Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 09-18-2012, 06:35 PM   #1
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Default 2012 WRX - Stage 2 Data log analysis *11/11/2012 update*
See last post 9 for stage 2 + SF intak 93 v310 map runs
hello,
2012 WRX, Stage 1, 93 octane map.
i reviewed the top 5 monitors and everything is within spec. is there some place to get more in-depth analysis of the the other 10 monitors?
zip file is attached.
thanks in advance
-chet
ChesterWRX is offline   Reply With Quote
Old 09-19-2012, 09:25 AM   #2
Cobb Tuning
Member#: 4803
Originally Posted by ChesterWRX View Post
hello,
thanks in advance
-chet
Can you post your logs at google docs (if you do, be sure to set the permissions to public and convert the files to google docs' format)?
Bill
Old 09-19-2012, 10:05 AM   #3
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Old 09-20-2012, 10:19 AM   #4
Cobb Tuning
Member#: 4803
Hi Chet - logs all look good. Enjoy!
Old 09-20-2012, 12:48 PM   #5
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
thank you!
Old 10-10-2012, 11:29 AM   #6
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Old 10-10-2012, 02:22 PM   #7
Cobb Tuning
Member#: 4803
Also look good.
Bill
Old 10-11-2012, 10:08 AM   #8
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
cool! thanks.
Old 10-31-2012, 08:12 PM   #9
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
went kinda Stage 2
Cobb SF Intake w/ box
Cobb Catted Downpipe
*still waiting on gaskets for my Invidia Q300 CBE (got used).
https://docs.google.com/spreadsheet/...1dJdVNWWWlwZlE
https://docs.google.com/spreadsheet/...01kMFM1SzlYSkE
https://docs.google.com/spreadsheet/...zVqQmY4U1lQSGc
https://docs.google.com/spreadsheet/...U9NaFE3d212c1E
https://docs.google.com/spreadsheet/...1BZbzY4b3ZuZ2c
https://docs.google.com/spreadsheet/...ktxUll3OWZ6M3c
ETA: don't mind the conditional formatting. it's set for stage 1 on the boost. gotta adjust next
Old 11-01-2012, 07:29 AM   #10
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Old 11-01-2012, 09:34 AM   #11
Cobb Tuning
Member#: 4803
went kinda Stage 2
Your boost is borderline high. Given that you still have a the stock catback, I would go ahead and reflash the low wastegate (LWG) version of your map as you may see even higher boost with aftermarket catback.
Bill
Old 11-01-2012, 06:29 PM   #12
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Bill
thank you as always.
i'll try to get a couple more logs.
here is one with the LWG map.
https://docs.google.com/spreadsheet/...EtENGpzVGktTXc
-chet
Old 11-02-2012, 11:13 AM   #13
Cobb Tuning
Member#: 4803
-chet
Boost control looks better. You do have some consistent minor knock even in this log. What gas brand are you using? Most have the best luck with the so-called "top tier" gas brands.
Bill
Old 11-02-2012, 03:54 PM   #14
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
hi Bill, i filled up with Sunoco (i think) last time.
i use 93 octane from the same 2 or 3 gas stations. i'm just below a 1/2 tank so maybe i'll fill up with some 94 over the weekend and try to take a few more logs.
much appreciated. i have the full TBE set up now - Cobb DP, Invidia Q300 CBE
Old 11-11-2012, 09:11 PM   #15
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
ok, since the initial logs (overboosting) i've had the cat-back on and removed, so i can't even honestly tell you which exhaust was on the car.
it's the same gas that was in there though. i'm down to a 1/4 and will fill up soon. ****! but i'm seeing the same knocking in a WOT and over boosting.
i have some computers issues i'm working through (yes, both my computers), but finally pulled these off the AP to my desktop.
i'm not even going to pretend that i know, but i'm just looking at the top 5 and what the tolerances are... as you can see, some of these were in a WOT in 3rd, while some were just cruising around.
so i'm pretty sure i took them with the Q300 installed. i can get more logs after a fill up.
so my question is: it appears to be "safe" to drive around as long as i'm not in a WOT taking logs, yes?
the map is still the LWG map, Stage 2+intake - 93 octane. I have a cobb catted downpipe still, Cobb SF intake. no other mods.
i didn't realize i had so manny, i just bring the AP with me just in case an opportunity arises.
https://docs.google.com/spreadsheet/...GVXc01rdUxlWEE
https://docs.google.com/spreadsheet/...zlRTTVKQlhsemc
https://docs.google.com/spreadsheet/...U9tck9jYmZzeGc
https://docs.google.com/spreadsheet/...1BJaThTTzVuZWc
https://docs.google.com/spreadsheet/...2JRYjVwaXQ5MFE
https://docs.google.com/spreadsheet/...zZQcy1XTEpQS1E
https://docs.google.com/spreadsheet/...mRQYzVoTjY5UGc
https://docs.google.com/spreadsheet/...ldQTFVLM0xLWWc
Old 11-11-2012, 09:18 PM   #16
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Bill
the knock looks worse.
i'll get some gas in there and redo. thinking about this more, i'm pretty sure they were taken with the q300 on. but it's back off (too loud).
the minor knocking looks worse on the other logs.
Old 11-12-2012, 10:20 AM   #17
Cobb Tuning
Member#: 4803
You'll want to move to a more conservative map. Let's try the 91ACN version of your map. There is a severe low wastegate (SLWG) version of the map you can download from the maps section at cobbtuning.com. Add the "Knock Sum..." values to your log list for future logs.
You also have some borderline extreme fuel trims. Could be nothing, but on a car this new, it could be an intake tract leak. I would get a pressure/smoke test of the intake tract done. There have been examples of leaks on these cars from the factory.
Bill
Old 11-13-2012, 06:30 PM   #18
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
oh crap, i just realized i switched to the wrong map. these logs were taken with the Stage 2 + SF 91 CRAP CRAP CRAP. well, just in case they are usefull. this is on a full tank of Sunnoco 93 and the logs werent good anyway. ETA: just to be clear, this was the Stage 2 91 SLWG map.
https://docs.google.com/spreadsheet/...kxKMmxITWM2ZkE
https://docs.google.com/spreadsheet/...TVNOUF1Rl93ZkE
https://docs.google.com/spreadsheet/...XUzVTdMXzZvamc
Old 11-14-2012, 10:16 AM   #19
Cobb Tuning
Member#: 4803
I would go ahead and reflash the 91 ACN map for now. Make sure you are not using an ethanol-free gas, which will typically reduce knock resistance compared to the typical E10 gas.
Bill
Old 11-14-2012, 04:19 PM   #20
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Old 11-15-2012, 08:22 AM   #21
Cobb Tuning
Member#: 4803
The SLWG map was a little too much and you are underboosting now. 91/91ACN maps have different boost targets than 93, so in this case the LWG version looks to be more appropriate, so I would go ahead and reflash the LWG 91ACN and get some additional logs. Otherwise, nothing out the ordinary in your logs.
Bill
Old 11-15-2012, 08:36 AM   #22
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Thanks bill,
