Old 10-14-2012, 06:03 PM   #1
st205wrx
Member#: 193253
08 wrx 322/352
wrb
Default Jr Tuned 08 WRX Dyno Results
I have owned this vehicle since December of 2011 from a local nasioc member, well 3k later the main bearing goes bye bye. So as a broke as student i decided just to do a small semi built motor just so i can drop in a little bigger turbo and have some fun auto crossing while finishing my degree. It took roughly three months for the motor build and shortly after install during break in period the transmission bearing decided to give out. This took another month in a half for the rebuild back to stock. Now after the rebuild of the transmission the car was finally dyno tuned with a tad bit bigger turbo and here are the results.
Event: First Dyno Tune
Running Condition: 85F and 30%humidity
Car: 2008 Wrx 4D
Tuner: Jr Tuned
Dyno: Dynojet
Trans: Stock
Gear: 3rd
Peak Hp at RPM: 322.10 awhp @ 5700 rpm
Peak Wtq at RPM: 351.17 awtq @ 3800 rpm
Fuel: 93 octane
Target boost: 20 psi
Modification:
Forged internals Manley piston
ACL race bearing
Heads resurfaced
Unknown brand TD05-18g 7cm Mitsubishi internals and rebuilt by Pavelís Racing Engines
Stock Flywheel
Exedy Clutch
Grimmspeed Bcs
IPR tmic
Perrin short ram
Perrin turbo inlet
Megan racing catless downpipe
Megan racing mid-pipe
SPT dual tip catless
ID 1000cc
Walbro 255 fuel pump
Tomei el headers
AP up-pipe
Stock bpv
All exhaust pipes are heat wrapped
Audio
SONY XPLODE SPEAKERS FRONT AND REAR W/ TWEETERS
KICKER AMP FOR SPEAKERS
BOSS BASS1200 SUBWOOFER W/ AMP
Lights
HIDs for the headlights and fogs
I would like to thank P&L Motorsports for the transmission rebuild, Six Star for the motor build, Jr for the nice tune, and Pavel's for the nice turbo.
Thank for looking
st205wrx is offline   Reply With Quote
Old 10-14-2012, 06:08 PM   #2
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Nice. How much of the car did you disassemble to pull that motor? It looks like front fenders are off in the pics.
slowgenius is online now   Reply With Quote
Old 10-14-2012, 06:10 PM   #3
st205wrx
Member#: 193253
08 wrx 322/352
wrb
i took the whole front end off so that way i wouldn't seem anything up cosmetically, but in all you only need to take the hood off and you can pull it out that way. I was just super paranoid
Old 10-14-2012, 06:38 PM   #4
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Lol no problem. I didnt have to remove the hood on mine to pull the motor.
Old 10-14-2012, 06:41 PM   #5
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
Looks nice! Seems to spool kinda late for a 18g 7cm though, probably better on the street. Nice numbers regardless!
ColeBerkenbile is offline   Reply With Quote
Old 10-14-2012, 06:48 PM   #6
st205wrx
Member#: 193253
08 wrx 322/352
wrb
i asked for a mild tune... but thank you it is fun on the streets.
Old 10-14-2012, 08:24 PM   #7
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Seems like a nice conservative tune. Graph looks strong
Old 10-14-2012, 08:52 PM   #8
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Glad your happy with the car.
Yea the tune was very soft on the car, it was his request. I usually keep the spool slow on the 5psd 2.5 cars.
Old 10-15-2012, 05:18 AM   #9
st205wrx
Member#: 193253
08 wrx 322/352
wrb
Very happy with the work that you have done... Your reputation is truly as good as every person says it is. Great job once again, I will be coming back to you some time soon for e85 hopefully
Old 10-17-2012, 07:49 AM   #10
Wrx_FoSho
Member#: 277108
09 Wrx Hatch
Grey
nice numbers. Getting mine retuned next week for e85 at P&L
Wrx_FoSho is offline   Reply With Quote
Old 10-17-2012, 09:32 AM   #11
st205wrx
Member#: 193253
08 wrx 322/352
wrb
thank you
i would like to do that some time in the future... i will need money for a need money for a new trans lol
hope all goes well on your tune
Old 10-17-2012, 04:21 PM   #12
NoGraffix
Member#: 276209
I am Rub
Function>Form
E85 is a must! After driving my 08 wrx witha vf39 on E85 for the past 10 months I will never go back to pump gas with a subaru. The gains are just fantastic (especially the torque), the gas milage is a bit crappier, but for the price it still costs just about the same (if not a little cheaper) $/mile as pump gas, and I log regularly and find virtually no knock.
NoGraffix is offline   Reply With Quote
Old 10-17-2012, 05:37 PM   #13
st205wrx
Member#: 193253
08 wrx 322/352
wrb
the only problem is that i go to siu from chicago thats 350+ miles and not every station has e85... so i need to save for a new ap and have two different maps. it would just be better which for when i want more power (or if i am broke as **** lol) but then have to better mpg on pump
Old 10-17-2012, 07:21 PM   #14
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
if it were available. id run e85. to date, my county has 1 station i know of that sells e85. doesnt make sense for me. also if i were to go on a long trip, i wouldnt want to search for a gas station to fill at. ill stick with 93 octane, its available all over.
Old 10-18-2012, 06:27 AM   #15
st205wrx
Member#: 193253
08 wrx 322/352
wrb
E85 would be run for auto crossing for sure.
Old 10-19-2012, 09:39 AM   #16
NoGraffix
Member#: 276209
I am Rub
Function>Form
understandable, but it's easy enough to have another map for 93. If I'm going to go on a long trip I'll just flash my 93 map, but living in chicago there are tons of e85 stations. I've got 3 that I use regularly (one by the house, on in between work and home, and one by work) so it's never an issue. I DD my car 60 miles a day to work and back without issue .
Old 10-19-2012, 09:40 AM   #17
NoGraffix
Member#: 276209
I am Rub
Function>Form
Or you can just buy a tactrix cable for about $170 (cheaper if used). Not sure if Jr tuned you open source or not but I went this option because it's cheaper then the AP and can do anything an AP can do.
Old 10-19-2012, 12:32 PM   #18
Wrx_FoSho
Member#: 277108
09 Wrx Hatch
Grey
Except Launch Control Rub
Old 10-19-2012, 01:09 PM   #19
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
But it does do the less exotic non-rub launch control
Mike Costin is offline   Reply With Quote
Old 10-19-2012, 06:04 PM   #20
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
I will say the AP and its support is far better then subaru OS available
Old 10-20-2012, 09:53 AM   #21
st205wrx
Member#: 193253
08 wrx 322/352
wrb
the car was tuned on open source... i think i am just going to save up some money buy some new parts and have it retuned by Jr with an ap and have two different maps.
i have an ap from my 05 wrx and i love that device like no other... i use it all the time
Old 11-08-2012, 10:43 AM   #22
NoGraffix
Member#: 276209
I am Rub
Function>Form
You can get launch control with OS
Jr what exactly do you mean?
Old 11-08-2012, 12:55 PM   #23
st205wrx
Member#: 193253
08 wrx 322/352
wrb
Should have asked for launch control then
Old 11-08-2012, 04:23 PM   #24
NoGraffix
Member#: 276209
I am Rub
Function>Form
I thought you wanted you transmission to last
Old 11-08-2012, 05:13 PM   #25
st205wrx
Member#: 193253
08 wrx 322/352
wrb
Lol i do but i would like to track the car once or twice to see what it can run
