Old 08-20-2003, 12:20 AM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default clutch compatibility between JDM /USDM
okay. so having to find this out on my own, this is what ive learned (rallispec = smart)
the gc8 turbo flywheel is 225mm bolt pattern, it takes 225mm clutch disc, and pressure plate
gda turbo flywheel is 230mm, 230mm clutch disc and pressure plate for 230mm.
newer = bigger.
throwout bearing, pilot bearing are compatible,
im guessing that old ej22 legacy has the same clutch setup as the impreza GC8 turbos, so it would use 225mm bits. can anyone verify that / measure it?
if u want to use GDA complete clutch setup (incl. flywheel) with GC8 turbo car trans, it shoudl work just fine. other way around too, if u are in a pinch or weird funny situ.
cools
h
supermoose is offline   Reply With Quote
Old 08-20-2003, 01:25 AM   #2
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
GC8 turbo? aftermarket? one thing is Gc8 is push type clutch and US WRX and JDM WRX are pull type clutch. Totally different design. Pressure plates are different and throwout bearings. Also, the slave cylinder for clutch is different. Oh ok i guess you are talking about legacy tranny not 2.5rs. Still helpful info.
AWJunkies is offline   Reply With Quote
Old 08-20-2003, 03:12 AM   #3
supermoose
Member#: 9093
swap starr
Default gc8 turbo
gc8 turbo is refering to JDM where real gc8's exist. there are no actual gc8's that were USDM sold.
im talking about the gc8 body style Japense turbo transmission taht came on the turbo car.
just to clear it up.
all turbo trans have the same setup.
h
Old 10-15-2012, 09:09 PM   #4
Jordan Gerein
Member#: 318939
96 Subaru Wrx Sti
I need a new clutch slave cylinder for my 96 jdm gc8 sti. does anyone know the part number of the slave cylinder I need?
Jordan Gerein is offline   Reply With Quote
What's the differences between JDM and USDM WRX's brakes? leoflc Brakes, Steering & Suspension 7 06-15-2005 06:36 AM
Difference between JDM and USDM exhaust? txl146 Newbies & FAQs 14 03-24-2005 03:37 PM
Differences between JDM and USDM STi up pipes Edvig Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-17-2004 06:02 PM
Differences between JDM and USDM Exhaust iNfEk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-22-2003 12:41 AM
differences between JDM and USDM mirrors? silverF4turbo Interior & Exterior Modification 4 05-20-2003 09:21 PM
