Old 10-10-2012, 11:27 PM   #576
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
ohhh, I see. I think the point is the gasket, that is sealing nothing.
bugeyetex is offline   Reply With Quote
Old 10-11-2012, 08:28 AM   #577
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Yes. They come with a gasket for some applications. This, and a majority others, don't need the gasket as they screw to a pipe fitting holding them up.
indytruckboy is offline   Reply With Quote
Old 10-13-2012, 10:26 AM   #578
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
See I have the exact opposite experiences as you guys. You deal with stupid customers, I deal with stupid mechanics. I'll just go down the list:
-when I got my car, the small dealership replaced the tranny and put too thin of a gear oil in. Blackstone tested and everything, now half my gears grind constantly
-timing belt job, months ago. During my inspection a few weeks ago they found a bolt finger loose on the timing cover.
-had my valve cover gaskets replaced because of internal leaking. Now they both leak externally, but "it's not the valve covers" -_-
-had my rear wheel bearings replaced by a local shop. I get to work the next day with smoke pouring out of my rear drums, the shoes were adjusted too far out. Also, they left my drivers side lateral link loose (I had to tighten), and 3 bolts on the rear differential loose, because they put in new axles too.
Thats not even all of them.
It's very frustrating. It's always awkward going back to tell them the mistakes. I honestly get paranoid when having people work on my car now. I try to do as much DIY as I can, but I just don't always have the right tools.
end rant/
ManualOverAuto is offline   Reply With Quote
Old 10-13-2012, 12:21 PM   #579
Jdub.csu
Member#: 283784
2013 EVO X GSR
You need to find a better shop. People make mistakes, and a good shop will own up to those and fix them as part of their warranty
Old 10-13-2012, 12:33 PM   #580
ManualOverAuto
Member#: 304662
Sedona red Pearl
That was 3 different shops. All 3 messed up.
-_-
Old 10-13-2012, 12:33 PM   #581
grknss
Member#: 44592
2004 WRX STI
Platinum Silver Metallic
+1 I have run into some bad shops too (the Subaru dealer near me, and unfortunately the only one within 250 miles).
grknss is offline   Reply With Quote
Old 10-13-2012, 12:51 PM   #582
Jdub.csu
Member#: 283784
2013 EVO X GSR
-_-
Use peer online reviews to help pick a good one. That's all I can really recommend. Also the better shops will have higher prices usually and a better warranty.
Old 10-13-2012, 04:49 PM   #583
rudymcskoody
Member#: 257618
2006 wrx
aspen white
-_-
That's why I do most thinks myself. If I can't do it I'll pay a little more to have Cobb do it.
rudymcskoody is online now   Reply With Quote
Old 10-13-2012, 05:06 PM   #584
ManualOverAuto
Member#: 304662
Sedona red Pearl
That's why when my transmission finally does go, I'm driving almost 2 hours for AndrewTech to fix it.
Old 10-13-2012, 05:32 PM   #585
rudymcskoody
Member#: 257618
2006 wrx
aspen white
That's a good plan.
Old 10-15-2012, 02:00 PM   #586
Mak Impreza
Member#: 6002
2001 Cobb Tuned IP
#1005 BRP
end rant/
If we screw something up here we have to pay to fix it. One guy here didn't check the lug nuts on a car and let it roll out the shop. So he's out 2000.00 because if came off the car and destroyed the quarter panel. So I understand the dumb mechanic thing.
You need to find a shop that will stand behind their repairs and tear into them if they are blaming something else.
Usually I'm nice to them until I hear a little bit of BS come out of their mouth then it's on.
I mostly DIY everything on the car because I know it's done right.
Some things I take it to the shop. (wheel bearings) just to get it done, but I'm that f-ing guy that likes to stand there and watch and look over the car meticulously before I leave.
Mak Impreza is offline   Reply With Quote
Old 10-15-2012, 02:21 PM   #587
stop_rallytime
Member#: 225515
end rant/
Stop being a kitty cat about life and ****ing learn something and do it your self then you won't run into stuff like that cause almost every shop tech will leave something off and if he says he never has hes a liar or he don't work on enough cars so rant your ass a chiltons manual and get busy then you can be mad at your self for sucking at life. Oh yeah don't have right tools? Buy them ****s is cheap as he'll if you don't go buying snap on or matco
stop_rallytime is offline   Reply With Quote
Old 10-15-2012, 02:27 PM   #588
WhiteKnightSTi
Member#: 169250
2001 Schweizer 300CB
(wirlybird)
I'll just leave this here:
Customer comes in complaining of a lack of power. Tech takes it for a test drive around the block and sure enough it can barely get out of it's own way. Brings it in and (thankfully) starts with the basics: The air filter...
Guess this is the new K&N Korn filtration system
WhiteKnightSTi is offline   Reply With Quote
Old 10-15-2012, 02:27 PM   #589
Jdub.csu
Member#: 283784
2013 EVO X GSR
Tools cheap? Lol um right maybe if you work on one brand of car only. Gtfo if your gonna **** talk about mechanics and generally bad mouth in this thread towards someone you do not know. Go back to OT
Half of the major pain in the ass jobs are when a diy got in too deep and now half the car is torn apart.
Are their ****ty shops? Yes that's why there is Internet peer review sites.
Old 10-15-2012, 03:07 PM   #590
ManualOverAuto
Member#: 304662
Sedona red Pearl
Lol.
I replaced my front ball joints, outer tie rods, and wheel bearings with one other friend, successfully.
I do as much a I can myself, but there are many specialty tools that I don't have, or have access to. Sure I could buy them, but why buy a $50-$100 tool just to use it once?
I could make a pretty big list of the things I've done myself so far, and I've only owned my car 1 year. Learn something? I'm here on NABISCO everyday, reading different things trying to learn about my car. Hell, most people my age (I'm 18.) don't even change their own oil, let alone all the other stuff I've done and research about.
.. and get busy then you can be mad at your self for sucking at life.
This made me laugh. Nice try though.
Old 10-15-2012, 03:12 PM   #591
Jdub.csu
Member#: 283784
2013 EVO X GSR
NABISCO the new NASIOC lol damn phone
Sorry guys no pictures haven't really had anything funny lately except a strange voicemail from a "new" customer.
Old 10-15-2012, 03:55 PM   #592
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
How does that even happen?
Ernest is offline   Reply With Quote
Old 10-15-2012, 04:00 PM   #593
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Its getting cold, and mice are looking for places to keep food.
Either that or some rather odd pranksters.
EvileyeZ88 is offline   Reply With Quote
Old 10-15-2012, 04:04 PM   #594
Jdub.csu
Member#: 283784
2013 EVO X GSR
Yeah seen that happen not with corn though. Love those rodents
Old 10-15-2012, 04:19 PM   #595
Mikey303
Member#: 335178
Lol prank for sure.
Mikey303 is offline   Reply With Quote
Old 10-16-2012, 06:00 AM   #596
mpristave
Member#: 284761
2012 WRX
I remember once seeing in a game online this guy saying he was laughing and wasn't mad. He happened to be my room mate and he was obviously furious.
mpristave is offline   Reply With Quote
Old 10-17-2012, 08:47 PM   #597
scx89
Member#: 269388
2011 Impreza WRX
obp
Trolling roommates are awesome. Good memories on them games
scx89 is offline   Reply With Quote
Old 10-17-2012, 10:47 PM   #598
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
I found an airbox full of dog food once. I walked into the waiting room and told the customer that they need to stop feeding their dog outside. They looked at me like I was some kind of psycho stalker.
It was an older caravan with the sideways air filter- poured all over the ground when I opened it. There was kibble all up under the hood 'blanket' too. By the time I emptied every thing out, there must have been 15lbs of food all over my bay.
Old 10-18-2012, 02:27 PM   #599
assasain
Member#: 323978
2004 WRX STi
Aspen white
Found this little gem when I was replacing the BOV that the previous owner put in, now got my stock BPV in place!
What you are seeing is 2 gaskets, yep.... he was smart enough not to remove the gasket and just figured it would work. Not to mention that the BOV wasn't even tuned correctly, I was leaking boost from the gasket and the BOV didn't hold boost. Yet another reason to no install BOV's unless you know what you're doing.
assasain is offline   Reply With Quote
Old 10-18-2012, 02:48 PM   #600
Jdub.csu
Member#: 283784
2013 EVO X GSR
2x thickness the gasket FTW lol. Nice fund
NASIOC, sometimes I hate you so much! Jard Off-Topic 50 08-25-2010 10:55 PM
sometimes i hate my job koolaideprived Off-Topic 17 07-01-2004 11:06 AM
Sometimes I hate suspense... LinuxGuy New England Impreza Club Forum -- NESIC 21 03-07-2003 10:03 AM
Sometimes I Hate Living Where I Do... S-K South East Region Forum 1 09-24-2002 11:51 PM
