Old 10-17-2012, 01:42 AM   #1
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
Default Fine Learn/ Feedback Knock Getting Worse
So I've been dealing with eric minehart at torqued performance tuning dealing with e-tunes via opensource. I recently went stage 2 with one of his maps and for some reason my car is having odd knock that he can't even explain. We went through 5 different versions of his map and still getting weird knock. Now he's telling me that I should get colder spark plugs (already ordered), and he says that my car has always never liked timing (going from his stage 1 to stage 2), but why would my car act so differently than anyone elses 2011 wrx. I've looked at other logs from 2011s running less mods and they're fully capable of running more timing. Logs are included and are labeled. What puzzles me even further is after his first revision I was only getting minor feedback knock and now with his last revision I'm seeing way more knock. Any input is appreciated as always.
Power Mods
AEM CAI
Cobb DP w/ Cobb Heatshield
1st revision logs
https://docs.google.com/open?id=0B14...ko0M2g1WGRHWFk
https://docs.google.com/open?id=0B14...2NsMHJpMVVXeWs
https://docs.google.com/open?id=0B14...WczNGVRa2xzLTg
https://docs.google.com/open?id=0B14...kpSNkNoTkZ5QWc
5th revision logs
https://docs.google.com/open?id=0B14...ktWU0FKenJtT2c
https://docs.google.com/open?id=0B14...TA4bG05Zks5TzQ
https://docs.google.com/open?id=0B14...kVnQlNRLUM1Wnc
https://docs.google.com/open?id=0B14...m9pQks1LURncFU
freddy121389 is offline   Reply With Quote
Old 10-17-2012, 04:51 AM   #2
chappell943
Member#: 297718
2001 V7 Sti Prodrive
Eric just tuned my Sti bugeye and did a great job so hopefully you can figure this out, are you using a wideband for logging? Also you need to set permissions to public so we are able to view logs.
chappell943 is offline   Reply With Quote
Old 10-17-2012, 09:28 AM   #3
quazimoto
Member#: 70395
Well if it's always been an issue with timing that is out of the ordinary I would maybe try readjusting and re-torquing the knock sensor to rule that out. Maybe clean up and retighten the factory engine grounds as well. Just a thought.
Old 10-17-2012, 10:05 AM   #4
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
do you think all of that could have went bad that fast? I drive a 2011 wrx I've only had it for a year.
Old 10-17-2012, 04:34 PM   #5
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Take off the heat sheild and see if it helps at all.
Old 11-05-2012, 11:11 AM   #6
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Also, get him to turn of AF#3 correction. that Rear O2 keeps ramping up as your logs go on. But i also agree with Blaze.... that heat shield tends to rattle... specially when one of the bolts crack that piece of metal. seen it a few times.
Bamofo is offline   Reply With Quote
