Old 10-10-2012, 01:28 PM   #4501
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
Yea mine has that sensor
todeswalzer is offline   Reply With Quote
Old 10-10-2012, 01:37 PM   #4502
johnfelstead
Member#: 856
2005 JDM STi
result.
johnfelstead is offline   Reply With Quote
Old 10-10-2012, 01:44 PM   #4503
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
i personally am running nearly the same timing on my ej207 as they have mapped in japan. i just have a smoother curve transition and stuff like that. using the s204 avcs and timing map as a reference at least.
Old 10-10-2012, 01:45 PM   #4504
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
These are the Sponaugle tables.
John only posted information amounting to a fraction of this table. In it, the engine code numbers are correlated to the piston part number and the versions.
If you want to skip the versions, it's your choice.
Old 10-10-2012, 01:53 PM   #4505
johnfelstead
Member#: 856
2005 JDM STi
Model code numbers are wrong in that table for MY05!
Old 10-10-2012, 01:58 PM   #4506
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
does your source specify the reference market? UK vs JDM?
Old 10-10-2012, 02:02 PM   #4507
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
In what respect are you saying the model number codes are wrong?
And based on what source?
Old 10-10-2012, 02:06 PM   #4508
PHruska
Member#: 214589
2002 wrx wagon
I dont think so.
If the plenum has a temperature sensor in it, then it is at least an MY05. If it doesnt then it's MY04 or earlier.
mine has an 03 stamp under the oil fill and its got the temp sensor under the IC...
PHruska is offline   Reply With Quote
Old 10-10-2012, 02:07 PM   #4509
johnfelstead
Member#: 856
2005 JDM STi
Based on the big lump of MY05 Widetrack Blobeye JDM Obsidian Black Pearl Goodness sat outside my front door and the chassis plate on that.
Model code for MY05 JDM STi is GDBE4EH, the table has the wrong year code ( which should be E) against the MY05 models in the model code table.
Old 10-10-2012, 02:11 PM   #4510
johnfelstead
Member#: 856
2005 JDM STi
Oil fill is on the other side of the engine to the code sticker, you looking at something that isnt the engine code?
Old 10-10-2012, 02:13 PM   #4511
25rsti
Member#: 166324
Excuse me if I'm the only one getting confused by this. What the heck are you talking about when you say "Widetrack Blobeye"????? Did only Europe get this widetrack or Japan too?
Old 10-10-2012, 02:20 PM   #4512
johnfelstead
Member#: 856
2005 JDM STi
It was Japan and Europe.
The MY05 Widetrack Blobeye was the last model year before the Hawkeye, it has a wider track at the rear than the MY03/04, 114.3mm PCD hubs, 8x17 wheels, longer wheelbase which matches the spec C, later generation DCCD-A with Yaw and steering wheel position sensors.......
Easiest visual indication of the Widetrack car is the extra blisters fitted to the rear wheel arches, to accomodate the wider track and wider wheels.
Old 10-10-2012, 02:21 PM   #4513
todeswalzer
Member#: 191495
'05 WRB GTX3071R
I'd assume he means the equivalent to the usdm 05 sti, with the fender archers due to the wider track
Old 10-10-2012, 02:25 PM   #4514
PHruska
Member#: 214589
2002 wrx wagon
on the inside of the oil fill cap there is a stamp with the year the engine was produced.
my timing sticker says ej207dw5cr
Old 10-10-2012, 02:28 PM   #4515
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
I dont think so.
The MY03 that I have, has this intake sensor in the plenum below the throttlebody.
Old 10-10-2012, 02:36 PM   #4516
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
The model numbers are wrong for 05, they should have E in the description, for rev E, in the 4th designator of the code.
The table is still good, other than this.
Old 10-10-2012, 02:39 PM   #4517
johnfelstead
Member#: 856
2005 JDM STi
It's not homologated, i'll take a look at an MY03 Spec C engine at the weekend and see if the homologation sheet is wrong.
Old 10-10-2012, 02:50 PM   #4518
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
I dont think so.
John.. are we sure about this, cause my engine code is EJ207DW6CR (according to your list it's MY04):
And i do have this IAT sensor on the intake manifold (currently unplugged):
Torquey is offline   Reply With Quote
Old 10-10-2012, 02:51 PM   #4519
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
The sensor is there since rev C.
Old 10-10-2012, 02:53 PM   #4520
johnfelstead
Member#: 856
2005 JDM STi
Based on that i'd say the homologation sheet is wrong Torquey.
Old 10-10-2012, 03:10 PM   #4521
PHruska
Member#: 214589
2002 wrx wagon
trying to move pins on my ecu but the white locks at the top are stuck. dont want to destroy the clips. goddamn it.
Old 10-10-2012, 03:16 PM   #4522
azscooby
Member#: 115297
2002 ej207 vf34
My V8 EJ207DW5CR has the temp sensor in the plenum (right under throttle body) and the oil filler says 7/03..
I was under the impression mine was a model year 2003/2004.....?
John your new info would suggest mine is a model year 2005, since it has the temp sensor?
I find that confusing if not contradictory to what the date on my oil cap says, though of course its entirely possible its not an original cap.
azscooby is offline   Reply With Quote
Old 10-10-2012, 03:19 PM   #4523
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
small screw driver and force the locks up. only way to do it. then push them back down and if it make syou fell better put some tape around it or a zip tie. or both!
Old 10-10-2012, 03:19 PM   #4524
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
What A Cluster **** Of Three Pages Of Info!
Old 10-10-2012, 03:41 PM   #4525
todeswalzer
Member#: 191495
'05 WRB GTX3071R
Seriously.
