#4501 |
Member#: 191495
NESIC
Vehicle:'05 WRB GTX3071R JDM V8 EJ207 USDM 6MT |
#4502 |
Member#: 856
International
Vehicle:2005 JDM STi Black |
result.
#4503 |
Member#: 224785
MWSOC
Vehicle:2005 wrx-jdm207 i went black... |
i personally am running nearly the same timing on my ej207 as they have mapped in japan. i just have a smoother curve transition and stuff like that. using the s204 avcs and timing map as a reference at least.
#4504 |
Member#: 46135
Tri-State
Vehicle:02 WRX Powered by Sti V9 Spec C |
![]() ![]() These are the Sponaugle tables. John only posted information amounting to a fraction of this table. In it, the engine code numbers are correlated to the piston part number and the versions. If you want to skip the versions, it's your choice. |
#4505 |
Member#: 856
International
Model code numbers are wrong in that table for MY05!
#4506 |
Member#: 6886
Tri-State
Vehicle:MY01 EJ207 HTA35r nothing to see, i'm stock |
#4507 |
Member#: 46135
Tri-State
In what respect are you saying the model number codes are wrong?
And based on what source? |
#4508 |
Member#: 214589
BAIC
Vehicle:2002 wrx wagon PSM |
#4509 | |
Member#: 856
International
Model code for MY05 JDM STi is GDBE4EH, the table has the wrong year code ( which should be E) against the MY05 models in the model code table. Last edited by johnfelstead; 10-10-2012 at 02:12 PM. |
#4510 |
Member#: 856
International
#4511 |
Member#: 166324
NESIC
Vehicle:02 V8 Spec C 03 V9 Limited 2013 Legacy |
Excuse me if I'm the only one getting confused by this. What the heck are you talking about when you say "Widetrack Blobeye"????? Did only Europe get this widetrack or Japan too?
#4512 | |
Member#: 856
International
The MY05 Widetrack Blobeye was the last model year before the Hawkeye, it has a wider track at the rear than the MY03/04, 114.3mm PCD hubs, 8x17 wheels, longer wheelbase which matches the spec C, later generation DCCD-A with Yaw and steering wheel position sensors....... Easiest visual indication of the Widetrack car is the extra blisters fitted to the rear wheel arches, to accomodate the wider track and wider wheels. |
#4513 |
Member#: 191495
NESIC
I'd assume he means the equivalent to the usdm 05 sti, with the fender archers due to the wider track
#4514 |
Member#: 214589
BAIC
#4515 |
Member#: 157532
MWSOC
Vehicle:2002 MY03 EJ207 E85 Dom 1.5XTR Twinscroll! |
#4516 |
Member#: 46135
Tri-State
The model numbers are wrong for 05, they should have E in the description, for rev E, in the 4th designator of the code.
The table is still good, other than this. |
#4517 |
Member#: 856
International
#4518 | |
Member#: 175334
TXIC
Vehicle:2003 Impreza WRX JDM v8 EJ207 WRB |
![]() ![]() And i do have this IAT sensor on the intake manifold (currently unplugged): ![]() |
#4519 |
Member#: 46135
Tri-State
The sensor is there since rev C.
#4520 |
Member#: 856
International
Based on that i'd say the homologation sheet is wrong Torquey.
#4521 |
Member#: 214589
BAIC
trying to move pins on my ecu but the white locks at the top are stuck. dont want to destroy the clips. goddamn it.
#4522 |
Member#: 115297
SWIC
Vehicle:2002 ej207 vf34 WRB |
My V8 EJ207DW5CR has the temp sensor in the plenum (right under throttle body) and the oil filler says 7/03..
I was under the impression mine was a model year 2003/2004.....? John your new info would suggest mine is a model year 2005, since it has the temp sensor? I find that confusing if not contradictory to what the date on my oil cap says, though of course its entirely possible its not an original cap. Last edited by azscooby; 10-10-2012 at 03:25 PM. |
#4523 |
Member#: 224785
MWSOC
small screw driver and force the locks up. only way to do it. then push them back down and if it make syou fell better put some tape around it or a zip tie. or both!
#4524 |
Member#: 224785
MWSOC
What A Cluster **** Of Three Pages Of Info!
#4525 | |
Member#: 191495
NESIC
| Thread Tools | |
| Display Modes | |
| ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain | 2 | 02-26-2011 07:29 PM |
| Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain | 10 | 06-03-2010 04:53 PM |
| JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
| 08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
| Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain | 21 | 10-17-2005 01:56 AM |
