Old 10-10-2012, 07:55 AM   #26
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
I know you wanna do it, but I'm with scotty. Changing your suspension out every few months is gonna get old real quick.
chazly413 is offline   Reply With Quote
Old 10-11-2012, 10:52 AM   #27
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
That's the truth... but installing/removing spacers and getting an alignment is pretty simple when/if you think about it...
Having a spare suspension would be just as easy, but more expensive...
It's just a matter of what the OP wants..
We are here but to prvide options and opinion on those options...
Old 10-11-2012, 10:58 AM   #28
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
thank you. I just bought a full swap coil over strut setup from a 2010 forester xt. Only takes about 45 minutes to swap all four corners.
Black07STiGuy is offline   Reply With Quote
Old 10-11-2012, 10:59 AM   #29
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Perfect... and when well versed with suspension stuff... quick!
Old 10-11-2012, 11:01 AM   #30
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
Huh???
Old 10-11-2012, 11:11 AM   #31
gsrcrxsi
Member#: 236952
2010 WRX
Spark Silver
You will not be able to just swap the forester coil assembly over and leave it at that. It will give you something like 4" of lift. This will pull your rear wheels forward because of the short trailing arm and likely into the wheel well. I don't think you want that much lift.
See this thread. http://www.dirtyimpreza.com/forums/s...ad.php?t=18978
gsrcrxsi is online now   Reply With Quote
Old 10-11-2012, 12:31 PM   #32
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
I saw this the other day. I wonder if the hatch has different mounting angles because my rears didn't pull forward like that.
Old 10-11-2012, 01:39 PM   #33
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Originally Posted by Black07STiGuy View Post
Huh???
Perfect soulition and quick swap..
Old 10-11-2012, 01:47 PM   #34
sc00by4life
Member#: 97135
the trailing arms are actually identical between the forester and impreza, the difference is the brackets/subframe spacers on the foz.
the easy fix for this problem is just getting foz struts with stock impreza springs.
Message Board Statistics All times are GMT -4. The time now is 08:49 PM.
