Old 10-10-2012, 10:26 AM   #1
truwrxtacy
Member#: 84786
2011 STi
Default how to tell if there is knock using AP?
Hey guys last night I went to fill my gas tank. But I was being a dumbass and spacing out and started putting I'm 85 into my sti which is ots stage 2 ap. Well by the time I realized it there was already 10 gallons in it. I then filled it up with 4 gallons of 91. Right now I'm just babying the car, shifting before 3000 rpm and riding intelligent mode.
Now I have an AP, is there anyway I can check knock on the car using live data logger?
truwrxtacy is offline   Reply With Quote
Old 10-10-2012, 11:12 AM   #2
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Maybe a better option would be to buy a $5 pump, a $10 gas tank, and get to work. :-\
Old 10-10-2012, 11:14 AM   #3
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
I wouldnt risk it. Why make one mistake, then make another? One bad knock can damage your engine, but by then its too late. Just find somebody that needs a fill up and drain yours out. A 60 dollar mistake doesnt have to cost thousands.
slowgenius is offline   Reply With Quote
Old 10-10-2012, 11:15 AM   #4
the suicidal eggroll
Member#: 51961
2005 STi
Look at dynamic advance multiplier, feedback knock correction, and fine learning knock correction. DAM you want to be 1, the others zero.
Old 10-10-2012, 11:28 AM   #5
NoGraffix
Member#: 276209
I am Rub
Function>Form
I'd either:
A: drive out of boost until you have refilled the tank with the correct octane
or
B: empty the tank of gas and refill with correct octane
These car's can be driven on 87 octane gas, but the potential for a knock event under boost is much greater.
NoGraffix is offline   Reply With Quote
Old 10-10-2012, 01:28 PM   #6
Cobb Tuning
Member#: 4803
I would reflash the economy mode map that can be found in the maps section at cobbtuning.com. This will disable boost control which will minimize boost levels. Additionally, you should drive conservatively and try to stay out boost as much as possible. Run the tank down as much as you can before filling up with 91 again. If you follow these steps, you should be fine.
Bill
Old 10-10-2012, 01:32 PM   #7
truwrxtacy
Member#: 84786
2011 STi
Thx guys. Someone told me to put about 2 - 3 gallons of e85 in it and it should help with the octane. Can someone please confirm this?
Old 10-10-2012, 02:45 PM   #8
Cobb Tuning
Member#: 4803
I wouldn't attempt to try to mitigate any knock by filling up partially with E85. Just run through this tank by driving conservatively and you'll be fine.
Bill
Old 10-10-2012, 04:00 PM   #9
truwrxtacy
Member#: 84786
2011 STi
Okay thanks for the info. Ill baby it more than usual lol. The intelligent mode is basically low Boost settings right?
Old 10-11-2012, 08:52 AM   #10
Cobb Tuning
Member#: 4803
If you are using a boost select map, then intelligent will be a lower boost mode (although more boost than running the economy map). Keep in mind that if you go wide open throttle (WOT) for a few seconds in intelligent mode, it will switch to sport mapping (and therefore boost levels with boost select). But, given your circumstances, you shouldn't be going anywhere near WOT.
Bill
Old 10-11-2012, 12:02 PM   #11
truwrxtacy
Member#: 84786
2011 STi
K ya I'm running the intellignt mode. And I'm shifting at or below 2500 rpm. Thanks for the advice guys
Old 10-11-2012, 08:21 PM   #12
hutch959
Member#: 267463
plug in your ap and put it on the feedback knock and just keep an eye on it while your driving around. that way you can see if anything is going on.
hutch959 is offline   Reply With Quote
Old 10-11-2012, 08:24 PM   #13
Member#: 51961
2005 STi
feedback knock correction is just one of the three methods of knock correction on the ECU. It won't tell you the whole story by itself.
