Go Back   NASIOC > NASIOC Reviews > Car Part Reviews
Old 09-26-2012, 02:30 PM   #1
RoadKillDMD
Member Sales Rating: (2)
Member#: 284792
2011 STI
Blurple
Edit: Clutch line installed. Review on my third post vvv
I'm in the market for a coated, braided stainless steel clutch line for my STI. The two that I've come across are the Goodridge clutch line and the Mach V Motorsports clutch line. Will I be compromising build quality or reliability going with one or the other? All in all, the Goodridge is a few bucks cheaper. I may end up flipping a coin to make my decision, unless someone has a solid reason why one should be bought over the other.
Thanks y'all!
DMD
Old 10-02-2012, 04:00 PM   #2
WhatTurboLag?
Member Sales Rating: (3)
Member#: 243992
2006 WRX TR
I went with goodridge just because it was the same as my brake lines
Goodridge lines are dot approved (or at least meet dot specs)
Old 10-02-2012, 04:09 PM   #3
roccer
Member Sales Rating: (9)
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
i've got the Mach V clutch line (and their matching brake lines). no issues so far. been on for over a year now. definitely firmed up the clutch feel. easy to install and no debris gets into the braiding thanks to the red sheathing around it. quality is very good. install was relatively painless (once the TMIC is out of the way). you'll probably be fine with either, but im just +1 for Mach V.
roccer is offline   Reply With Quote
Old 10-03-2012, 02:36 PM   #4
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Thanks guys. I already flipped the coin and went with the Goodridge line. I found one for ten bucks less than the MachV line. I appreciate the replies.
Old 10-09-2012, 08:19 PM   #5
thrasher
Member Sales Rating: (49)
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Please report back on how much of a pita the install is. Thanks.
thrasher is offline   Reply With Quote
Old 10-12-2012, 02:38 PM   #6
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Update! I got my clutch line installed last night and this is now a review! The install of the clutch line itself was super easy. Unscrew two connections and screw the new one on. It literally took all of fifteen minutes. The hard part was bleeding the system, which required me to remove the clutch slave cylinder. Altogether, the install was fairy straight forward. I didn't run into any real time consuming problems.
The clutch pedal feels amazing! Much more even pedal pressure throughout the range of motion. No more squishy clutch feel. It's not any harder to push in, but it definitely has a more solid feel, especially when pushing the clutch hard and fast. I would recommend to anyone wanting to remove some slop from their clutch pedal.
Here is my detailed install writeup, hopefully it helps any of you all wanting to get a clutch line too:
http://forums.nasioc.com/forums/show....php?t=2419445
