#1 |
Member#: 255666
Tri-State
Vehicle:2005 WRX STI WRB |
Where would you guys suggest I try mounting a camera in an 05 STi for an autocross event? Event organizers stress that it must be in a safe place as to not come loose an get wedged behind a brake pedal. There just does not seem to be anywhere sturdy (like a headrest crossmember) to mount a standard camera mount (not a gopro or the like). Any suggestions?
#2 |
Subtly Outspoken
Moderator Member#: 238
MWSOC
Vehicle:99 Ver6 Recreation JDM Speedwagon 3 LSDs..:) |
Front Windshield Lower center.. or Left side window to see hands...up to you...what view do you enjoy watching>>> that would transpire to where you put the camera..
..sidenote: make sure your mount is secure. ![]() Bill |
#3 |
Member#: 179170
South East
Vehicle:2005 |
I like to put it either outside on the rear driverside window close to the B pillar, aiming right at the a/c vent it shows driver input as well as the front left to see how close to cones Im getting. Or inside on the rear passenger window looking forward. It gets more of driver input and really shows the full effect of slides and such. With the inside view I use a centr mounted roof car and ovrlap them on videos.
https://www.youtube.com/watch?v=k3cT...e_gdata_player Or https://www.youtube.com/watch?v=1hJQ...e_gdata_player |
#4 | |
Member#: 255666
Tri-State
#5 | |
Street's closed, pizza boy
Member#: 17301
MAIC
Vehicle:is the "dark side" 06 Evo #7 STU, 05 Saabaru |
The best setup is two cameras blended in post-processing though That way you could see the cones on the right side of the car too. |
#6 |
Member#: 218964
MWSOC
Vehicle:2009 WRX Rally Blue |
I have GoPros. I used a cut off hockey stick that I mount to the seats using large hose clamps wrapped in vinyl hose to protect the seats. this works well for inside the car. I've never had an issue using the suction cup car mounts for other places.
![]() Last edited by MNGman; 10-08-2012 at 05:25 PM. Reason: added photo |
#7 |
Member#: 162988
MAIC
Vehicle:06 06 Sti STU&ASP Gray |
do u wana use the footage as data imput? or are u using it just to show case ur runs. for data, you can put it right next to the bpillar and face it downward just a hair so you can see the suspention working along with how close you are to cones. as far as just the best views, check out some of my videos on youtube: Kwracing22 , Buttdyno can voutch for me, hes been at pretty much every event I have done recording for. lol i use tons of diffrent angels to make my videos. But honestly the best camera for the job is the Hero2 with wifi remote. my next challenge is to get a my old gopro in the wheel well so see all the components working.
#8 | |
Member#: 179170
South East
Vehicle:2005 |
#9 |
Member#: 255666
Tri-State
thanks for all the input so far guys. I should have made it more clear that I do not have a gopro or contour type camera. I will be mounting my canon dslr and will not be mounting it outside of the vehicle. I just picked up a ram mount and will most likely be mounting it to the inside of the rear passenger window. And no, this footage will not be analyzed, this is just to showcase how bad of a driver I am.
#10 |
Member#: 162988
MAIC
well in that case be careful, because the Dslr is gona be way heaver especially under all the lateral and bumping around. Alos depending on your lens choice if you are using a lens with a plastic or lower quality mounting bracket you could break or bend the bracket with all the bumpiness. In some case i have seen it actually break the "lock in" bracket on the dslr. This is why i havent done this yet lol Im looking into buying a t2i just as a camera body to put in special situations such as right after a cone on course or on the outside of the car. Im not willing to put my 60D out there just yet lol
#11 |
Member#: 255666
Tri-State
yeah, I was worried about that but then I found this:
thing seems very sturdy and I will obviously give it some good stress tests before I mount my camera. It even holds a ten pound weight in the picture! So it's gotta be good, right? |
#12 |
Member#: 162988
MAIC
I would stay away from that and look into more serious mounts for a DSLR, i would go with a 2 or more suction cup mount rig. Check out this website. http://www.filmtools.com/delkin-fat-...era-mount.html
let me know what you think. also what Dslr do you have? i paid 1100$ for my camera with kit lens, idk if i would trust all that with a 30$ mount if you catch my drift. |
#13 |
Member#: 255666
Tri-State
I have a canon t2i. You are right, I am skeptical. But I will most certainly test run it before I actually mount anything I don't want broken to it. I wil also look into the mounts you suggested for these types of applications in the future. Thanks!
#14 |
Member#: 17301
MAIC
Dude, original Go Pros are pretty cheap. I would save up for one of those way before I put a $1000 camera on a mount in a car.
#15 | |
Member#: 198231
Vehicle:'06 WRX SGM |
#16 | |
Member#: 162988
MAIC
#17 |
Member#: 255666
Tri-State
Thanks dwomp, unfortunately the even is this saturday and I would not receive it in time. I have other, smaller, less expensive point and shoot cameras that I can mount. I just wanted the best video quality possible. However, if you would still like to sell it in a few weeks I would happily purchase it from you.
#18 |
Member#: 92604
MWSOC
Vehicle:05 WRX STi CGM |
I'm lazy, so I just used the sticky mount and stuck it to the center light. Gives a great view and it is sturdy enough - never came loose for me.
#19 | |
Member#: 208152
TXIC
Vehicle:2007 STI LTD #576 Urban Gray Metallic |
![]() I've been contemplating a way to mount my GoPro between the front seats for the best angle possible, and no wind noise. Else, it's the bottom of the driver's side rear door glass 99% of the time. |
#20 |
Member#: 255666
Tri-State
Op just letting you know that I blew my turbo today. My short lived auto x season has ended before it began. But I did beat the pants off the vette and the boss 302. Not a total loss and they can't say I wasn't driving my heart out.
