Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-07-2012, 04:56 PM   #1
purdyclevur
Member#: 288781
2004 Impreza WRX
Red
Default 04 WRX Engine Noise need help!!!
Check out this video:
Its a 2004 Subaru Impreza WRX 2.0L - Does anyone know what this ticking or knock could be? I think it could be something with the valves but I have no idea. Going to do a compression test and take the oil pan off to see what I can find and check the oil for shavings. Any other ideas on what I can check myself? It doesn't overheat and when it idles sometimes the ticking isn't near as loud. Hoping its not a problem with the pistons or engine block.
purdyclevur is offline   Reply With Quote
Old 10-07-2012, 09:33 PM   #2
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
I would be surprised if that was anything other than rod knock. Maybe a destroyed valve of some sort?
tebriel is offline   Reply With Quote
Old 10-07-2012, 09:46 PM   #3
Tech5000
Member#: 330575
05 Subaru WRX
Pearl Blue
Same thing happened to mine last week. Got the same exact noise! Your motor is toast.. Its Rod Knock. Spun Bearing.. Makes me wanna cry every time i hear it.
Tech5000 is offline   Reply With Quote
Old 10-10-2012, 05:19 PM   #4
Member#: 301037
2004 Forester XT
Yep it is a dead bearing. It was/is a common issue with the 2.0L. Sorry to hear that.
art@grimmspeed is offline   Reply With Quote
Old 10-11-2012, 12:08 PM   #5
kev29
Member#: 321425
2002 Impreza WRX
It can also be an idler or timing belt tensioner. Take off your timing belt cover to see if it gets louder or if you can see anything.
kev29 is offline   Reply With Quote
