Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 10-07-2012, 08:16 AM   #6501
jockeygolfs
Member#: 260868
2011 STI
Originally Posted by smeerone
8cm or 10cm?
Funny, I know a guy with that turbo.... 10cm.
jockeygolfs is offline   Reply With Quote
Old 10-07-2012, 01:08 PM   #6502
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
23" tire height at 22#s of air pressure. Car weighs 3320#s with me in it, 1/2 tank of E85.
maxpowr is offline   Reply With Quote
Old 10-08-2012, 05:19 PM   #6503
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Does anyone know of a possible fix for fuel pick up starvation?
I lose a lot of power and the car stutters coming out of hard corners with anything less than 3/4 of a tank of gas.
breaksOFTEN is offline   Reply With Quote
Old 10-08-2012, 05:23 PM   #6504
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Surge Tank will eliminate that problem.
Z0rr0 is offline   Reply With Quote
Old 10-08-2012, 05:34 PM   #6505
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Exactly. Check out the tanks from integrated engineering.
06rexwagon is offline   Reply With Quote
Old 10-08-2012, 05:35 PM   #6506
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
those are great tanks, and even better for the price.
Old 10-08-2012, 08:26 PM   #6507
Boss Paco
Member#: 176723
2005 WRX STi
Platinum Silver Metallic
I bought a T1Racing surge tank and it's exactly like the IE one. Same price and it shipped from Dallas to OKC, which makes it overnight.
Just an option for those wanting a 2 x 044 setup.
Boss Paco is offline   Reply With Quote
Old 10-12-2012, 05:39 PM   #6508
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I finally got my car up and running
Old 10-12-2012, 06:47 PM   #6509
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
[quote="juanmedina"]I finally got my car up and running
What's your setup? Wow.
Old 10-12-2012, 11:19 PM   #6510
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Juan...25-27#s of boost?
Old 10-12-2012, 11:28 PM   #6511
Maxwell Power
Member#: 190729
Looks sweet.
two questions:
1. why so rich under 3k?
2. can we see the graph over 7k?
Maxwell Power is offline   Reply With Quote
Old 10-13-2012, 11:33 AM   #6512
juanmedina
Member#: 133146
[quote=sackytar;38259416]
The setup is the same just different transmission and clutch. Now I have 2011 STi transmission and ACT full face STi clutch with a xtreme pressure plate.
it hit 28 for a second
Originally Posted by Maxwell Power View Post
Looks sweet.
two questions:
I am glad you like my curves Dom ...
1. This is the first pull that I have done after breaking in the clutch so the tune needs a lot of clean up.
2. I only rev to 7055rpm on that pull. After the pull the car smelled like if the clutch burn... so it might need some more breaking in time. I am also sorting out some issues with the slave cylinder, if I fix it today I get you another log reving higher.
I am hitting 16.5 psi by 3700 rpm
Old 10-13-2012, 11:52 AM   #6513
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
so a green is a lil bigger than a 30r?
Old 10-13-2012, 12:26 PM   #6514
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
^^^^I thought Jaun was running the fp black (stock location 35r)?
Old 10-13-2012, 12:50 PM   #6515
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
guess he needs to update profile
Old 10-13-2012, 01:10 PM   #6516
juanmedina
Member#: 133146
Yeah I am running a FP Black, a stock location HTA82/HTA35r 68lb/min
I will update my profile ones I have some track times.
A FP green 49lb/min will only see around 440whp on VD and a 30r around 460whp
Old 10-13-2012, 01:19 PM   #6517
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Juan you got any vd/airboy info on the Precision 6266?
Old 10-13-2012, 01:25 PM   #6518
juanmedina
Member#: 133146
nope, but I imagine it will make around low 600whps on E85 with 30psi.
Keep in mine that my setup is stock location, IWG with a TMIC, and running low timing compared to what I head other people are running.
Old 10-13-2012, 01:53 PM   #6519
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
^^^ yeah juan your setup is real nice.
Old 10-13-2012, 02:40 PM   #6520
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Don't forgot to add the junky overrated cams as well
Looks super good though. I like to focus on where 300wtq happens the first and second time to judge a car. You seem to be doing just fine (note: FANTASTIC!), even if you need some more rev's to really max out that turbo!
Old 10-13-2012, 06:41 PM   #6521
juanmedina
Member#: 133146
Thank man, although I am running ****ty cams they seem to be doing a good job .
My rev limiter is set at 7500rpm so it should make more power. My slave cylinder is leaking... so I will post new plots later this week
Old 10-13-2012, 08:57 PM   #6522
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
I'd be happy a 460whp.
Old 10-13-2012, 11:12 PM   #6523
juanmedina
Member#: 133146
yes sir, 460whp is a lot
Old 10-17-2012, 05:16 PM   #6524
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Im having a e85 related issue so i thought i would post here and check to see if anyone else has had this problem. My car is a 2011 fxt and has a dw65c pump and id1000cc injectors running e85. The problem accured the other day when i put 10 gallons of e85 in the car that was in my garage from a reputable mobile i use regulary as soon as i put it in the car would not fire. It cranked just fine but would stumble and stall every time i tried to turn it over. I tried for about 5 min befor trying something new.
I then decided to flash a different map with my ap and after waiting for it to load it fired rite up. It was a cold day about 45* so i chalked it up to cold weather and the ethanol. Next morning the same thing happened so i switched it back my original map and waited for it to load and it fired rite up. So i called my tuner and he changed my cold start enrichment tables to suit the colder weather.
I just tried to start the car today with the new map its about 60* outside. I loaded it in the other nite and still nothing this morning. I primed it for a long time and after a few more primes and a long wait it finally started. So i know its not map related and once the car warms up it runs fine as far as i know. Could it have been a bad or a different mix content that could have had this happening? The car started normally befor i put the 10 gal in so thats all i can think of.The day befor it was about 50* and it fired up normally. I am used to having to crank longer then normal in the colder days but this is pretty bad.
Also the car starts fine for the rest of the day once it warmed up this only happens on the first cold start of the day. I have been on e85 close to a year now.
nate_fisher is offline   Reply With Quote
Old 10-17-2012, 07:11 PM   #6525
sackytar
Member#: 149262
PrimerGrey
Longest post ever award^
I have had issues with cold start ups. It can be tuned better for cold start ups.
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
