Welcome to the North American Subaru Impreza Owners Club Saturday March 30, 2024
Old 10-12-2012, 01:32 AM   #51
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Walbro 450 will support 600+whp on e85 all day long. The 400 has gotten me to 650 and 140+mph traps
Old 10-13-2012, 01:19 AM   #52
teesutt
Member#: 127940
Evil shenanigans
11.3@130 tonight. I need to get faster with shifting. i'll post the time slip later.
Car is pushing coolant under power. Its bypassing the cap and goes right into the overflow tank and then blows all over the place. The block is pinned, but not o ringed. I assume that is the issue?
teesutt is offline   Reply With Quote
Old 10-13-2012, 01:54 AM   #53
TwinscrollGT35R
Member#: 256810
Nice work!
TwinscrollGT35R is offline   Reply With Quote
Old 10-13-2012, 12:47 PM   #54
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Nice!! Better shifting and thats easily a 10sec car
Thats no good at all brotha. Could be a HG problem or even a small crack in the cylinder. I hope its just a headgasket/sealing problem
Old 10-13-2012, 01:12 PM   #55
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
What Paul said... it sounds like a head gasket issue. Det?
Old 10-13-2012, 03:04 PM   #56
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Very nice, shifting will get us the mph.
Yep, call Paul@p&l for the fix. Non oringed and FFS/LC on big hp cars always gives problems. That and get some l19 heads studs or bigger ones.
Old 10-13-2012, 03:08 PM   #57
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Yea it's a hg, the cylinder pressure and then FFS/Revlimiter/LC pretty much any abrupt cut will cause head lifting issues on big hp cars without orings/studs. Det would def do it too, but unless he picked up some bunk e85 I doubt it's the cause. I leave pretty decent margins between maxed out timing on e85 cars.
Old 10-13-2012, 09:28 PM   #58
mboulton
Member#: 174433
No studs on this built block? Hard to imagine.
mboulton is offline   Reply With Quote
Old 10-13-2012, 09:47 PM   #59
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Arp std studs, not the greatest on a 600whp Subaru. Few guys around here have broken them.
Old 10-15-2012, 03:49 PM   #60
teesutt
Member#: 127940
Evil shenanigans
I didnt know the ARP studs i installed wouldnt take that kind of power. then again, the car made a lot more hp than I thought.(good machinist, good builder, great tuner!)
Me and the mad scientist will tear it down this winter and take it to the machinist and have it ringed. I'll also talk to paul about some heavier duty studs. For now, I have drained all the coolant and am just running distilled water so i dont get icky coolant all over the motor.
Old 10-15-2012, 04:22 PM   #61
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Good work, Nice chart.
But can I ask one question.... Why do people around here use STD correction? Its out dated and is inflated. It read approx 4% higher then SAE correction, which is the current standard. All charts should be SAE or Uncorrected with the temps reported.
Some reading
http://www.gettorq.com/store/blog/sa...-dyno-numbers/
Sry for the OT.
Boosted Tuning is offline   Reply With Quote
