#6501 | |
Member#: 260868
South East
Vehicle:2011 STI White |
10cm.
#6502 |
Member#: 159243
Tri-State
Vehicle:sg3 Turbo Tek Tuned Hakt Ecu e85 30r 6spd |
23" tire height at 22#s of air pressure. Car weighs 3320#s with me in it, 1/2 tank of E85.
#6503 |
Member#: 260549
SCIC
Vehicle:69' Camaro Project, 76' Yamaha Cafe Project |
Does anyone know of a possible fix for fuel pick up starvation?
I lose a lot of power and the car stutters coming out of hard corners with anything less than 3/4 of a tank of gas. |
#6504 |
Member#: 23123
SWIC
Vehicle:05 Legacy GT 13 Scion FR-S |
Surge Tank will eliminate that problem.
#6505 | |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag |
#6506 |
Member#: 23123
SWIC
#6507 |
Member#: 176723
Vehicle:2005 WRX STi Platinum Silver Metallic |
I bought a T1Racing surge tank and it's exactly like the IE one. Same price and it shipped from Dallas to OKC, which makes it overnight.
![]() Just an option for those wanting a 2 x 044 setup. |
#6508 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
I finally got my car up and running
#6509 |
Member#: 149262
MWSOC
Vehicle:2003 03WRXw6sp/05FXT PSM |
[quote="juanmedina"]I finally got my car up and running
![]() What's your setup? Wow. |
#6510 |
Member#: 159243
Tri-State
Juan...25-27#s of boost?
#6511 |
Member#: 190729
NWIC
Looks sweet.
two questions: 1. why so rich under 3k? 2. can we see the graph over 7k? ![]() |
#6512 | ||
Member#: 133146
[quote=sackytar;38259416]
it hit 28 for a second Quote:
... 1. This is the first pull that I have done after breaking in the clutch so the tune needs a lot of clean up. 2. I only rev to 7055rpm on that pull. After the pull the car smelled like if the clutch burn... so it might need some more breaking in time. I am also sorting out some issues with the slave cylinder, if I fix it today I get you another log reving higher. I am hitting 16.5 psi by 3700 rpm |
#6513 |
Member#: 159243
Tri-State
so a green is a lil bigger than a 30r?
#6514 |
Member#: 48350
MAIC
Vehicle:04 WRX |
^^^^I thought Jaun was running the fp black (stock location 35r)?
#6515 |
Member#: 159243
Tri-State
guess he needs to update profile
#6516 | |
Member#: 133146
I will update my profile ones I have some track times. A FP green 49lb/min will only see around 440whp on VD and a 30r around 460whp |
#6517 |
Member#: 48350
MAIC
Vehicle:04 WRX |
Juan you got any vd/airboy info on the Precision 6266?
#6518 |
Member#: 133146
nope, but I imagine it will make around low 600whps on E85 with 30psi.
Keep in mine that my setup is stock location, IWG with a TMIC, and running low timing compared to what I head other people are running. |
#6519 |
Member#: 48350
MAIC
Vehicle:04 WRX |
^^^ yeah juan your setup is real nice.
#6520 | |
Member#: 166005
MWSOC
Vehicle:2005 Saab 92x Beaten Silver |
![]() Looks super good though. I like to focus on where 300wtq happens the first and second time to judge a car. You seem to be doing just fine (note: FANTASTIC!), even if you need some more rev's to really max out that turbo! |
#6521 | |
Member#: 133146
.My rev limiter is set at 7500rpm so it should make more power. My slave cylinder is leaking... so I will post new plots later this week ![]() |
#6522 |
Member#: 159243
Tri-State
I'd be happy a 460whp.
#6523 |
Member#: 133146
#6524 |
Member#: 270482
Vehicle:2011 forester xt corn fed td06 20g 8cm |
Im having a e85 related issue so i thought i would post here and check to see if anyone else has had this problem. My car is a 2011 fxt and has a dw65c pump and id1000cc injectors running e85. The problem accured the other day when i put 10 gallons of e85 in the car that was in my garage from a reputable mobile i use regulary as soon as i put it in the car would not fire. It cranked just fine but would stumble and stall every time i tried to turn it over. I tried for about 5 min befor trying something new.
I then decided to flash a different map with my ap and after waiting for it to load it fired rite up. It was a cold day about 45* so i chalked it up to cold weather and the ethanol. Next morning the same thing happened so i switched it back my original map and waited for it to load and it fired rite up. So i called my tuner and he changed my cold start enrichment tables to suit the colder weather. I just tried to start the car today with the new map its about 60* outside. I loaded it in the other nite and still nothing this morning. I primed it for a long time and after a few more primes and a long wait it finally started. So i know its not map related and once the car warms up it runs fine as far as i know. Could it have been a bad or a different mix content that could have had this happening? The car started normally befor i put the 10 gal in so thats all i can think of.The day befor it was about 50* and it fired up normally. I am used to having to crank longer then normal in the colder days but this is pretty bad. Also the car starts fine for the rest of the day once it warmed up this only happens on the first cold start of the day. I have been on e85 close to a year now. Last edited by nate_fisher; 10-17-2012 at 05:44 PM. |
#6525 |
Member#: 149262
MWSOC
Longest post ever award^
I have had issues with cold start ups. It can be tuned better for cold start ups. |
| Thread Tools | |
| Display Modes | |
| Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
| jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
| The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
| Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
| Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
