Old 10-12-2012, 08:23 PM   #1
zZzZz
Member#: 245990
2004 WRX
Default Leaking Water ???
Hi all,
Hopefully I have enough info for you guys to help, but I noticed every time I drive my car harder than usual, I would notice it dripping water(?) from under the passenger side of the car. My coolant levels are fine and doesn't seem to be going down so I'm assuming it's not coolant. Definitely not oil. When I drive normally w/ little to no boost I noticed there is no leak after.
Any ideas ?
zZzZz is offline   Reply With Quote
Old 10-12-2012, 09:15 PM   #2
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
turbo reservoir is leaking? Cracked return line perhaps?
tebriel is offline   Reply With Quote
Old 10-12-2012, 11:20 PM   #3
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
The ac drains water on the passenger side right by the turbo. Thats my guess.
Old 10-13-2012, 12:40 AM   #4
FraudulentNeon
Member#: 29108
2002 Impreza WRX
That's exactly what's happening here.
FraudulentNeon is offline   Reply With Quote
Old 10-13-2012, 01:22 AM   #5
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
Are you running your A/C?
Chaz2.5 is offline   Reply With Quote
Old 10-13-2012, 02:42 AM   #6
zZzZz
Member#: 245990
2004 WRX
Hmmmm, I can't recall. I'll give it a try tomorrow and blast the AC to see if it starts leaking.
Old 10-13-2012, 02:53 PM   #7
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
depends on where he is. :P It's like 40 degrees here.
Old 10-13-2012, 07:06 PM   #8
quazimoto
Member#: 70395
The obvious answer is to get under the car and find out where the water is coming from. Pretty straight forward solution as we can not see your car from the interwebz.......
Old 10-14-2012, 05:21 PM   #9
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
maybe you can't... *puts away binoculars*
Old 10-15-2012, 10:22 AM   #10
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
If it is cold, maybe you had it in defrost not with the A/C Specifically on?
BoboTheMonkey is offline   Reply With Quote
Old 10-15-2012, 10:45 AM   #11
lavid2002
Member#: 226864
AC makes water condense just like a cold can of soda. The car had a black run off line that drips this water out of the firewall just below the turbo.
Normal
Old 12-18-2012, 06:59 AM   #12
UnknownAlly
Member#: 277330
2004 WRX
Does it still drain water with defrost and a/c off?
UnknownAlly is offline   Reply With Quote
Old 12-18-2012, 11:41 PM   #13
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
Um, I guess it shouldn't but their is a water drain line for your winshield area too. A car wash, spraying your windows, rain etc. would also drain here.
Old 12-18-2012, 11:52 PM   #14
UnknownAlly
Member#: 277330
2004 WRX
That's what it is then. Thanks!
