Old 10-12-2012, 05:27 PM   #1
gbaer22
Member#: 255601
2004 STi
blue
Default Tips on replacing turbo
Ok so my turbo tools a **** on my 2008 STi.. I got the gaskets for it pulled intercooler but can't seem to get the down pipe loose from turbo
gbaer22 is offline   Reply With Quote
Old 10-12-2012, 05:34 PM   #2
P-Train
Member#: 279233
2008 WRX
What are you trying to say? Can you not get the nuts and bolts loose? Are the nuts off and the pipe seized to the turbo?
P-Train is offline   Reply With Quote
Old 10-12-2012, 05:37 PM   #3
gbaer22
Member#: 255601
2004 STi
blue
The nuts are off.. The down pipe is still TIGHT to the turbo
Old 10-12-2012, 06:38 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 10-12-2012, 06:47 PM   #5
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
^:facepalm: very helpful.
Have you disconnected the DP from the cat back? Give it a good pry with a nice long handled pry bar.
Make sure absolutely everything connected to the turbo is disconnected.
Its most likely rusted in place from multiple heat cycles and rain water.
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 10-12-2012, 07:01 PM   #6
~Evil
actually...one of THE secrets to doing a quick turbo swap is to drop the WHOLE ENTIRE exhaust off in ONE PIECE
taking the exhaust apart is a fools errand and 100% unnecessary
Old 10-12-2012, 07:02 PM   #7
and the OP needs a local friend to make sure he isnt disassembling the transmission or the rear end here, i think
Old 10-12-2012, 07:30 PM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
~Evil
Old 10-12-2012, 08:34 PM   #9
gbaer22
Member#: 255601
2004 STi
blue
Ok we'll turbo is out and seems to look fine and don't feel no shaft play? But y would it only boost 7psi and be SLOW as hell
Old 10-12-2012, 08:40 PM   #10
oh boi.....ya pulled the terbo for THAT
there are MANY reasons for what you describe and MOST have nothing to do with taking the terbo off the car
Old 10-12-2012, 08:42 PM   #11
gbaer22
Member#: 255601
2004 STi
blue
Yea it's off already... I was told by the dealer n specialist it was turbo but seems ok
Old 10-12-2012, 08:43 PM   #12
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Here's a great tip, if you don't have any idea what the hell you're doing, don't do it.
Did you try trouble shooting or did you just decide it was the turbo for the hell of it? What you're describing could be a ton of things.
And your profile says 2004, but you say 2008. Be prepared to spend money, I see this motor going BOOM soon.
Old 10-12-2012, 08:46 PM   #13
gbaer22
Member#: 255601
2004 STi
blue
I had an 04 before but bought a 08.. Like I said I was told
Old 10-12-2012, 08:52 PM   #14
gbaer22
Member#: 255601
2004 STi
blue
I had a 04 STi before sold it to buy my house.. Bought my 08 ran great then bam out of no where it lost boost and smoked from turbo it would run 7psi but that's it .. Specialist said it was turbo and to not drive it till replaced
Old 10-12-2012, 09:10 PM   #15
gbaer22
Member#: 255601
2004 STi
blue
What else could it be so I can check
Old 10-12-2012, 09:36 PM   #16
jrodm12
Member#: 296705
05 STI
Motor pulling timing and boost due to knock.
jrodm12 is offline   Reply With Quote
Old 10-13-2012, 12:11 AM   #17
gbaer22
Member#: 255601
2004 STi
blue
So what should I do
Old 10-13-2012, 12:17 AM   #18
lavid2002
Member#: 226864
Your research.
What are the mods on the car? Is it tuned?
I can't believe you just dove into a turbo swap without confirming that it's the turbo. Shaft play can be felt just by dropping the downpipe off anyways.
Old 10-13-2012, 01:47 AM   #19
gbaer22
Member#: 255601
2004 STi
blue
AEM intake and Cobb tuner stage 1 tune...
Old 10-13-2012, 02:09 AM   #20
rkl303
Member#: 171314
2008 STI
...could be that.
rkl303 is offline   Reply With Quote
Old 10-13-2012, 07:44 AM   #21
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
You said the turbo was smoking. Does that mean you saw smoke out the exhaust or smoke was just rising from the turbo itself in the engine bay? What does that mean?? It could be that the dealer diagnosed the problem as the turbo oil seals. Do you see oil in the intercooler or turbine?
FCmaniac is offline   Reply With Quote
Old 10-13-2012, 11:08 AM   #22
gbaer22
Member#: 255601
2004 STi
blue
There is some oil in turbo n intercooler
Old 10-13-2012, 11:15 AM   #23
stillatoy
Member#: 276391
2004 WRX
java black pearl
^ thats pretty normal its just some blowby a good aos or catch can will help with that.
stillatoy is offline   Reply With Quote
Old 10-13-2012, 11:19 AM   #24
gbaer22
Member#: 255601
2004 STi
blue
Check all vac lines? I'm going to do leak down test
