Old 10-09-2012, 07:25 PM   #1
93GC8AWD
Member#: 245268
1993 Impreza L Wagon
Default Little Help With My Lego Swap
I have recently purchased a 92 legacy ss. I'm pulling the motor for a rebuild. But before I start, I was going to keep things simple and use a set of 2.5 dohc heads and a td04 turbo. Should I purchase a 2.5 dohc timing kit? I'm honestly only looking for around 250-300 HP.
93GC8AWD is offline   Reply With Quote
Old 10-11-2012, 05:42 PM   #2
DohcEj22e
Member#: 289011
Yes, you must purchase the EJ25D timing kit since you have pretty much adopted that setup when you converted to DOHC heads. Make sure you use the 97-99 EJ25D heads as their chambers are well enclosed in the EJ22T bores.
Also, the passenger side head must be tapped for the turbo & since you're converting from single to DOHC, you may as well get an 11mm STi oil pump (to compensate for the increased room in the heads) & a new turbo water pump as well as new tensioner & timing belt pulleys.
Set the timing as you would an EJ25D & it will start right up. The crank pulley, crank, & cam sensors will be the same & your ECU will run those heads. You WILL have a decreased compression ratio though but that will allow you more room for boost.
DohcEj22e is offline   Reply With Quote
