Old 09-28-2012, 03:25 PM   #476
Juks
Member#: 108163
2015 WRX, 2005 STI
Need to get me up there too, between Juan and Reno
[code]Juks 2005 Subaru WRX STI NA Stockish 2.5 4 GT35R 30psi E85 500 420 10.8sec 129mph NA NA 4.2[code]
Updated the 1/4 mile info.
Juks is offline   Reply With Quote
Old 09-28-2012, 06:03 PM   #477
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
lol, looks like I need to up the boost and go for a 3.9
Old 09-28-2012, 11:37 PM   #478
Juks
Member#: 108163
2015 WRX, 2005 STI
Don't be scared homie!
If you do I think you'll have me beat at least until I get new tires
Old 09-29-2012, 01:04 AM   #479
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
OK, will do. Maybe I'll put you ahead of Juan too....
Do it!!!
Should have gotten video of the 10.8 run. That probably had a good time due to all the grip.
Old 09-29-2012, 01:09 AM   #480
Nuke209
Member#: 108089
NF Performance
video's posted
Old 09-29-2012, 01:13 AM   #481
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Not the speedo!
Old 09-29-2012, 10:17 AM   #482
Nuke209
Member#: 108089
NF Performance
Not the speedo!
ah...have him go repeat it again
Old 09-29-2012, 12:31 PM   #483
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I added the Invidia equal length header to my car and the 50-100mph time for a 3rd gear pull went from 4.6-4.7 seconds with the stock header, down to about 4.3 seconds with the EL header. This is due to the turbo spooling up sooner and being in a stronger part of the powerband by the time it reaches 50mph. With the new header is it usually at or close to 20psi by 50mph and with the stock header it is usually only 12-13psi.
Invidia Equal Length Header (~4.3 seconds):
Stock Header (4.6-4.7 seconds):
Old 09-29-2012, 12:44 PM   #484
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
A couple weeks of daily pulls on the 35R so far. We'll see how things go at the track tonight. I ran my 30R at 28psi for about a year and a half before that on the same build.
If you're worried about it, just switch to E85 and leave it at 28psi. It'll be well worth it. From what I've picked up on here, it seems the 35R doesn't really come alive until after 25psi anyway. The difference between 25psi and 30psi with the 35R was over 50hp on virtual dyno for me. Granted it's not a chasis dyno, but there is no denying the seat of the pants difference.
you don't think is because of the weather?
Old 09-29-2012, 12:54 PM   #485
Nuke209
Member#: 108089
NF Performance
nope, because both Fuji & I were in the car with Juks when tuning.
We started the first pull with 25psi, then switched it up right after and BAM
same weather that night LOL
Old 09-29-2012, 01:23 PM   #486
Juks
Member#: 108163
2015 WRX, 2005 STI
The cool weather on the 35 has been awesome
But like Nuke said, the first day we tuned the 35 it was 80 degrees plus. We started at 25 and then went up to 28 and then 30. The seat of the pants difference was significant, with the biggest jump being from 25 to 28. There were gains from 28 to 30 but not as much.
Lovin this turbo btw
Old 09-29-2012, 04:55 PM   #487
juanmedina
Member#: 133146
sorry guys I meant to quote Xluben's post...
From 4.6-4.7 seconds to 4.3 seconds is really significant just by swapping the stock headers
Old 09-29-2012, 05:01 PM   #488
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The temps were probably only about 10 degrees different between the two. This is comparing 3rd gear pulls, so the powerband is a big part of it. The big difference is at the very beginning. It's probably 0.2-0.3 seconds difference just between 50-60mph. The stock headers are still building boost during that period so it's quite slow.
Old 09-29-2012, 09:21 PM   #489
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Just goes to show you how much power a header can actually add once you have the right amount of power. I lost the boxer rumble but I actually love the way the my perrin sounds. That thing flies dude. I wish I could pull 50-100 in just 3rd
Slimsti is offline   Reply With Quote
Old 09-29-2012, 11:06 PM   #490
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I really like the way mine sounds too. The peak power went up a bit but not a huge difference. The faster spool is really what helped the 50-100mph time so much. Here's the plot.
The real difference (as confirmed by the butt dyno) is the quicker spool and much better response. It is around 300rpm's sooner to 20psi (ie. at 3,600rpm's the EL header is at 20psi and the stock header was only at 13psi), and that is a noticeable difference on the street. The translates into a much broader powerband. The low/mid range torque is a huge difference. Between 3,200rpm's and 4,200rpm's it has 50 to 70 ft-lbs of torque more than the stock header! Past peak torque the difference is around 20 ft-lbs and that holds until redline.
Old 09-30-2012, 11:49 AM   #491
Slimsti
Member#: 155696
Yeah mine did the same thing down low. I picked up like 5-10 more up top but gained 7psi of spool and like 50ft/lbs down low. The 3000-4900 area has a nice fat band of power increase. Your graph really shows the difference plain and clear. I wish I would have data logged and airboyd every step of the way like u did.
Old 10-01-2012, 01:47 PM   #492
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
anyone interested seeing me run a R1. PM me
Old 10-01-2012, 02:05 PM   #493
juanmedina
Member#: 133146
Wow, impressive gains
Lol.....
Old 10-01-2012, 02:20 PM   #494
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Lol.....
lol what! i'm still in awe!
Old 10-01-2012, 02:41 PM   #495
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Wow that was a masterful launch!!!! How much boost did u build off the line?
smeerone is offline   Reply With Quote
Old 10-01-2012, 03:03 PM   #496
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
7-8psi... then as soon as I drop it, I get up to 20psi almost automatically.
Old 10-12-2012, 02:26 AM   #497
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
My AP is giving me some really funky datalogs. I did a pull tonight and the speed doesn't match up with the boost, or time or anything. Is there a good way to log this? because according to my log I'm only getting to ~92mph and the speedo is around 105??
Thanks in advance
breaksOFTEN is offline   Reply With Quote
Old 10-12-2012, 11:49 AM   #498
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Thanks in advance
Try using a GPS to check your speedo for starters.
Old 10-12-2012, 11:57 AM   #499
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Ill do that, but I know on my dyno graph the car was at 101mph at 7000rpm 4 th gear.
Also the drive by radar things on the side of the road to tell you to slow down are always within 2-3mph of my speedo.
Well I just set my data log to a minimal list and the car reads 2-3 mph lower than my actual speedo, so ill try another run soon and hope the AP reads accurately. I'm pretty sure I don't hover around 92mph for over a second while doing the 50-100 pull haha
Old 10-14-2012, 02:17 PM   #500
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
http://youtu.be/Kpb5D29L-64
Was going for a 60-130 time. But here you go
NASIOCers!! Starter mods list Daniel son Legacy Forum 4 11-21-2006 03:56 PM
50 cent listings on eBay motors plunk10 Off-Topic 7 10-17-2006 12:15 PM
Official NASIOC OT C List dr_wheel Off-Topic 25 02-22-2006 05:41 PM
NASIOC GMail Invite List AVATAR-X Off-Topic 458 05-21-2005 10:04 AM
Japan's Top 50 car list Tragedy Off-Topic 5 07-29-2003 11:49 PM
