#1 |
Member#: 322736
Vehicle:1996 legacy (sti) white |
Custom 1996 White Subaru Legacy BD5
Mods: Engine: JDM STi Ver-4 turbo cross-member Custom Forged and Coated RYNOMOTO/ROSS Coated pistons EJ257 BLOCK AND CRANK Balanced rotating assembly ROSS HD rings, file to fit each bore Bored and Honed with Torque hone plate using ARP head studs ACL Race series bearings, properly clearance STI Rods with ARP Rod bolts installed ARP Head Studs STI Stock Head Gaskets Gates Racing Timing Belt 08 STI OIL PUMP Perrin intake & MAF tubes TXS (K&N) shorty filter Mishimoto radiator Tranny/Bushings 06 STI 6 Speed transmission swap ACT 6 puck w extreme pressure plate Clutchmasters flywheel Front WRX axles Cobb rear poly shifter bushing Group N trany mount Subimods front delrin shift bushings Group N race rear diff mount bushings Whiteline rear diff crossmember bushings Full hein joint rear end Whiteline front end Rear-End: 06' STi rear-end complete: R180 (3.54), axles, subframe, stainless ebrake-lines, etc. 04' STi rear knuckles, hubs, bearings, 5x100 Fueling: Walbro 255 fuel pump Wichunter 945cc injectors Perrin v2 fuel rails w lines Aeromotive fuel pressure regulator Summit racing fuel filter + fittings TGV delete block off plates (rods removed and honed) Turbo: Blouch Dominator 3 Turbo w 10cm housing TXS Front-mount Intercooler painted flat black APS 50/50 Bov Exhaust: Agency Power unequal length header GrimmSpeed 38MM VBand external dump up-pipe (Catless) Tial 38mm VBAnd EWG (1-bar spring) Helix catless downpipe Custom catback exhaust Kartboy poly exhaust hangers Suspension: Cusco front strut bar STi (04) Alum front control arms Megan street coilovers (revalved by feal 8 front 6 rear) WhiteLine rear crossmember lockdown WhiteLine Anti-Lift Kit MINES front chassis brace Perrin 22mm front sway w/endlinks (STi width) Perrin 22mm rear sway w/endlinks (STi width) Perrin adjustable lateral links Cusco trailing arms (txs) Brakes: 04' STi Brembo's 4pot/2pot STI rotors/pads (5x100) Stainless Steel lines Wheels/Tires: Rota G-Force Gold 17x7.5 Bridgestone Potenza RE070 Electronics: 03' WRX vehicle harness+ecu (merged by zephr) Open Source Tuned Defi Link with boost/egt/oil-pressure(60mm white) Interior: JDM WRX v4 seats Custom made carbon fiber side rails Sti jdm black floor mats Custom fit indash gauge pod Exterior: JDM grill JDM custom reversed hoodscoop JDM projector headlights JDM projector foglights JDM bumpers JDM side skirts Custom made carbon fiber diffuser to fit jdm bumper The car dyno'd at 404AWHP at 21psi on 93 pump gas!!! http://s1051.photobucket.com/albums/s425/blaster2900/
#2 |
Member#: 306478
South East
Vehicle:2012 WRX limited 305whp/360tq TSM tuned |
thats one badass sleeper!!
only the brembos give you a hint there might be something lurking under that hood i like it. |
#3 |
Member#: 322736
thanks lots of time and hard work did everything myself from ground up got shell originaly with no doors fenders or anything
#4 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
go to photobucket and rotate the pic. and if you hover over the thumbnail, just click n past the [ img ] code link at the bottom to embed
#5 |
Member#: 167338
Vehicle:2000 Aspen rs Rotated mass |
sick! i love BD's
mind you if i ask what heads and cams are you using? |
#6 |
Member#: 303231
Vehicle:2008 WRX Dark Metallic Grey |
jesus...
#7 |
Member#: 320012
International
Vehicle:1994 legacy gt white |
very nice numbers and mods blaster im impressed, i got your twin but its definately not sleeper version in appearance lol
http://s828.photobucket.com/albums/zz209/subarusolja/ Last edited by stilegacy2.2; 10-18-2012 at 02:04 AM. |
#8 |
Member#: 142029
Vehicle:2013 Fozz 2004 STi, 1991 Miata BRG |
I love BD Legacys.
#9 |
Member#: 193253
Vehicle:08 wrx 322/352 wrb |
sick set up... i love the sleeper look
#10 |
Member#: 108163
Vehicle:2005 STI - 10.8@129 more in the works! |
...tell me the video isn't this thing burning to the ground
#11 |
Member#: 82633
Vehicle:'08 WRX STI Silver |
Sick BD. I had a 96 with some JDM parts and had painted WRB. Rust ate the car before I ever got to doing a turbo swap. Miss that car every day. Congrats on an awesome build!
#12 |
Member#: 322736
Thanks lot of hard work I had boughten the red 1 on here about a yr back and audio company installed audio wrong n burned it to ground... 1 time I don't do everything myself so I took the motor n trany out n built everything around it from ground up cuz that's all that was save able and built this monster lol it's def a fun ride just needs a paint job and gonna do a big maf n turn it up to like 26 hopefully see 450+ maxed out my maf at 21
#13 |
Member#: 322736
And I'm useing sti heads just not using the avcs Cuz it's got wrx throttle body (drive by cable) so it's wired as wrx
