Old 10-10-2012, 09:22 AM   #51
s2ktosti
Member#: 70151
2011 WRX Limited
Originally Posted by Howl View Post
I suspect what they meant was with winter tires you ideally want tires with a taller sidewalls. If he has 17" rims he probably should drop down to 16" rims for winter, if they'll clear the brakes.
Eh, then they'd still be wrong. You want tires that are narrower, not taller.
s2ktosti is offline   Reply With Quote
Old 10-10-2012, 09:25 AM   #52
Dale2011WRX
Member#: 304299
2011 WRX Sedan
My understanding is that you want narrower and taller. Narrower to cut through the snow and slush, and taller to give your wheels a little more protection (against potholes and curbs that you may not see as well in bad weather).
Old 10-10-2012, 10:00 AM   #53
s2ktosti
Member#: 70151
2011 WRX Limited
Got me there, doesn't help with traction which would be my main concern. Protecting a wheel is just a bonus.
Old 10-10-2012, 01:02 PM   #54
a2cpc
Member#: 10139
9&11 WRX 5Dr
DGM/Silver
I have the Blizzack on my wife's car and the AltiMax ARTIC on my car...last year we got 4 inches of snow!
a2cpc is offline   Reply With Quote
Old 10-10-2012, 02:01 PM   #55
MorganJ
Member#: 203823
2009 WRX STI
Originally Posted by FourOhFour View Post
Studs are useless on snow, worse than useless in the rain, and noisy as hell. The only plus is ice. Is enough of your driving on icy roads to warrant studs?
The roads are not very icy. It usually stays below freezing so very little melting and freezing. Roads are generally snow covered or partially covered.
Maybe I will skip the studs.
Ski season is almost here!
Hankook I Pikes any good for snow covered roads?
MorganJ is offline   Reply With Quote
Old 10-10-2012, 05:42 PM   #56
Howl
Member#: 57830
1999 OBS
^ what he said.
Howl is offline   Reply With Quote
Old 10-10-2012, 05:56 PM   #57
caperex09
Member#: 243122
for the OP, just get Dunlop wintersport 3D put on your wheels,
they are a great HP winter tire. they are not "mushy" if temps are up into the spring , and even summer season.
if you have 8+ inches of unplowed snow, nothing will help you get home.
caperex09 is offline   Reply With Quote
Old 10-10-2012, 10:24 PM   #58
MorganJ
Member#: 203823
2009 WRX STI
This will help
http://www.subaruforester.org/vbulle...w-plow-105756/
Old 10-10-2012, 11:36 PM   #59
OK Houston
we have an Uncle
d00000000000000000d
i guess you dont really understand how all this really works
for the same diameter tire.....you cant have narrower without the sidewalls being taller
Old 10-11-2012, 04:24 AM   #60
bugeye829
Member#: 81995
02 WRX Sedan
best all around winter tire imo are dunlop wintersport 3d. i've also had good experiences with michelin x-ice 2
bugeye829 is offline   Reply With Quote
Old 10-11-2012, 06:47 AM   #61
stop_rallytime
Member#: 225515
+1 on the dunlop I have had all others but they don't compare to the dunlop great traction in New England winters and they aren't super soft like witerforce
stop_rallytime is offline   Reply With Quote
Old 10-11-2012, 10:13 AM   #62
s2ktosti
Member#: 70151
2011 WRX Limited
d00000000000000000d
Thank you captain obvious, but still has nothing to do with my original statement. They didn't mention going to a narrower tire, they just mentioned a taller one. I'm the one who mentioned that ideally you want a narrower tire, it needing to being taller as a result is inconsequential to the original statement.
Time to put your E-penis away, no one wants to look at it.
Old 10-11-2012, 10:18 AM   #63
Dale2011WRX
Member#: 304299
2011 WRX Sedan
Old 10-11-2012, 11:02 AM   #64
Reebis
Member#: 126157
'01 2.5RS Coupe
BRP
Nokians if you have the money...Winterforce if you're on a budget.
/thread
Reebis is offline   Reply With Quote
Old 10-11-2012, 12:24 PM   #65
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
I got a link from a local newspaper in quebec ( sorry it's in French) and they evaluate the 15 best snow tire for the region. Mostly cold, lot of black ice and ton of snow.
http://auto.lapresse.ca/conseils/201...hiver-2013.php
They found the nokian Hakka 7 to be the best, followed by the x-ice 3 and the blizzak ws70.
This is for winter 2013, article went online yesterday
Syrius78 is offline   Reply With Quote
Old 10-11-2012, 12:47 PM   #66
OK Houston
we have an Uncle
sweetie....this is the idiot forum....just right for you
this is the best place for you and this question because the TECHNICAL forums that actually deal with this kind of thing are just WAY too complicated
stick around here with the rest of the short bus crew
Old 10-11-2012, 12:54 PM   #67
s2ktosti
Member#: 70151
2011 WRX Limited
Explains why you spend so much time here.
And you better buy me dinner before you start calling me sweetie...
Old 10-11-2012, 12:56 PM   #68
Dale2011WRX
Member#: 304299
2011 WRX Sedan
Scotty's got a lot of sweeties, he's kinda slutty.
Old 10-11-2012, 01:07 PM   #69
s2ktosti
Member#: 70151
2011 WRX Limited
I just added him to my ignore list. Though in hindsight I do find him humorous so maybe down the road I'll take him off it. Ok, probably not.
Old 10-11-2012, 01:58 PM   #70
schaffer
Member#: 277612
2005 WRX
Bought a 96 impreza to commute last year,before my wrx.needed something decent on gas but wanted something good in the snow. We got a total of 15 inches of snow all year.
schaffer is offline   Reply With Quote
Old 10-11-2012, 02:48 PM   #71
chapstien
Member#: 68284
2009 FXT Limited
obsidian black
Go to tirerack.com, enter your vehicle, pick each tire and look at the survey. There are ratings for different conditions.
If you plan on driving like a nut, you might want to look at performance winter tires. You only need studs if there is always snow on the road. They are dangerous on pavement and the **** it all up.
I don't know if it was mentioned, but you can buy tires mounted on steel wheels so you can just swap them, and you don;t have to take them somewhere to get mounted.
chapstien is offline   Reply With Quote
Old 10-11-2012, 05:41 PM   #72
Howl
Member#: 57830
1999 OBS
I case people aren't aware winter tires are MANDATORY BY LAW in Quebec.
oh and . . .
http://translate.google.ca/translate...hiver-2013.php
Old 10-11-2012, 07:51 PM   #73
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
oh and . . .
Mandatory yes, our winter is humid and very cold. Winter tire are a must. In the USA, I suppose it vary by region, so choose accordingly. Performance, snow, dry, slush, icy, noise. Pick the one that best fit your need and be happy.
The law is useful, a lot less accident, and less injury. Great law for our winter.
Old 10-11-2012, 07:58 PM   #74
fitrider82
Member#: 300855
2005 Subaru WRX STi
I have Dunlop Wintersport 3Ds and like them a lot, Michigan winters get pretty nasty.
fitrider82 is offline   Reply With Quote
Old 10-11-2012, 08:53 PM   #75
cmk82600
Member#: 248305
97 OBS
my custom mixed silver
I have used the Michelin X-ice, Peirelli winter carving, Firestone winter force ( only liked for deep snow, not on ice ), and Bridgestone blizzak 3 different models of these. all good tires and great in the winter my next set will be which ever is cheapest of them except the winter forces. Too much ice around here. Or maybe some Nokian Hakkapilettas if the price is right
cmk82600 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 07:12 PM.
