Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 10-09-2012, 12:55 PM   #1
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
Default My '12 WRX dyno numbers
So I did 3 pulls yesterday, first time. Only mods are AP OTS 93 stage 1 & Nameless axleback muffler delete. Temperature was a cool 72 degrees here in Houston and it wa a Mustang dyno. Best numbers were pull 3 @ 238 HP & 253 FT/LB. Ill post the videos when I get a chance. Is this about right?
Here's the google docs link:
https://docs.google.com/file/d/0B8fA...9aN191SmM/edit
SouthernWRX is offline   Reply With Quote
Old 10-09-2012, 07:24 PM   #2
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
that sounds pretty accurate. stage 2 will open up the power alot more. go to efilogics.com. they have a dyno database. its pretty useful for comparisons.
Old 10-09-2012, 08:31 PM   #3
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
yup, slap a downpipe on it and get a protune. The new wrx's do pretty well when you turn them up to about 19psi... that cobb mapp is what 15psi with conservative timing?
All4bSpinnin is offline   Reply With Quote
Old 10-10-2012, 11:56 AM   #4
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
Thanks for the input yall.
I'm hitting around 16psi usually. Other day when we had some cool weather (58F, yes thats cool for us folks here in Houston) It actually hit 17.1psi at one time.
Definitely plan on a downpipe with a protune. Plan right now is to get around the 300 - 325 awhp mark and play with that for awhile. Just need to save up some coin.
Old 10-12-2012, 10:15 AM   #5
L8Braker
Member#: 297987
2011 WRX-Limited
Blue Pearl
Southern, I want to do the same thing you have, I'm a little leary of getting over 300hp, don't think our weak 5-speeds and clutches can handle it.
L8Braker is offline   Reply With Quote
Old 10-12-2012, 10:50 AM   #6
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
Well from what the guy at the local shop here told me, was the tranny would be good to around 400whp. However before I get close to that 300whp mark, I will be doing lots of home work. I plan on upgrading the clutch in the venture to the 300-325whp.
Ill keep you posted (throught PM here) as I do more things and let you know how it is going. Do the same if you dont mind.
Old 10-12-2012, 12:29 PM   #7
makopolo
Member#: 260046
2011 WRX Hatchback
Keep in mind that a more aggressive clutch adds more shock to the drivetrain. The stock clutch can handle those power levels and any slip is just a little more safety for your transmission.
makopolo is offline   Reply With Quote
Old 10-12-2012, 12:45 PM   #8
jiGGypiGGy
Member#: 271097
2014 Evo Gsr
wicked white
I could not run 19 for long on the stock ic, in socal at least. Tbh with just a dp n intake i think im still having heat problems tuned open source at 17 psi, very little timing before heat soaking.
jiGGypiGGy is offline   Reply With Quote
Old 10-17-2012, 02:39 PM   #9
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
what's going on here?
i've ran 18psi on the stock ic for a year now. knock on wood, no problems.
i've been at 330wtq for a year now. knock on wood, tranny has no problems.
clutch, on the other had, started slipping in 3rd+ at that amount of torque around 30k miles. dealership replaced it under warranty (don't ask me how that happened) and now the new, stock-grade clutch is doing dandy... knock on wood.
Nimbus09 is offline   Reply With Quote
Old 11-28-2012, 09:45 PM   #10
BigRob74
Member#: 305107
2012 wrx
360/386 E85
i know this is a little old, but i was looking for somewhat stock numbers to compare my stage 2 #'s to. to the OP, just FYI, with just a DP and TP stage 2 tune, i did 265whp/320TQ on a mustang dyno, so you might want to look into a DP..30WHP and 70Ftlbs for less than 300 bux
BigRob74 is offline   Reply With Quote
