Old 10-10-2012, 01:20 PM   #1
amarks563
Member#: 283410
2007 WRX Wagon
UGM
Default Subaru Boost Gauge - Bizarre Problem
Many moons ago, I installed a used Lamco boost gauge in my 2007 WRX. I plugged the electrical harness that came with the gauge into the dongle in the back of the head unit, and it didn't work. Assuming maybe an early boost gauge with a burned out light bulb, or an inappropriate use of that dongle, I left it alone, and tolerated not seeing the gauge at night.
A few weeks ago, the backlight turned on and started working.
But not consistently. Most of the time, the light still does not turn on when I turn the headlights on. However, if the headlights are on, the boost gauge will illuminate after I give an input on the left stalk (the one that controls headlights and turn signals). I've had the backlight turn on when I flashed my brights, and I had the backlight turn on when I used a turn signal. I don't get it.
Anyone have insights as to the source of this gremlin? When the boost gauge backlight turns on, it will work properly until I turn off the ignition. I can turn the headlights off and on, and the boost gauge will work correctly, turning off and on appropriately. Similarly, when the backlight is on, the dimming works perfectly.
amarks563 is offline   Reply With Quote
