Welcome to the North American Subaru Impreza Owners Club Friday October 31, 2014
Old 10-04-2012, 08:04 PM   #51
cineris
Member#: 263329
2011 Impreza WRX
Denatured alcohol you say... that's awesome, thanks for the heads up. Do I need to re-coat it with anything?
cineris is offline   Reply With Quote
Old 10-04-2012, 09:39 PM   #52
Jdub.csu
Member#: 283784
2013 EVO X GSR
No unless the outside is hazy
Jdub.csu is offline   Reply With Quote
Old 10-04-2012, 09:57 PM   #53
cineris
Member#: 263329
2011 Impreza WRX
Last question: does baking ruin anything? I obviously never baked with the lens against the oven metal but my friend is convinced that's what the inside haze is from. I think he's wrong.
Old 10-04-2012, 10:07 PM   #54
Jdub.csu
Member#: 283784
2013 EVO X GSR
So you have opened the headlights before? Or did I read that wrong?
Old 10-04-2012, 11:16 PM   #55
cineris
Member#: 263329
2011 Impreza WRX
Yeah the light has been opened before.
Old 10-04-2012, 11:19 PM   #56
Jdub.csu
Member#: 283784
2013 EVO X GSR
Open them up, clean them, then use new sealant from lightwerks ect and bake them close =)
Old 10-05-2012, 12:54 PM   #57
itr.#1446
Member#: 162447
03 Wrx
Sonic yellow
Originally Posted by Thomistopheles View Post
Here's what I recently started doing to restore headlights. I got this from a detailing forum, the results last a long time.
http://www.autogeekonline.net/forum/...lant-idea.html
Wetsand 400-2000 grit
Polish w/ Meguiars M105
Polish w/ Meguiars M205
IPA wipe
Coat with a 50/50 mix of Helmsman Spar Urethane and mineral spirits
Let it dry and you're done.
I've been using the same method just using the 3m kit comes out perfect!
itr.#1446 is offline   Reply With Quote
Old 10-16-2012, 07:20 PM   #58
vms150
Member#: 172917
2004 WRX
I tried using alcohol to clean the INSIDE of the lenses.... NEVER DO THIS! It melted the coating on the inside of the lens and I had do split the housing, sand the lens down and clear coat . Hugh PITA for a tiny bit of haze on the inside.
vms150 is offline   Reply With Quote
Old 10-16-2012, 08:19 PM   #59
Jdub.csu
Member#: 283784
2013 EVO X GSR
Originally Posted by vms150
I tried using alcohol to clean the INSIDE of the lenses.... NEVER DO THIS! It melted the coating on the inside of the lens and I had do slip the housing, sand them down and clear coat them. Hugh PITA for a tiny bit of haze on the inside.
Melt? Dafaq? I've used it plenty of times (denatured alcohol)
Old 10-16-2012, 09:10 PM   #60
burke420
Member#: 254983
05 Impreza STI
Aspen Wht PG+K
this is an guess... retrobright?
burke420 is offline   Reply With Quote
Old 10-16-2012, 09:40 PM   #61
vms150
Member#: 172917
2004 WRX
Jdub - Yup, the alcohol literally melted the inside coating. I should have taken a photo before I sanded it down.
burke - retrobright?
Old 10-16-2012, 09:59 PM   #62
Jdub.csu
Member#: 283784
2013 EVO X GSR
Strange never seen that happen. What headlights where they? Aftermarket?
Old 10-16-2012, 11:38 PM   #63
vms150
Member#: 172917
2004 WRX
Nope, Stock 2004 wrx headlights
Old 04-07-2014, 04:00 PM   #64
romanboy
Member#: 356242
Originally Posted by hybrid gti 2 View Post
Just for your benefit. I will post this as some can't use the search button. The oxidation comes from the uv coating. The only way to remove it effectivly is to sand it off and then polish the plastic. Then you have to consider how to deal with the uv coating now being gone.
Here is what I did and suggest. I used the 3m headlight restore kit. For $20. Then I used headlight film to prevent further oxidation, $50. Haven't touched the headlights since I did this. As well they look great.
what headlight film did you use?
romanboy is offline   Reply With Quote
Old 04-07-2014, 04:33 PM   #65
Jdub.csu
Member#: 283784
2013 EVO X GSR
ReNuLite
Old 04-07-2014, 04:39 PM   #66
Paidfor
Member#: 267815
Be in awe
dont hate .)
1000 grit......wash with soap.....dry
Apply minwax clear polyurathane ( sold at lowes for wood products) with paintbrush.
As it dries all the little runs just dissapear. Ive been haze free for over a year now vs i was applying a bs headlight resto sealant every other week!!!
Old 04-07-2014, 06:03 PM   #67
Phil206
Member#: 308713
2006 WRX Wagon
SGM
Another for the 3M kit. Got mine looking new again with just the kit and a cordless drill.
Phil206 is offline   Reply With Quote
Old 04-20-2014, 11:43 PM   #68
EmilyG3714
Member#: 388422
2007 Impreza WRX
Gray
Really fine sandpaper for buffing works great on the older headlights!
EmilyG3714 is offline   Reply With Quote
Old 04-21-2014, 03:10 AM   #69
k0ukii
Member#: 204429
Got pics? Did you use
Clear SatinClear Satin
or
Semi Clear GlossSemi Clear Gloss
k0ukii is offline   Reply With Quote
Old 04-24-2014, 11:44 PM   #70
romanboy
Member#: 356242
Originally Posted by k0ukii View Post
Got pics? Did you use Clear Satin or Semi Clear Gloss?
I would like to see those too! Also where do you live?
Old 04-25-2014, 03:48 PM   #71
Omali89
Member#: 385032
Bump.
Omali89 is offline   Reply With Quote
Old 04-26-2014, 03:14 AM   #72
Rymaster
Member#: 296277
2002 Impreza WRX
I'm in for the pixs too xD
Rymaster is offline   Reply With Quote
Old 04-26-2014, 04:48 AM   #73
simo7708
Member#: 387512
Anyone try this? http://www.autogeek.net/dia-plastic-liquid-armor.html
Looks like it would be a good preventative measure to stop headlights from hazing in the first place
simo7708 is offline   Reply With Quote
Old 04-26-2014, 07:04 AM   #74
ltd.wrx_Matt
Member#: 361764
2012 Wrx Ltd
Grey Metallic
Tooth paste is the secret.
Fluoride gets rid of the oxidation. Ore wipe new.
But then your car won't be minty fresh!
ltd.wrx_Matt is offline   Reply With Quote
Old 04-29-2014, 11:17 PM   #75
reeson3
Member#: 389460
Originally Posted by 6Star_McCoy View Post
+1 on this kit, it rocks..
reeson3 is offline   Reply With Quote
