Old 09-28-2012, 01:38 PM   #151
stretchedk7
Member#: 170602
06 Wrx 6Spd TSBorg
Warner S400-Aem-2200s
Actually it appears there's issues with block.
I'm wetarded.
My guess is cracked sleeve, scarred sleeve, or something got into bore and made grooves.
Old 09-28-2012, 02:01 PM   #152
baseballdbk1
Member#: 242700
2011 Impreza Wrx Sti
Originally Posted by stretchedk7
Oh as far as I know the block was ok. I think he might have had a 704 casting and that brought on the discussion.
I could be wrong though haven't been following lately. More or less in to see what she makes and what boost it takes and that sorta stuff myself.
I will discuss more information in the very near future about what the problem really is but plain and simple...
NOT A SLEEVE ISSUE! :-)
baseballdbk1 is offline   Reply With Quote
Old 09-28-2012, 05:36 PM   #153
stretchedk7
Member#: 170602
06 Wrx 6Spd TSBorg
Well that's good!! ^ I've never once had a sleeve issue. They aren't as weak as some ppl think.
P and l- multiple 35 psi cars on them lol.
Old 10-03-2012, 11:44 AM   #154
baseballdbk1
Member#: 242700
Just a minor update...
Still waiting to here updates on the engine so unfortunately I have no update on that end lol
However, as I said earlier in the thread my car is going on a diet and one of the first pieces of the puzzle arrived today from Josh @ IIR!
Old 10-03-2012, 12:45 PM   #155
Shortpersonbk
Member#: 319017
2005 SAABARU 18g xt
JDM 6 speed
love the build...makes me feel depressed that you are building this monster changing everything when everytime i go WOT i have that lingering thought waiting for my 2012 sti stg 2 to explode lol....15,000 miles so good :S
Shortpersonbk is offline   Reply With Quote
Old 10-03-2012, 07:27 PM   #156
baseballdbk1
Member#: 242700
Haha Thank you!
If it ever blows up, build a nice shortblock, rotated 30r and leave it alone lol
Going fast is the biggest rush imaginable but it comes with a price, that even I was not anticipating when I started this build but I'm addicted and can't stop
Old 10-03-2012, 07:39 PM   #157
baseballdbk1
Member#: 242700
Well... Finally some engine news!!!
Just got off the phone with Nate and the engine will be back up in running in no time!
What had happen was... WE MADE TO MUCH DAMN POWER!!!
The OEM case bolts were not up to the task of holding the case together which caused the mains to go .005 out do to it stretching and the crank moving back and forth but is being fixed by the machine and we are going to refresh with new bearings all around, new piston rings, ARP case bolts and recheck all clearances so we can hit the 600 mark before taking it to MIR to wreck house!
Heads are already completed as well so once the shortblock is back together, we will use ARP L19 headstuds to make the heads dont separate from the block and make some F**king jam!!!
Old 10-04-2012, 07:09 AM   #158
Shortpersonbk
Member#: 319017
2005 SAABARU 18g xt
JDM 6 speed
NICE hope it works out
Old 10-11-2012, 08:25 PM   #159
baseballdbk1
Member#: 242700
Progress continues to be made...
The engine should be back in the sti this upcoming week and will be getting around to the fuel system, which I will def taking pictures of to show how we set it up ;-) Things are falling into place and cant wait to get back to the track!
On a fun note, my good friend Dave who holds the Evo stock longblock/turbo record going 10.51 @ 127mph last year stopped by TPG Tuning and snapped a pretty nice photo of his evo, my sti, and a customers sti that made me smile while I was sitting in class
Here is a link to Dave's record setting run:
Old 10-11-2012, 09:38 PM   #160
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
What rims are on that evo?
Old 10-11-2012, 11:40 PM   #161
baseballdbk1
Member#: 242700
TR Motorsport wheels
Old 10-11-2012, 11:45 PM   #162
baseballdbk1
Member#: 242700
Justin's Powdercoating just let me know that my ceramic coated turbine housing, exhaust manifold and up-pipe will be shipping back to me tomorrow...
And damn do they look good!!!
Old 10-30-2012, 02:57 PM   #163
baseballdbk1
Member#: 242700
ENGINE UPDATE!
Dividing into 2 sections: Block & Heads
SHORTBLOCK UPDATE:
Well to start things off, this has been a huge learning experience for myself and there has been a lot of work done to make sure we can make the power this setup is capable of and hopefully someone can take something away from my experiences through this very involved build :-) On to the info!!!
As those of you that have followed the build thread so far, the engine experienced a failure that involved one of the intake camshafts grinding through a bucket which then broke a valve stem and locked the valve in the open position loosing compression...
After finding this out seeing the metal pieces throughout the engine, we decided to tear down the shortblock as well to make sure nothing got damaged and be cleaned...
After tearing it apart we found a few problems with the block:
1. The block mains were stretched out .005"
2. The connecting rod bushing were extruding from the rod
3. The wrist pins were slightly bent
The use of the OEM case bolts caused the case to stretch and try to separate but probably the most interesting things were the bushings being pushed out of the rods and the bent wrist pins but I guess the head failure was somewhat of a blessing because we were able to fix the problems before something more serious would happen
Another thing that I became aware of was that I am in-fact using a 704 casing but bcz of time I had the block build, I was almost positive that I was using a 703 casing but thankfully after almost 8k miles on this block, the stock sleeves look brand new with no signs of abnormal wearing or cracks through the inspection, testing and reassembly process that I will cover next!
After finding this out, we took the following steps:
1. Machined the block halves and line main hone with upgraded ARP case bolts
2. Install new main bearings w/ clearances ranging between .0026 & .0028'
3. Install new rod bearings w/ clearances ranging between .0023 & .0024"
4. Honed connecting rods & installed new "classified" high quality bronze connecting rod bushings
5. Installed new CP piston ring set
6. Installed upgraded CP "Tool Steel" wrist pins(These are not the same type of wrist pins that came with my pistons)
7. Fresh cylinder hone using torque plate and ARP L19 head studs
8. Fully balanced rotating assembly
Now this all of these issues addressed the shortblock is ready to be installed and attached to the heads which I will put an update about shortly!!!
Old 10-30-2012, 05:48 PM   #164
JSti07
Member#: 190019
07 STi
swp
Glad you got it all figured out! Can't wait to come down and check the car out
JSti07 is offline   Reply With Quote
Old 10-30-2012, 10:47 PM   #165
baseballdbk1
Member#: 242700
ENGINE UPDATE!
HEADS UPDATE:
Alright, on to the heads...
As I stated previously in other posts, the setup I was previously running has been changed greatly after an intake camshaft lobe from my Kelford 220-C was ground down and made its way through my bucket, broke off the valve stem, put a small crack in the head and sent metal everywhere which was amazing to see when disassembling the longblock
I guess the worst part of this failure is that we can not clearly determine the cause of the failure but oh well and time to rebuild!!!
Changes/Settings:
Installed Ferrea "Drag Racing" dual valve springs, seat locators, titanium retainers, lockers
and seals
Installed Ferrea Competition Plus 1mm+ intake & exhaust valves
Installed new valve seats
Installed/clearanced Kelford 220-D camshafts(min. clearance .0060")
Stick-welded the crack inside of the heads
Roughen up intake ports to fix very slight fuel puddling for better atomization
Super-Flow flow bench tested= 340CFM
Valve spring seat pressure= 90lbs
Valve spring open pressure= 315lbs
Net valve lift:
Intake= 11.55mm
Exhaust= 11.00mm
Coming Together Nicely!!!
Tight Clearances FTW!
Awesome Intake Port Work
New Valve Seats!
Exhaust Port-n-Polish
Crack Repaired With Stick-Weld
Old 10-31-2012, 09:39 AM   #166
stretchedk7
Member#: 170602
06 Wrx 6Spd TSBorg
its looking great man keep it going! cant wait to see it run
Old 10-31-2012, 11:09 AM   #167
baseballdbk1
Member#: 242700
Thanks Jeff!
You better stop by the shop asap!
Old 10-31-2012, 11:53 AM   #168
baseballdbk1
Member#: 242700
Thank you!
It has been a crazy last couple months but so happy to be having things come back together
Old 10-31-2012, 01:07 PM   #169
baseballdbk1
Member#: 242700
Driving to pick up engine and assembling at TPG tonight! So pumped!
Old 10-31-2012, 01:32 PM   #170
MRF582
Member#: 48219
. Always drive
the race line .
Wow, so the wrist pins were bent?! Is that due to an engine overrev or from too much torque? Generally speaking, at what torque level does your engine builder recommend upgraded wrist pins?
MRF582 is offline   Reply With Quote
Old 10-31-2012, 02:05 PM   #171
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
WE MAKE'EM FASTER!
www.ImportImageRacing.com
looking good dave, we miss you. get your beast running!
IMPORTIMAGE is offline   Reply With Quote
Old 11-01-2012, 08:34 AM   #172
baseballdbk1
Member#: 242700
Thanks a lot Josh!
Don't know where the car would be without all of your help!
Old 11-01-2012, 09:10 AM   #173
baseballdbk1
Member#: 242700
Yea I have the box with the bent wrist pins and they are barely noticeable without measuring them...
No actual numbers given of when to upgrade wristpins and quite honestly, we probably would have been fine getting a new set of the same material but CP had a tool-steel material so we decided to be safe and go with those
Old 11-01-2012, 02:22 PM   #174
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Those aren't copper-beryllium seats and they don't appear new? Your guides are also not new?
Crystal_Imprezav is offline   Reply With Quote
Old 11-01-2012, 04:18 PM   #175
baseballdbk1
Member#: 242700
Alright that was my bad!
I accidentally misunderstood him when I pick up the engine from the machine shop.
He was talking about a set of heads previously done with the copper-beryllium but I don't know why I thought he was talking about mine?
I was running on about 2 hours of sleep that day so that may have something to do with it lol
Message Board Statistics All times are GMT -4. The time now is 01:13 AM.
