Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 10-13-2012, 01:51 PM   #1
NatSTI
Member#: 334984
Default 05 to 06 front end conversion problem...
Hi guys!
I'm doing a 05 to 06 front end conversion (STI)... and I'm stuck..
I've bought the carbon creations OEM CF hood and the supportive OEM parts such as the tie bar, left & right side panels (53020FE210 and 53020FE200) had to trim those because they were almost an inch wider than the 05 ones, anyway the problem is that the hood striker (the one I had on my 05 car) is almost 0.78 inch away (and need to be pushed outside) in order to fit in the lock assy..
I've checked with a 06 N/A impreza and my tie bar is in place along with the lock assy and everything..
I've also checked the distance between the striker bolts location to the end of the hood (3.937 inch from the end to the bolt holes)... just like the N/A 06 one I have there... but the question is:
Is the hood to short? or maybe the Hinges are different between the 05 and the 06?
Please advise...
NatSTI is offline   Reply With Quote
Old 10-13-2012, 07:22 PM   #2
jdblock
Member#: 235211
2004 STi
jdblock is offline   Reply With Quote
Old 10-13-2012, 07:40 PM   #3
NatSTI
Member#: 334984
Thanks for the reply, but I still can't find any answer to why the striker doesn't fit the locking assy...
Old 10-13-2012, 08:37 PM   #4
jdblock
Member#: 235211
2004 STi
Was thinking that would be a better place to post your question. Good luck man.
