Old 10-13-2012, 09:29 PM   #1
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
OMGHi2U JrTuned, 02 WRX/ Precision 6765 -- 828WHP
Event: Dyno Tune !
Ambient Temp: 65 degrees F
Elevation: sea level
Weather: cool
Car: 2002 WRX
Tuner: Junior2jz
Dyno Info: DynoJet
Peak HP at RPM: 828
Peak Torque at RPM: xxx
Baseline hp/tq for a stock on same dyno: 230-240
Target Boost: 36PSI
Target AFR: 11.7
Fuel: straight e85
Engine/Performance
Darton Sleeved Block | Weisco Pistons | Pauter Rods | ACL Rod & Main Bearings | OEM STi Crank | Modded 11’ STI Oil pump | Cometic Headgaskets | Headgames Ported Heads | Kelford 282 Cams | Ferrea Competition Plus Valves | Ferrea Drag Springs & Retainers | Power Enterprises Racing Timing Belt | Cosworth Timing belt Guide | Cosworth Cam Sensor Adapter | Perrin Crank Pulley | Killer B Oil Pan, Baffle and Pickup Tube | Mishimoto 3 Core Radiator | AEM V1 Standalone
Turbo Setup
TurboTrix Racing Front Mount Turbo Setup | Precision 6765 Ball Bearing Turbo | Shorty exhaust and dump out the hood | Tial Wastegate | Tial Q Blow Off Valve | Treadstone Intercooler Core
Fuel
RCI 10 Gallon Fuel Cell | Twin 044 Bosch Fuel Pumps Mounted With a T1 Bracket | Teflon Lines | T1 Topfeed Conversion Fuel Rails | Injector Dynamics ID 2000 Injectors | Aeromotive Fuel Pressure Regulator
xdrian is offline   Reply With Quote
Old 10-13-2012, 09:42 PM   #2
wrxhard
Member#: 108091
Powerband looks like it wants to keep going!!! Glad to see it back up and running. With your driving this should turn some pretty serious times!
wrxhard is offline   Reply With Quote
Old 10-13-2012, 09:44 PM   #3
GeneralTJI
Member#: 152680
2002 ej22t 2.35 s363
surged aem ems 6spd wagon
Where do you see full boost?
That thing definitely wants to rev!! nice!
GeneralTJI is offline   Reply With Quote
Old 10-13-2012, 09:48 PM   #4
xdrian
Member#: 104200
828 WHP BUGEYE
no full boost yet, the wastegate keeps creeping thats what it looks so linear
Old 10-13-2012, 09:49 PM   #5
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
turbo record holder 11.4
The target is 20psi, but it does creep to 26 by 8k
Old 10-13-2012, 10:06 PM   #6
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
very nice xdrian and Jr,glad to see you got it running.
john 1badSTI is offline   Reply With Quote
Old 10-13-2012, 10:20 PM   #7
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Awesome job to everyone involved! She's going to be fast can't wait to see what you do at the track
Old 10-13-2012, 11:11 PM   #8
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
What transmission and clutch are you running?
Congrats Xdrian
Old 10-14-2012, 12:23 AM   #9
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
Full targeted boost is achieved at 4900rpm in 3rd on 93. I'm going to guess in 4th(dyno gear) with e85 it will hit full boost at 4500rpm
Old 10-14-2012, 12:29 AM   #10
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Well done sir!!
YZ86 is offline   Reply With Quote
Old 10-14-2012, 12:51 AM   #11
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
I already offered him my new ppg 6spd, now all we need are tires.
Would be nice to reset the east coast drag record
Old 10-14-2012, 03:43 AM   #12
hybridpatient95
Scooby Scammer- Do Not Buy From User
Member#: 127606
its gonna be on a problem on the east coast street race scene
hybridpatient95 is offline   Reply With Quote
Old 10-14-2012, 09:21 AM   #13
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Hahahaha sick! My qtp 16's with rims are at IAG! If you want to borrow them go right ahead bro! It's like a 2hr drive and they are 5x100
Old 10-14-2012, 11:30 AM   #14
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
That is currently our problem. All of us are rocking 5x114 now and I sold my 17s/15s when I parted my GC out. Maybe my 20" volks with drag radials will gave to do.. lol
Old 10-14-2012, 11:34 AM   #15
CatfaceType-R
Member#: 81102
****off scammer!
Nice build . Would love to hear spool numbers on the street, seems nice even on the dyno with no ram air from the ff turbo.
Old 10-14-2012, 11:50 AM   #16
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
That's just non stop rising power. My god, that must feel insane on the street
Slimsti is offline   Reply With Quote
Old 10-14-2012, 12:42 PM   #17
02WRX2.5
Member#: 63192
02 wrx
9.5@146.9 / 1.3 60'
Great job guys. Fast Bugeyes FTW
02WRX2.5 is offline   Reply With Quote
Old 10-14-2012, 12:48 PM   #18
mtcs
Member#: 180640
2000 FF Drag Impreza
6765,PPG,brakeman,Chute
Can't wait to see this thing at full power!
Keep the updates acomin...
mtcs is offline   Reply With Quote
Old 10-14-2012, 01:24 PM   #19
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Ohh ok ya that sucks. If you has other 16's then your more than welcome to use my tires bro...
Old 10-14-2012, 02:35 PM   #20
bubbajan21
Member#: 205532
Wow! Very nice!
bubbajan21 is offline   Reply With Quote
Old 10-14-2012, 04:29 PM   #21
xdrian
Member#: 104200
828 WHP BUGEYE
Thanks Wayne, im going to get a set of my own soon, need to find wheels that will fit over the front brembos!
Old 10-14-2012, 08:09 PM   #22
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
If you want to run 16's you can take a few mm off the top and bottom of the brembos to make them work. Or just go 17 with 275's seems like she will work good with your suspension setup...
Good luck bro
Old 10-14-2012, 09:35 PM   #23
stu
Member#: 25768
35R bugeye
Awdsome
This is one bad bugeye. Congrats!!
stu is offline   Reply With Quote
Old 10-14-2012, 10:08 PM   #24
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Why is this making the same power on 93 that the missile did on E?
SO HAPPY we finally have a car coming up with Evo-like numbers.
Old 10-14-2012, 10:16 PM   #25
xdrian
Member#: 104200
828 WHP BUGEYE
Congrats Xdrian
07 6-speed with a Spec Clutch Triple Disc
The missile has a 6262 iirc. I was just as surprised with the numbers that the car put down. I cant wait to see what we can do on E
Message Board Statistics All times are GMT -4. The time now is 06:45 AM.
