
Heedlessone
Member#: 254130
1993 LS1 RX7
I'm at 6,500 in Big Sky, MT and I don't know what my car feels like at sea level. Only ever go down to 4,500ft. But it feels good up here as far as I know.
Heedlessone is offline   Reply With Quote
Old 10-10-2012, 05:47 PM   #13
grzydj
Member#: 84984
2006 Impreza 2.5i 5D
'04 Toyota Tacoma TRD
11k on I-70 in Colorado. Could have sworn the car was running on 1 cylinder at that altitude.
Car felt like a dragster when I got back down to sea level.
grzydj is offline   Reply With Quote
Old 10-10-2012, 07:20 PM   #14
1BadP71
Member#: 289883
WRX '03 + '06 WAGON
White and Blue Limited
Probably 200 ft above sea level. I live at 150. This is Florida for you!
1BadP71 is offline   Reply With Quote
Old 10-10-2012, 07:27 PM   #15
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
No WRX/STI here but in my 2.5i, 11,992ft. Higher in different vehicles.
subyski is offline   Reply With Quote
Old 10-11-2012, 08:03 AM   #16
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
No ecu should be constantly adjusting certain values to make up for that. Now if I protuned a car for 100ft and its at 5k and you went to a dyno before and after you may see a slight power loss, but nothing bad will happen.
Again reason why certain cars can't make it up is because the air gets thinner. Thinner air for na car is harder to get into the motor, making it struggle. Turbo though your compressing the air into the motor so your constantly giving it plenty of air so it doesn't struggle nearly as much. Again don't worry about.
Old 10-11-2012, 12:24 PM   #17
Zuko65
Member#: 253527
2007 WRX
Mine has been to the top of Pikes Peak! 14,114 feet Unfortunatly on the Pikes Peak Highway you cant go all the fast =P
Zuko65 is offline   Reply With Quote
Old 10-11-2012, 12:40 PM   #18
Stevetoter
Member#: 332476
2012 WRX
I live at 6,062. Had it up to about 11000.
Stevetoter is offline   Reply With Quote
Old 10-11-2012, 12:46 PM   #19
seaneddy11
Member#: 330431
2005 STI
I must be tripping myself out, there's definitely a big powerless, not that substantial I guess but definitely noticeable, also once I shift in this elevation my Rpms don't immediately drop like in lower, it will hover for a tad bit mid shift..
Also, my turbo timer is going higher, normal driving it'll stay on for about 45 seconds, up here it's around 1.5 mins, I'm just confused on how the type of air could effect my car like this. (Also around 50 degrees)
Old 10-14-2012, 02:13 AM   #20
kbluie
Member#: 263271
2013 wrx
wrb
Tallest point around here is 2700ft and i've been up just about to that. Not as interesting as most but it was a fun drive to it.
kbluie is offline   Reply With Quote
Old 10-14-2012, 02:31 AM   #21
CoryA08
Member#: 259523
2011 WRX Hatch
Dark Grey Metallic
There is definitely a power loss at altitude, just comes with the environment. If you are coming from sea level you will notice the loss, but the car will still run great. Live at 6500 in CO and on my weekly commutes I travel +/- 2000 vertical feet. On weekends I head up to the mountains, taken the WRX over 14K feet, Mt. Evans, Pikes Peak and many back country passes.
Trust me you would definitely notice the power loss of altitude in an NA car a lot more than what we see.
The turbo is great for providing power when most cars have none.
CoryA08 is offline   Reply With Quote
Old 10-14-2012, 04:45 PM   #22
NeverSummer WRX
Member#: 311108
2012 WRX LTD 5-door
I regularly go over Loveland Pass 11,991 feet (3,655 m) and did a few drives through RMNP trail ridge road 12,183 ft (3,713 m). Also as Cory said Mt. Evans (highest paved road in NA).
NeverSummer WRX is offline   Reply With Quote
Old 10-14-2012, 10:26 PM   #23
JH1304
Member#: 201407
09 STI
12 WRX, 06 Foz
Pike's Peak.
Whatever elevation that is... 14k+
Edit:
Ah yeah, that. Sure you can drive fast, you will die but you can do it haha.
JH1304 is offline   Reply With Quote
Old 10-14-2012, 11:12 PM   #24
CobbsSTI
Member#: 245242
2005 STI
E85 Power
Originally Posted by JH1304
Pike's Peak.
Edit:
How did the car run at that altitude?
CobbsSTI is offline   Reply With Quote
Old 10-15-2012, 10:26 AM   #25
Zuko65
Member#: 253527
2007 WRX
Originally Posted by JH1304 View Post
Pike's Peak.
Edit:
Im not that into dieing oddly enough. My car was fine up there it just keeps pulling!
