![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#26 |
Member#: 125739
South East
Vehicle:Who needs brakes? Call: 919-420-0021 |
We made some to work w/ the SVX rotor drilled to 5 x 100.
Only a few people asked about it. Making it is no problem at all - selling it is another story completely.
#27 |
Member#: 60135
SCIC
Vehicle:2011 WRX WR Blue |
I must say, if there was a bracket to use the z32 aluminum calipers with STi or LGT rotors, I probably would have gotten them.
#28 |
Member#: 222879
Vehicle:2003 WRX Silver |
I'm working on a cheap 350mm and 380mm solution using 6 piston calipers for the front. The rotors will be the most expensive part if they are made for this application using aluminum hats, otherwise a redrilled rotor could be used.
Cant decide on the calipers yet but i do need someones old busted WRX hub for measurements. I'll pay shipping of course and probably make more than one set of brackets which you will get at cost. |
#29 | ||
Member#: 220619
Vehicle:04 wrx wagon silver |
#30 | |
Member#: 125739
South East
I need a caliper to mess with. Should I get an AL or Cast Iron? I think the AL one are getting rare. -Ken |
#31 | |
Member#: 220619
#32 |
Member#: 220619
Is there a difference in master cyl from sliding caliper wrx's to the 06-07?
#33 |
Member#: 60135
SCIC
Well, what's really the driving force behind this? When I think of this particular brake mod, I look at it as a poor man's upgrade costing similar or less to Subaru 4 pots, but benefit from a larger rotor.
I can see where there would be lack of motivation in doing this if it cost similar to second hand STi Brembos. |
#34 |
Member#: 220619
Wrx 4 pots, useless ricer upgrade. You gain very little if anything at all other than a large selection of pad types.
Sti brembos, great, forced to use 17+ inch wheels, very expensive. Z32+lgt rotors. Can fit 16's, Same pads as Subaru 4 pots, calipers can be found for $150 for the set, rotors about $120. Rotors are a good bit larger than Wrx OE, can handle more heat, not stuck with only 17 inch plus wheels. |
#35 |
Member#: 125739
South East
I ordered some calipers from Cardone. $69/each + core.
I have my old proto brackets from the LGT setup so those should be a good starting point. Calipers - $200 Brackets - $150ish at least - That's $200 less than Brembo's give or take. |
#36 |
Member#: 60135
SCIC
Well, Ken, I may ditch my Racing Brake 4 pot fronts just to try this out for isht and giggles.
#37 |
Member#: 220619
The only "modification" that needs to be made is Subaru brake lines use a banjo bolt. Nissan uses a flare nut. Just get a small easy out and it will pop the brass flare out of the Nissan caliper. This takes seconds to do. I also sanded down the casting surface with sand paper and a block of wood to ensure the banjo washer sealed correctly.
#38 |
Member#: 220619
To save on cost and parts being left on the shelf you could sell them as "made to order"
Also I would start an interest thread about these. This coming from a reputable vendor would get the ball rolling and help with people's general distaste of new ideas around here. |
#39 | ||
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
If you can get an affordable way to make the Z/2.5GT setup work, that's great. I might even change my setup when it's time to replace my DBA rotors. But there's no need to go overboard trying to make your case about why it's better than the other options out there. Quote:
Pat Olsen Last edited by Patrick Olsen; 10-17-2012 at 12:16 PM. |
#40 | |
Member#: 125739
South East
That's right - I forgot about that. |
#41 |
Member#: 60135
SCIC
Will the banjo bolt thread in there just fine?
#42 | |
Member#: 220619
Also, my comment was aimed more so towards the fact that people seem to do that swap simply for looks alone. As for the global Z brackets. Correct me if I am wrong but those were primarily over seas, no? I can't remember what rotor they used but I seem to recall rotor machining being needed? After all of that you are close to an Sti swap cost. Machine cost, over seas shipping cost, z32 calipers were not nearly as cheap either. Because of the hassle and the fact their domestic market had a plethora of options (both oem and aftermarket) readily available is the reason they died off. Onto the topic of fear of change or something new. All I personally ever see if 80% of the crowd following the status quo, best example. "dude! That's so dumb! Why would you get rid of your access port IT'S AMAZING ZOMG LIK TOTS MA GOATS!" oh yea? My open source cable cost me $50, sold the ap for $200, flashed a known good stg2 base map, gained substantially more power, recorded more agreeable af mixtures, went from 19mpg to 25mpg. |
#43 | |
Member#: 220619
#44 |
Member#: 135978
Is this for the fronts only or all corners?
#45 |
Member#: 135007
Vehicle:2002 Wrx Sedan Aspen White |
Personally I'm dying for some alternatives. Brembo's are a seriously flawed product. On the track the dust seals burn up. The only sleeved bolt seems to be the banjo. The mounting holes are prone to seizing and stripping. The bleeders likewise. Even replacing the OEM bleeder screws are difficult ($65 each... really?) A single rear 2 piston caliper is $700 from the dealer. The OEM rebuilt kit is 100 for just the fronts.
I'm in the middle of rebuilding mine and I'm really not happy. I think I should have gone with Wilwood. Screw dust boots! |
#46 |
Member#: 60135
SCIC
http://forums.nasioc.com/forums/show....php?t=1567707
It appears the Nissan 2 pot rears will bolt up with an adapter or 2 pot backing plate, but it sits out further. I'm sure another bracket could be made that would make the caliper sit in about 3mm closer to the hub to correct that. Either that or find another rotor. |
#47 |
Member#: 125739
South East
I've got the calipers, my old SVX sized bracket, and a knuckle and of course a rotor so I can start fitting this up.
#48 |
Member#: 196920
South East
Vehicle:03 Wrx WRB |
#49 |
Member#: 267863
SCIC
Vehicle:2002 WRX Sedona Red Pearl :) |
I'd be down for a group buy. I've had the calipers. I've just been trying to find some brackets.
#50 |
Member#: 125739
South East
Working on it as soon as possible
| Thread Tools | |
| Display Modes | |
| WTT WRX front rotors/brackets for RS rotors/brackets + WTB WRX rear caliper brackets | Jard | MAIC Private Classifieds | 9 | 11-24-2009 09:38 AM |
| WTB: 02+ WRX Front Caliper Brackets, H6 Rear Caliper Brackets | JDMFLCL | Private 'Wanted' Classifieds | 4 | 10-30-2009 01:19 PM |
| WTB: Front WRX caliper bracket and rear Legacy caliper bracket | 92XJET | MAIC Private Classifieds | 0 | 11-20-2007 10:37 PM |
| WTT: I want YOUR Rs rotors and caliper bracket for MY Wrx caliper bracket and rotors | scobaru | MWSOC Private Classifieds | 6 | 12-10-2006 08:02 AM |
| WTB: WRX Caliper Brackets + H6 Caliper Brackets | Krelkor | Private 'Wanted' Classifieds | 11 | 07-12-2004 03:28 PM |
