Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 10-07-2012, 06:49 PM   #26
wrxguy04
Member#: 261086
1999 OBS 2.5 Swap
So i keep hearing a loud vacuum leak sound right in front of me while im driving and its making me go crazy
Checked brake booster hose and also the intake manifold an intercooler y-pipe elbows but those are hard to get to in order to check if they're leaking while the car is running..
Any suggestions on what it may be around the driver side firewall man area?
wrxguy04 is offline   Reply With Quote
Old 10-07-2012, 07:08 PM   #27
WrxWrb
Member#: 287477
02 Wrx Wagon WRB
EVO III 16g=Fun
Im going to guess you are leaking at the bpv still. Also sometimes where you hear the leak is very far from where it really is.
I would also check the compressor to tmic y pipe connection.
WrxWrb is offline   Reply With Quote
Old 10-07-2012, 08:26 PM   #28
wrxguy04
Member#: 261086
1999 OBS 2.5 Swap
Well i actually blew out the diaphragm in my megan racing vta bov so i switched it back to the stock one but put that one on vta as well because my inlet's recirculation hose is trashed but i put a new gasket on it! Ill check it though
Old 10-07-2012, 10:31 PM   #29
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Did the boost gauge line get cut when running ir through the firewall? The only other things over in that area is the tmic elbow, brake-vac line. When you charge the system are you hearing anything in that area?
2gnt2wrx is offline   Reply With Quote
Old 10-07-2012, 11:23 PM   #30
wrxguy04
Member#: 261086
1999 OBS 2.5 Swap
Nah boost gauge line is good! But nah i gotta charge it up and check it back there
Old 10-08-2012, 12:11 AM   #31
BIGJBEARS
Member#: 301099
You cannot run the stock bpv as a vta, it leaks @ idle
BIGJBEARS is offline   Reply With Quote
Old 10-08-2012, 12:38 AM   #32
wrxguy04
Member#: 261086
1999 OBS 2.5 Swap
Well actually its crushed and JDM modded! If that makes a difference?
Old 10-08-2012, 06:27 PM   #33
wrxguy04
Member#: 261086
1999 OBS 2.5 Swap
Anybody know?
Old 10-10-2012, 12:42 AM   #34
wrxguy04
Member#: 261086
1999 OBS 2.5 Swap
Bump234
Old 10-10-2012, 01:42 AM   #35
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Crushing it should not make a difference and is a common mod. But you must run the hose that goes back to the inlet.
Old 10-10-2012, 02:49 AM   #36
wrxguy04
Member#: 261086
1999 OBS 2.5 Swap
So you're saying it will leak at idle regardless?
Old 10-10-2012, 10:26 AM   #37
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I think what he was saying is that it will leak back into the intake track.
Old 10-10-2012, 10:56 AM   #38
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
^^ Only if he has the recirc hose on there lol. otherwise it's leaking to the world.
tebriel is offline   Reply With Quote
Old 10-10-2012, 11:52 AM   #39
wrxguy04
Member#: 261086
1999 OBS 2.5 Swap
Haha yeah the bpv elbow isnt on and neither is the recirc hose so its vta AND leaking. ****
Old 10-10-2012, 01:52 PM   #40
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I don't think I've ever seen anyone run a stock bpv vta lol, Pretty sure that's your problem.
Old 10-10-2012, 02:30 PM   #41
wrxguy04
Member#: 261086
1999 OBS 2.5 Swap
Haha thanks man. Ive heard that crushing it helps but oh well. AND i found out that the little vacuum line connector on the compressor of the turbo was clogged so bad it wasnt letting air pass
