Old 10-13-2012, 10:42 AM   #1
manny183
Member#: 95588
Hi guys.i got 99 impreza coupe. With sti swap. But I got 05 sti suspension up front with wheel hubs., will 99 struts fit 05 wheel hubs?
manny183 is offline   Reply With Quote
Old 10-17-2012, 08:40 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
No. You will need new struts.
speedyHAM is offline   Reply With Quote
Old 10-17-2012, 09:08 PM   #3
Buurma
Member#: 258394
2001 GC8
Pear black
i know a guy who has 2007 hubs on his 01 RS struts. they bolted right up.
Buurma is offline   Reply With Quote
Old 10-17-2012, 09:29 PM   #4
cpturbo
Member#: 49175
2004 STI
The 05-07 STi struts will NOT fit without shimming, but you probably dont want to do that
cpturbo is offline   Reply With Quote
Old 10-17-2012, 09:41 PM   #5
Buurma
Member#: 258394
2001 GC8
Pear black
shimed how and where?
Old 10-18-2012, 12:17 AM   #6
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
false...
You can shim to fit 5x114 front struts onto a 5x100 hub. NOT the other way around.
You need 5x114 (05-07) front struts which will bolt up just fine to your car. For the rear, you CAN use your stock struts but it will be very mismatched and not handle well. I would recommend getting matching front and rear struts from an sti (05-07) and notch the rear strut towers to fit the top mounts. There is a write up on how to do this if you search.
Zefy is offline   Reply With Quote
