Old 10-10-2012, 10:50 AM   #1
MrTbrew8
Member#: 329811
Default Tire fitment question!!
I have a bone stock 2006 wrx, I was curious if these wheels and tires would fit without any complications
Tires- 235/40zr
Wheels- 18" rotas
MrTbrew8 is offline   Reply With Quote
Old 10-10-2012, 01:35 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Clearly, you've done your homework. They should fit fine, regardless of what wheel width or offset you choose. Those pieces of information are not at all important to wheel fitment.
Old 10-10-2012, 02:37 PM   #3
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
MD04WRX is offline   Reply With Quote
Old 10-10-2012, 02:40 PM   #4
MrTbrew8
Member#: 329811
Smartass
Old 10-10-2012, 02:42 PM   #5
MD04WRX
Member#: 72891
2014 Molten ST
235-40-18 tire
18x8.5 plus 48
No rubbing problems.
Old 10-10-2012, 04:39 PM   #6
sc00by4life
Member#: 97135
Originally Posted by MrTbrew8 View Post
Smartass
maybe you should thinking about including the actual pertinent information regarding fitment?
wheel diameter means nothing. literally.
tire size fitment depends on a combination of width and offset.
width alone means nothing.
offset alone means nothing.
Old 10-10-2012, 10:21 PM   #7
MrTbrew8
Member#: 329811
It's 9" wide with a 35 offset
Old 10-10-2012, 10:22 PM   #8
MrTbrew8
Member#: 329811
It's 9" wide and 35 offset
Old 10-10-2012, 10:50 PM   #9
MD04WRX
Member#: 72891
2014 Molten ST
If you want no complications then you need to stay with the 18x8.5 plus 48. 18x9 plus 35 will require mods.
Old 10-10-2012, 11:29 PM   #10
MrTbrew8
Member#: 329811
What kind of mods do you think? I've never heard about this offset stuff before I've always been into rock crawling an have never had to worry about it
Old 10-11-2012, 07:51 AM   #11
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
Negative camber all around, rolled rear fenders.
colin1234567 is offline   Reply With Quote
Old 04-09-2014, 03:18 AM   #12
LipDown_DiffUp
Member#: 373848
06 WREX
Obsidian Black Pearl
This is a bit of a rehash of an old thread but I've just started looking at modding my car and couldn't find the answer to my question. I have 06 WRX like the OP but I'm on stock rims and wanted to know if I could fit a 225/50R17 tire under my car without pulling fenders or excessive camber. I'd like to have a bit more side wall since as I understand it this will improve the ride quality (even at the expense of performance). I'm only using it as a DD so I'm not concerned with trying to track the thing until I can afford new rims and suspension. Or if someone has a link on how to measure tire fitment I could just break out a tape measure and figure it out myself. Thanks
LipDown_DiffUp is offline   Reply With Quote
Old 04-09-2014, 09:47 AM   #13
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
No do not do that. Your ride quality will absolutely not be improved by adding too tall of tires.
pDubs is offline   Reply With Quote
Old 04-09-2014, 01:33 PM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Originally Posted by LipDown_DiffUp View Post
This is a bit of a rehash of an old thread but I've just started looking at modding my car and couldn't find the answer to my question. I have 06 WRX like the OP but I'm on stock rims and wanted to know if I could fit a 225/50R17 tire under my car without pulling fenders or excessive camber. I'd like to have a bit more side wall since as I understand it this will improve the ride quality (even at the expense of performance and my speedometer reading wrong and my odometer tracking mileage incorrectly).
Added a bit to your statement there - performance probably won't suffer all that much, but other aspects of general use of the car will.
Taller sidewalls can change ride quality to some extent, so I don't agree with pDubs statement that it would "absolutely not" change. However, you'd be better off looking for a different type of tire in the correct size, as that's more likely to result in a noticeable change.
Just picking Bridgestone tires as an example, going from a 215/45-17 RE-11 to a 215/50-17 RE-11 might gain you a little bit more compliant ride, but going to a 215/45-17 RE760 or RE970AS would generate a bigger difference because the structure of the tire is fundamentally different.
http://www.rimsntires.com/specspro.jsp
Old 04-09-2014, 04:45 PM   #15
pDubs
Member#: 149317
'95 BMW M3 (E36)
Yeah I guess I should have clarified. He said having a bigger sidewall will "improve the ride quality". If we are referring to not feeling bumps and potholes as much then yes.
To me ride quality is a lot more than smoothness of driving. I'd rather have quality all around, and hurting performance doesn't create quality in my mind at all.
Old 04-09-2014, 09:52 PM   #16
yo vanilla
Member#: 71903
11 Audi A4 6MTQ
13 Mazda CX-5
besides any change in ride quality, adding diameter will throw off your speedometer a good bit, not to mention overall gearing
if you want a better ride quality, change the type of tire instead of the size. continental dws is a nice, compliant tire for instance.
yo vanilla is offline   Reply With Quote
