Old 05-24-2012, 12:19 PM   #1
tornado542
Member#: 280370
2012 Sport Premium
Ice Silver Metallic
Default [OFFICIAL TSB ISSUED!!!!] DIY 2012 Impreza seat squeak fix!
EDIT 11/5/12 - OFFICIAL TSB FROM SUBARU! YAY!!!!
https://docs.google.com/open?id=1rJ-...EogzrJQf5TCTUQ
This seems to be a common subaru problem so I took the seat apart and what did I find...
After unzipping the seats, there is a visible spring that prevents the seat back cushion from falling through the seat frame. This spring is attached to the frame by 6 hooks ( 2 at the bottom, 2 at the middle and 2 large ones at the top near the head rest area. It is also secured by 4 O-rings(2 attached to seat cover and 2 attached to wiring inside seat back foam)
The squeak comes from the top 2 hooks that attach the spring to the frame, the subaru insulation (paper LOL) in this area comes off and rubs metal on metal inside the hook loops in the frame. This causes squeak, and it fix it just pull out the spring and insulate the 2 hooks at the top of it with tape or cloth or something. I used duct tape and it worked fine. See below for a diagram i drew up.
Here is the bushing part label!
tornado542 is offline   Reply With Quote
Old 06-19-2012, 03:39 PM   #2
tornado542
Member#: 280370
2012 Sport Premium
Ice Silver Metallic
bump for all having this issue!
Can we sticky this plz??
Old 06-19-2012, 03:56 PM   #3
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
This is what i like to see people that instead of complaining, solve issues.
auskip07 is online now   Reply With Quote
Old 06-19-2012, 03:58 PM   #4
tornado542
Member#: 280370
2012 Sport Premium
Ice Silver Metallic
For the Reccord...A New 2012 Impreza seat has a backorder lead time of 4 months, and SOA likes to tell dealers that squeaks arnet covered by warranty...
...so do this fix...dont wait for SOA and complain
Old 07-02-2012, 03:19 PM   #5
Furiousd1983
Member#: 295099
2013 Not so Hot HB
Talked to the dealer while I was there this afternoon. Instead of waiting 3-4 months for a seat back. They are just going to give me a loaner and tear into the seat and fix the squeak.
Furiousd1983 is offline   Reply With Quote
Old 07-07-2012, 01:10 PM   #6
79letour
Member#: 302570
2013 XV
DGM!
Mastro Subaru just installed a new seatback. When they were done they showed me the old one. Just like tornado said. Top two hooks had worn through the paper. The seatframe has fiber insulation on the middle two points of the seatback, but the top and bottom are just metal on metal separated by paper. The awesome tech over at Mastro actually took the extra time and made little foam rubber pieces to go under all six attatchment points for the spring. The old spring was also bent on one corner it looked like. The seat now feels and sounds right again. For anyone wanting to avoid waiting on a dealer or soa- Tornado has it nailed. Thanks for an excellent thread and for spending the time to show folks the fix for what I'm sure will be a common annoyance. Although I didn't do it myself- thanks anyhow.
Old 07-12-2012, 12:23 PM   #7
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Has anyone bothered doing this to the passenger seat too? I assume they both have the same design issue, right?
Old 07-12-2012, 12:45 PM   #8
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK, I know I'm not the sharpest knife in the drawer, so I guess I need some more explanation about this procedure. I just went out to my car (during my lunch hour) to check the seat out. I got into the back seat, and see the two zippers going up the left and right edges of the seat. So I unzipped those, but the zippers end approximately 6 inches (or more) below the top edge of the seat, where the headrest is, and where the hooks are that are causing the squeaking. Also, the bottom edge of that center panel of fabric was still connected along the bottom edge of the seat, so I couldn't raise the fabric panel completely out of the way.
How do you get at the the area of the seat where the top hooks are? I simply couldn't reveal the innards of the seat well enough to gain access to the top hooks.
Sorry for being such a dummy!
Old 07-12-2012, 01:07 PM   #9
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Like all upholstry everything is a very tight fit so no wrinkles appear in the fabric. It will take some muscle to get of off an on.
Old 07-12-2012, 01:12 PM   #10
tornado542
Member#: 280370
2012 Sport Premium
Ice Silver Metallic
You need to remove the O-rings and bottom and middle hooks, then the whole spring kinda swings around on the top hooks.
From then on out the easiest way to do it is to open both rear doors, lay on your back on the back seat with your head pretty much inside the seat cover that's unzipped and look straight up. You will see the hooks and the loops they are in, and all you need to do is push up and they will pop out. Might take some effort as they are wrapped in paper and it has a tendency to rip and get stuck in the loops. Just wiggle it around and push upwards.
Also, remove the headrest before you do anything as it might affect visibility inside.
If you are doing this without alot of lighting i recommend a flash light in your mouth
Old 09-19-2012, 02:07 PM   #11
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
Tornado, thanks for the excellent instructions. I noticed that the paper had worn away by the bottom set of hooks as well. The middle set already had some cloth or something wrapped around it, from the factory. Not sure why they didn't do that for all three sets.
This was the first time for me taking apart a car seat. What I had the most trouble figuring out was how to separate the front of the cover from the back. There's a sort of plastic clip thing running the entire width of the seat at the bottom holding it together. I'm not sure if that's typical in all cars or not.
soobie doo is offline   Reply With Quote
Old 09-19-2012, 04:28 PM   #12
tornado542
Member#: 280370
2012 Sport Premium
Ice Silver Metallic
8 months later...passenger seat sqeaks! Time to fix that one too!
Old 09-19-2012, 08:13 PM   #13
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
is that the sound i hear when i get out of my car? sound like springs are decompressing?
i thought it was the springs of my car... i was thinking crap did i gain weight or are the subaru impreza 2012 springs just weak.....now i need to know if its because of the seat springs.
Old 09-19-2012, 08:28 PM   #14
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
It's the seat springs. I only hear it when I get out of my car too. Therefore, I'm not planning to do anything about it. If I heard it while driving, it would certainly drive me nuts (and maybe it will start doing that someday). But for now, I'm leaving well enough alone.
Old 09-21-2012, 04:01 AM   #15
Blackmamba24kb
Member#: 330797
true, i hear it and just thought it was my springs but if its just the seat, i think ill leave it alone for the time being....im sure it will either get to me or ill ignore it but thanks for the fix tornado!
i will definitely keep this handy!
so is 79 the only person who got SOA to replace his seat? (is everyone experience front drive and passenger seats or only the rear seats?)....i think 79 was rear seats....i'm having driver seat issues
Old 09-21-2012, 10:42 PM   #16
teknickal
Member#: 332932
May I inquire which Mastro? They have locations in Tampa and Sanford. I got mine in Sanford and have joined the squeaky seat club, so it would be great to know if they can fix this for me. If Sanford, do you happen to remember which tech worked on it? Thanks!
teknickal is offline   Reply With Quote
Old 09-30-2012, 01:01 AM   #17
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Add me to the list. I noticed the squeak when getting out of the car. Then I drove with no music on & noticed it on any bump. If I just push back in the seat the upper area squeaks away. With music on I really didn't notice it, but now it's all I can hear. Will be calling the dealership Monday. I'm confident they'll take care of me. Always have. No discomfort; the seat is comfortable, just squeaky. I may unzip to look in there myself like the DIY fix, but I'll leave this up to my warranty & have the pros do it.
Old 10-10-2012, 04:00 PM   #18
SleepNMnky
Member#: 302491
Took it in today & a new seat back is on order.
Old 10-10-2012, 08:29 PM   #19
DKsiazek
Member#: 314375
2012 Impreza Sport
Marine Blue Pearl
Has anyone else had problems with the seat heater bunching up under the seat cover? I have had them adjust it 2x now, once replacing the actual cover as it started to fray. I am very close to taking the seat apart and just removing the seat heater.
DKsiazek is offline   Reply With Quote
Old 10-10-2012, 09:19 PM   #20
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Oh, I'm sure you'd miss the heater. Syracuse is cold enough to avoid the idea of removing the heater.
Old 10-11-2012, 01:09 PM   #21
SleepNMnky
Member#: 302491
I printed the post & diagram from tornado542 & taped it to the dash for the tech to see. Didn't want to bother or confuse the counter girl who checks me in. Talked to my friend who sold me the car & he said the tech was appreciative & it pointed him straight to the problem. Said without it they may not have had the time or support from SOA to fully investigate it under a warranty issue. They're using it & submitting it to SOA to see if they can get a TSB for this issue started. Nice work tornado542!
Old 10-17-2012, 07:57 PM   #22
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
I just had to post this because I thought it to be funny and kind of sad at the same time.
I think I unintentionally found a "fix" for my squeaky seat.
Earlier this evening, I shifted in my seat as I went to exit my car and I heard a popping sound and felt something in the seat back let go. The seat looks and feels the same, but the squeak is completely gone lol.
I wouldn't suggest someone purposely try to break their seat to get rid of the squeak, but whatever works...
Old 10-17-2012, 10:16 PM   #23
SleepNMnky
Member#: 302491
I'd almost bet that pop was one of the springs either breaking or coming unhooked. It's probably only one of several springs so you may not notice a change in the feel but if another spring comes undone you probably will be able to tell. Your squeak may be gone, but it's no "fix".
Old 10-18-2012, 05:15 AM   #24
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Or, more likely, the squeaky spring shifted into a new position, so now it doesn't squeak anymore. I doubt that a spring would "break". And it might shift back into the squeaky position again in the future. Who knows.
Old 10-18-2012, 08:24 AM   #25
79letour
Member#: 302570
2013 XV
DGM!
Only my drivers seat does it. But yeah- the Squeak has returned with a vengeance! I officially hate the seats.
Yeah- I can "feel" the warmers sorta bunched up behind my back. The non-heated seats in the loaner didn't squeak and were more comfortable.
I give these seats an F- and WISH swapping them was at all an option.
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
DIY - 2012 Impreza GPS/Radar Detector Hardwire ST Eye Interior & Exterior Modification 33 01-18-2013 02:59 PM
How are you cleaning the dash 2012 impreza? Kaupps33 Car Care & Detailing 23 08-25-2012 06:18 PM
Finally, a clutch creek/squeak fix! rides20 Transmission (AT/MT) & Driveline 2 09-13-2006 09:56 PM
('93-'01) Sunroof Squeak Fix? RacerX Impreza Forum 13 10-12-2001 12:26 AM
