Old 10-08-2012, 12:25 PM   #1
RealDealTarheel
Member#: 142447
**** Texas
Default IAM 0, low boost log inside
I'm scratching my head on this one and was hoping someone could look at my log and tell me where to start. The car is a 95 Impreza L with a JDM V8 engine and trans, JDM ECU. The car drives just fine but it won't get more than 7.8lbs of boost and the IAM will plummet to zero and I have no idea why as I'm not seeing any knock, or at least I don't think I am. I have a code for Rear 02 sensor low when I pull up learning view, no others.
The posted log is from a reset and I let the car idle for a few minutes before I went and made the log. Any help would be greatly appreciated.
https://docs.google.com/spreadsheet/...DJhOXVlUnhvYWc
RealDealTarheel is offline   Reply With Quote
Old 10-08-2012, 01:03 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
idle log was useless... try again
What we need to see is WHEN the IAM starts to drop. then we can go from there.
Old 10-08-2012, 01:05 PM   #3
RealDealTarheel
Member#: 142447
**** Texas
That's in there, it's rather long log. The logs consists of a start up after reset, idle, then a drive to the store.
Old 10-08-2012, 01:07 PM   #4
RealDealTarheel
Member#: 142447
**** Texas
Guess not, rehosting log.
Edit: log rehosted and linked in first post. I guess something got lost on the conversion to Xcel the first time.
Old 10-08-2012, 01:09 PM   #5
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
please convert it to google docs format... its easier to review
Old 10-08-2012, 01:27 PM   #6
RealDealTarheel
Member#: 142447
**** Texas
Conversion done, my apologies with the hosting, first time doing this.
Old 10-08-2012, 02:05 PM   #7
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
have a copy of your tune available? post it up in your google docs.
Old 10-08-2012, 02:15 PM   #8
RealDealTarheel
Member#: 142447
**** Texas
Stock V8 ROM. Stock down pipe, factory intake. Which is why I'm stumped. I can't see anything out of the way.
Old 10-08-2012, 02:24 PM   #9
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
well, you are also only logging a handful of monitors. Also, im sorry, im not a subaru superstar. I dont know what the stock "v8" rom is. maybe you could give me the actual rom code?
do you think next time you could atleast add your total timing?
Old 10-08-2012, 02:33 PM   #10
RealDealTarheel
Member#: 142447
**** Texas
I'll host the ROM, are there any other parameters I should log?
Old 10-08-2012, 02:38 PM   #11
RealDealTarheel
Member#: 142447
**** Texas
There we are, the stock Rom I pulled.
https://docs.google.com/open?id=0B-Y...HNybnl2a1NLdms
ROM ID: A4TE001B
Old 10-08-2012, 02:49 PM   #12
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
can you log your front O2, and total timing. mayb even fuel trim (A/F learning) if available.
Old 10-08-2012, 03:16 PM   #13
RealDealTarheel
Member#: 142447
**** Texas
A new log, I think that should have the parameters needed. Thanks for looking.
Old 10-08-2012, 04:14 PM   #14
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Running on a hunch here, try this rom. If it fixes your problem, we will discuss your issue.
https://docs.google.com/open?id=0B3k...TRidFNUY1ZhQlU
Old 10-08-2012, 04:23 PM   #15
RealDealTarheel
Member#: 142447
**** Texas
Okay thanks, I'll report back as soon as I get it flashed in.
Old 10-08-2012, 08:56 PM   #16
RealDealTarheel
Member#: 142447
**** Texas
Boost was unaffected and it's raining now so I can't pull up what the IAM is, but I'm guessing it's a zero. What was the change to the map out of curiosity?
Old 10-08-2012, 09:14 PM   #17
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
you seem to have a direct mechanical or electrical fault with the car. find your test mode connectors, and make sure they arent shorting out at all.
can you pull and post your DTC codes. Please post everything.
aside from that, the only other thing I could think of, would be for you to log your misfire counts. you might have a faulty knock sensor and the ECM could drop IAM based off misfire count.
Old 10-09-2012, 12:22 AM   #18
RealDealTarheel
Member#: 142447
**** Texas
Will do, I'll get a screen shot of learning view and log the new ROM. Thanks for the assist.
Old 10-13-2012, 05:57 PM   #19
leforce
Member#: 246246
Have you always had this issue, since you installed the engine? I had the same issue with a 16bit STi, IAM plummeted to 0 at idle before rough correction was supposed to kick in! I came to the conclusion that the issue must've been electrical, possibly test connectors short, I couldn't solve it & ended up zeroing advanced timing, adding the values to base timing.
leforce is offline   Reply With Quote
Old 10-15-2012, 01:18 AM   #20
04ScottWRX
Member#: 155412
2004 WRX Wagon
At time 32194 IAM 0's out without any feedback knock correction. the only reason for this would be electrical I would think. Perhaps there is a conflicting sensor input and the ECU is dropping IAM to 0 to activate failsafe mode---no boost control, failsafe open loop. Ususally you wold see the IAM decrement as the FBKC registered lots of negative correction--not just 0 out all of a sudden. That's the only thing I can think of @ this point--subscribing!! Good luck!
04ScottWRX is offline   Reply With Quote
Old 10-15-2012, 05:05 PM   #21
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Did you undo the green test mode connectors...
