Old 12-13-2011, 05:29 PM   #251
IHaveADream
Member#: 303385
Simply brilliant. Great resource. Thanks so much!
IHaveADream is offline   Reply With Quote
Old 04-01-2012, 04:07 AM   #252
Jaymansomething
Member#: 301189
In for later read
Jaymansomething is offline   Reply With Quote
Old 04-27-2012, 02:46 AM   #253
sleazy07sti
Member#: 273116
2007 Hawkeye Sti
0bp
Hey bro quick question.I'm currently running a tial 50mm bov that is not welded to my fmic pipe.it is held on with a tmic flange thay bolts to a fmic flange ,two clamps and a silicone tube between them.I purchased it from a nasioc member who from what I Belive had a 14psi spring and I was getting nothing but surge.everyone told me that this is how it was suppose to should so I drove on it for 2-3mnths.so today I purchase a 11psi(pink) spring as I'm running -17 to -21 in vac at idel but I'm still getting the surge.could this be because it is not welded to my pipe and I'm leaking like crazy or should a try a 10 or 12 psi spring?
sleazy07sti is offline   Reply With Quote
Old 04-27-2012, 03:15 AM   #254
DaveC113
Member#: 126901
2010 WRX 5 Door
Originally Posted by boost-o-matic View Post
In light of the fact that it sounds as though the part has changed for the '08+ WRX's, here's my ?
I have a 2010 WRX and am being told that the OEM BPV or BOV(whatever your preference) leaks at around 17-18 psi. Is this true? Looking to get my car custom tuned soon and want to know if I need to upgrade this part or not prior to tuning. Also need to determine if running the OEM intercooler on my 2010 is going to be okay at 18-19psi. Hearing stuff about the plastic endtanks not withstanding boost much beyond 18psi. I don't ever plan on running high boost(race fuel), but do want to have a 93 octane map made which will wiststand an additional psi over 91 octane. I will be daily driving on 91. Don't really want to spend another $850 upgrading the BOV and i/c as I'm planning to keep the stock turbo, but just add things like EL headers, up-pipe, intake and EBCS to compliment my TBE and AP.
Anyone pressure tested the OEM BOV in the '08+ to see where it starts leaking? Did this on the eclipse I used to have and the OEM unit held to 23 psi. I gave a way my turbo pressure tester with the last car when i sold it. Guess I could always make another one.
I have exactly the same question, same car, same mods... don't want to waste $175 on a new bpv if I don't have to... anyone?
DaveC113 is offline   Reply With Quote
Old 05-03-2012, 03:33 PM   #255
twinturbomeow
Member#: 315546
03 wrx
nvm11
twinturbomeow is offline   Reply With Quote
Old 07-30-2012, 11:53 AM   #256
Nathan_troy1983
Member#: 327606
2012 Subaru
Dark Grey Metallic
Great post, I am so glad that I am reading before buying any of these parts.
Nathan_troy1983 is offline   Reply With Quote
Old 08-10-2012, 10:08 AM   #257
eXploited_GR
Member#: 309298
2008 STI
Need some help..
I have a 2008 STI and my By-Pass valve has a crack in the elbow where the hose connects... and I need to get a new one ASAP.. But I cannot find one in stock anywhere...
What are my options as to what will fit? Any WRX BPV??
eXploited_GR is offline   Reply With Quote
Old 08-10-2012, 05:59 PM   #258
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Originally Posted by eXploited_GR
Need some help..
So the elbow is cracked and not the bov? Just get a WRX one (pre 2008) and it'll bolt to your bpv.
jay25RS is offline   Reply With Quote
Old 09-07-2012, 06:27 PM   #259
Meech3k
Member#: 319622
09 Sti
Thanks for all the FAQs. I read a couple of your threads already, answering my questions and ones I wouldn't think of. Good ****!
Meech3k is offline   Reply With Quote
Old 09-24-2012, 08:08 PM   #260
cjkarling
Member#: 307627
Have the OEM BPVs changed over the years? Yes. 08+ Subarus have a BPV that is plastic. So if you for some reason you have a plastic BPV, it will not hold as much boost as the old metal ones. The plastic ones will only hold ~17PSI give or take.
I have a 2012 WRX stage 2 pumping out 19.5 PSI. Is my plastic BPV leaking?
cjkarling is offline   Reply With Quote
Old 09-24-2012, 08:09 PM   #261
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
no .
WRB19 is offline   Reply With Quote
Old 09-24-2012, 09:17 PM   #262
cjkarling
Member#: 307627
How can you tell if it is?
BTW; This is my second WRX, I have a 2003 Bugeye that was stage one, I knew a lot of this stuff, but I have been out of the game for about 8 years.
Old 10-11-2012, 07:33 PM   #263
Fail Puff
Member#: 305738
Originally Posted by Unabomber View Post
No. You need to read the post again. BPV/BOV that 100% recirculates = 100% fine. Anything else = rich.
sorry but i am confuse.. so if i get this then i wont be running rich? http://www.importimageracing.com/for...7-wrx-sti.html coz it said its 100% venting D:
Fail Puff is offline   Reply With Quote
Old 10-11-2012, 07:36 PM   #264
the suicidal eggroll
Member#: 51961
2005 STi
Does it recirculate? No, therefore it is not fine to run, and will make the car run rich.
Old 10-11-2012, 08:46 PM   #265
Fail Puff
Member#: 305738
so..all BOV will run rich then D:
Old 10-11-2012, 08:53 PM   #266
Fail Puff
Member#: 305738
what if i get it tune?
Old 10-11-2012, 08:56 PM   #267
Member#: 51961
2005 STi
Yes
You can't tune for an atmospheric BOV
Old 10-11-2012, 09:03 PM   #268
Fail Puff
Member#: 305738
ohhh ok but regular ones i can yeah?
Old 10-11-2012, 09:06 PM   #269
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
If it's an aftermarket BOV that recircs 100% back into the intake, it'll be essentially the same as the stock BPV tuning wise.
brett192 is offline   Reply With Quote
Old 10-11-2012, 09:10 PM   #270
Fail Puff
Member#: 305738
so its tuneable! D: lol well if its pretty much the samething as BPV then its good!?
Old 10-11-2012, 09:11 PM   #271
Member#: 51961
2005 STi
What? I think you need to go back and read a bit. Start here:
http://forums.nasioc.com/forums/show....php?t=2339839
If by "regular ones" you mean recirculating bypass valves (BPV), then there is nothing to tune for, because they work exactly like stock.
Old 10-11-2012, 09:11 PM   #272
Member#: 51961
2005 STi
What on earth are you going on about?
Old 10-11-2012, 11:25 PM   #273
sc00by4life
Member#: 97135
No....you can't. People are confusing a BOV with a BPV.
You cannot tune for an atmospheric BOV.
Old 10-11-2012, 11:45 PM   #274
rocketperson7
Member#: 283968
MBP
unless it's speed density
:stirpot:
Old 10-11-2012, 11:47 PM   #275
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Yes
Why isn't it tuneable ? I was always under the impression you can drop the fuel tables to control the amount of fuel and air pumped in through the car to safely get away from the half second rich moment after spool ?
tjmmason93 is offline   Reply With Quote
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 10:03 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 111 06-11-2016 09:28 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
