Old 10-17-2012, 12:24 AM   #1
stiltz357
Member#: 311373
2009 impreza 2.5i
dark grey metallic
Default ecuflash being difficult
im having trouble with ecuflash reconnizing the moddified rom from romraider. i have updated romraider, ecuflash, java, and all the def. files. i started out by reflashing my ecu with a different ecu id so i could use the experimental def. to tune that worked fine then i open the rom in romraider editor and made a couple of changes and saved that rom under another name. then i have to but this file into a hex converter so i can open it in ecuflash but when i try to open it it says the def is not found. also i cant edit it wit ecuflash either cuz the only metadata that comes up is ecu info. idk if anyone has had this problem before but its driving me nuts driving to figure it out so any help would be apperciated.
stiltz357 is offline   Reply With Quote
Old 10-17-2012, 12:38 AM   #2
Rich_D
Member#: 244913
2006 WRX
Make sure you have saved the file as (file name).hex otherwise it won't recognise it..
Rich_D is offline   Reply With Quote
Old 10-17-2012, 01:39 AM   #3
stiltz357
Member#: 311373
2009 impreza 2.5i
dark grey metallic
thanks i feel extremely stupid just added .hex and now theres no problem
Old 10-17-2012, 04:58 AM   #4
Rich_D
Member#: 244913
2006 WRX
No worries, glad I could help!
Message Board Statistics All times are GMT -4. The time now is 11:50 PM.
