Old 04-24-2012, 09:00 PM   #126
C J
Member#: 132587
2006 JrTuned STi
[email protected]
was it dying?
C J is offline   Reply With Quote
Old 04-24-2012, 09:20 PM   #127
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Originally Posted by C J
was it dying?
Oh ya. I got stuck on the side of the road quite a few times
mecpgh is offline   Reply With Quote
Old 04-24-2012, 09:45 PM   #128
C J
Member#: 132587
2006 JrTuned STi
[email protected]
wow, sounds identical to what I am dealing with. Hope it is something I can get sorted out quickly when I get some time.
Old 04-25-2012, 04:40 AM   #129
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Ya the worst part is that when it stalls it floods the engine so it won't restart for atleast 20_30 min. Blows big time needless to say I dont drive it to work any more just incase.
I have tried everything I can think of to get it cleared out in a timely fashion but nothing works. And I think it's partially due to my plugs being gaped so tight
Old 04-25-2012, 04:41 AM   #130
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Oh and I run copper plugs not a normal plug for these cars
Old 04-25-2012, 08:12 PM   #131
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Yeah my car does not want to restart until I give it a few minutes. Almost thought I swapped a carb on it and have to let it clear out haha.
Old 04-25-2012, 08:59 PM   #132
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Yes not cool at all I've been stuck at red lights and cops roll up and everything
Old 04-25-2012, 09:33 PM   #133
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Damn that would suck, mine hasn't been that hard to restart.
Old 04-25-2012, 09:35 PM   #134
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Ya like I said I'm pretty sure alot of it is the plugs
Old 04-25-2012, 11:43 PM   #135
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Running and not dying!
Increased the latency quite a lot from what they recommend and still need to increase it some more but it idles/cruises/returns to idle without dying.
Runs pretty rough when returning to idle but recovers.
Old 04-26-2012, 04:44 AM   #136
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Good to hear
Old 04-26-2012, 07:35 AM   #137
Ohhey1
Member#: 260297
2006 STI White
HTA Green Methanol
Do the Deatschwerks 1100cc side feeds have as many problems at Five-0's 1200cc side feeds? The Deatschwerks cost twice as much.
Ohhey1 is offline   Reply With Quote
Old 04-26-2012, 08:03 AM   #138
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
it's big side feeds in general that arent reccomended
Old 05-02-2012, 05:37 PM   #139
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Originally Posted by fastblueufo View Post
I want to bump this thread. I have been tuning a car with side feed 1200cc for the past few days. I just want to say that these injectors SUCK!. And that is putting it lightly. The fueling is all over the place at idle. The fuel corrections will be flat one minute then out of nowhere the afr will shoot rich and corrections swing wide. That may last a few seconds then back to normal for a while. But corrections still arnt what I would call acceptable.
As for idle control. SUCK! You can stop at a light and idle corrections are ok, stop at the next light and corrections will be -25. Next light they may be ok again. System voltage is stable, maf voltage is stable, map, all the data is correct and nothing to cause this behavior.
I would not recommend these injectors to any customer or client to install on there car.
That's pretty much where I am at with these same injectors. Once second they're at -25, then +25, and shortly after back to -25. I've played with these for a few days now and I think I'm done trying to work with them. I've gone high enough in latency that the ECU couldn't command a smaller PW, back it off and then it's back to being all over the place.
yamahaSHO is offline   Reply With Quote
Old 05-02-2012, 10:03 PM   #140
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Moral of the story: side feed fiveo's are poop. My 1600 top feeds are still fine but eventually I'll get some id2000's.
06rexwagon is offline   Reply With Quote
Old 05-03-2012, 01:47 PM   #141
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
The injectors are garbage. I've tuned many dw large side feeds without issue. The owner of the car I refered to with these injectors ended up buying a top feed conversion kit with id1000cc injectors and he can't be happier. Here is a link to his turbo upgrade with injectors.
http://www.mysubie.com/forums/viewtopic?id=4804
fastblueufo is offline   Reply With Quote
Old 05-03-2012, 03:41 PM   #142
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
dw's biggest sidefeed is 1100....unless people are getting custom ones made.
so its 10% less flow which is helping out.
i just dont think running a sidefeed >850cc is a good idea. bigger than that should be converted to topfeed.
Old 05-05-2012, 08:35 PM   #143
reid-o
Member#: 103631
2004 STI
http://www.witchhunter.com/subarumod1.php4
If you read the bottom it explains a lot.
Old 05-07-2012, 07:15 AM   #144
fastblueufo
Member#: 212154
02 billet crank
Thanks for that post. That explains everything about why the five-o side feeds don't work properly. Sorry for all the guys that got sucker'd into buyings these from five-o motorsports. They know they suck yet still keep selling these.
Old 05-07-2012, 10:00 AM   #145
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Those are actually the PE Injectors, not quite the same thing, is it?
TyranosaurusWRX is offline   Reply With Quote
Old 05-07-2012, 01:29 PM   #146
reid-o
Member#: 103631
2004 STI
They're based on the same core, I would think. I don't think PE makes the injectors, for example. They take a core and mod them. Since PE is doing the modification, they're branded as PE injectors. But only several companies actually make injectors.
Old 05-07-2012, 01:32 PM   #147
reid-o
Member#: 103631
2004 STI
I have to say that my AEM is doing a pretty good job of holding 14.7:1 on pump without misfires, and I have the 1200s side feeds. The latencies were WAY off though. I'm running something like 1.2 ms at 14v. If the site is correct though, I should measure the resistance between injectors and then it looks like the flow may change over time. I couldn't get them running on the stock ECU however. I had every problem listed in this thread.
Old 05-07-2012, 04:30 PM   #148
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Ya stock ecu closed loop is too sensitive, my car is super smooth in open loop @ idle, same concept with aem
Old 10-11-2012, 06:28 PM   #149
wrxkyle
Member#: 199635
02-4 rSTI
i second this. my car has run much better after converting, still a pain to do the conversion though. dont get the black 1200 topfeeds, that look like injector dynamics ones, they are too short, they still seal on the rail but i suspect them not sealing at the tgv as there is no clamping force down on them, they leave 1/8-1/4" room to slide up and down in the rails, i posted pics in a thread i think somewhere here.
also, agreed, ron is a tuning wizard, we ran out of fuel and decided to hold off, and now i'm looking at a different turbo with better spool anyway lol. life...
wrxkyle is offline   Reply With Quote
Old 08-23-2014, 09:23 AM   #150
oscar1407
Member#: 397651
Hey guys
Got a set of 1200cc sidefeeds a while ago been trying to tune them in ever since i just cant get the afr to stand steady at idle misfires are not the issue its whenever electrical load is added or subtracted the afr swings ~1.0
I have tried messing with the latency tables but cant seem to steady it out is there any other table i should be looking at or should i keep experimenting with the latency figures
oscar1407 is offline   Reply With Quote
Five O Motorsports Injectors apsdsmracer Car Part Reviews 185 02-26-2016 12:48 AM
The 2.0 vf34 that did, now a built 2.0/2.5? hta green on e85 karlknaupp Proven Power Bragging 684 06-30-2015 08:20 AM
555 Motorsports June Tuning Trip (June 19-22) Benchmark Tuning MWSOC Vendor Classifieds 35 07-14-2008 10:21 PM
555 Motorsports Chicago Tuning Trip & Dyno Day #'s Benchmark Tuning Proven Power Bragging 11 07-13-2008 01:48 PM
Primitive Motorsports/Cobb Tuning/JC Sports??? Kevin Thomas General Forum Archive 24 10-01-2000 06:54 PM
