Old 09-28-2012, 12:42 AM   #926
omz
Member#: 232060
Interesting, why did you decide to put a slight "flare" or up turn on the end of the spoiler? I like the filled in ones, but I've not seen a re-worked one like yours.
omz is offline   Reply With Quote
Old 09-28-2012, 01:26 AM   #927
dangerousatom
Visiting NASIOC Timeout
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
I miss my GC8 and it's JDM STi wing. . . Just a tad more down force and or a slight more agressive look.
I boxed in the sides like the GC wing too. . . Need to get picks up os the further progress.
dangerousatom is offline   Reply With Quote
Old 09-28-2012, 02:29 PM   #928
OhTwo OBS
Member#: 322327
02 Impreza Outback
Dangerousatom
Last two pages have been awesome!
OhTwo OBS is offline   Reply With Quote
Old 09-28-2012, 05:38 PM   #929
sigterm
Member#: 264104
Chapter/Region: HIIC
05 STi
CGM
Nice work dangerousatom, very nice.
sigterm is offline   Reply With Quote
Old 09-28-2012, 08:46 PM   #930
gregroot198521
Member#: 280844
2006 STi
???? He posted all of those a long time ago originally, that dude was talking **** that he hasn't posted anything of worth.
gregroot198521 is offline   Reply With Quote
Old 09-30-2012, 08:37 PM   #931
AWDshenanigans
Member#: 197856
2010 FJ Cruiser
Sandstorm
Attention guys from the old school unique mods thread:
A while back I posted pics of my R1 (bike) and how I wired a DIY garage door opener button into it, then, for entertainment purposes, posted a picture of a model in a bikini on the bike. Most of the people that saw it requested more pictures of her. That girl now does porn. Search ftvgirls for Cassidy. That is all.
Edit: also, she fists herself
AWDshenanigans is offline   Reply With Quote
Old 10-01-2012, 10:45 AM   #932
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
Originally Posted by krzywhtboi82 View Post
Thanks bro. I do like that grill. Might look into that. Where do I look for a sub specific. Or is the crown Vic big enough
you buy the crown vic one and cut out the subaru grill shape from within the ford grille. the crown vic grille is huge.
burkart is offline   Reply With Quote
Old 10-01-2012, 03:38 PM   #933
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Ahh ok that's what I was thinking. Looks clean though
krzywhtboi82 is offline   Reply With Quote
Old 10-01-2012, 09:34 PM   #934
garudatwo
Member#: 322385
2006 Civic LX
Stage a lot 140BHP
40% complete sports grill for widebody WRX's:
garudatwo is offline   Reply With Quote
Old 10-02-2012, 01:31 PM   #935
TweekedXXII
Member#: 313727
2005 WRX Wagon
Aspen
Moarrrrrr pictures pleaseeeee... Looks awesome so far!
I. Also in the hunt for something more aggressive for my wagon.. The rear hatch spoiler isn't quite doing it for me
TweekedXXII is offline   Reply With Quote
Old 10-02-2012, 02:11 PM   #936
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
Past: 05 RS, 92 Legacy
Being FMIC'd on my 05 sti, I had an open line where the I/C spray water would come out for the TMIC setup. I ran a line down the side of the fender into the front bumper. Snagged some windshield washer spray nozzles at the junkyard, as well as a "Y" splitter and put in the end of the line. Viola! Cheap, and functional FMIC spray setup.
In the pictures I pulled them out of the mounting spot so you can see them better. I was able to get them tucked behind the license plate mounting area, so they are hidden normally.
The spray is a little "weak" as the water has to travel from the resovoir in the trunk, to the front of the car, down into the bumper and out of two nozzles. It sprays a little better out of just one sprayer, more of a trickle with both, but when driving it goes onto the fmic.
VTSubieRS is offline   Reply With Quote
Old 10-02-2012, 04:09 PM   #937
farmboss
Member#: 252324
04 STi
JBP
I did the same thing, but with different nozzles. And here's how I did it...
http://www.iwsti.com/forums/how-inst...c-sprayer.html
And I got rid of the stock switch and put this in so I wouldn't have to hold it down to use it...http://www.iwsti.com/forums/3589710-post835.html
farmboss is offline   Reply With Quote
Old 10-02-2012, 04:27 PM   #938
dsdphotos
Member#: 333026
2011 subaru impreza
pearl
Very nice
dsdphotos is offline   Reply With Quote
Old 10-02-2012, 05:44 PM   #939
armyssoldierboy
Member#: 109424
06 AW STI
TS HTA 3076r 436hp/426tq
Farmboss, whered you get the switch with the led? I can only find one like that without the light. I need 2. I could do your setup and I was also going to use the other for a "green safety connector switch" instead of plugging them together to switch maps.
armyssoldierboy is offline   Reply With Quote
Old 10-02-2012, 07:02 PM   #940
farmboss
Member#: 252324
04 STi
JBP
I actually ordered it offline assuming autozone and advance didn't have them. But it turns out that they do have them, as well as O'reilly auto parts.
Old 10-09-2012, 07:19 PM   #941
burkart
Member#: 305000
2005 Legacy GT 5MT
i recently did this a second time. i'm using an OBXT grille as the surround, a Ford Crown Vic honeycomb insert. the honeycomb mounts to the shell via drilled holes and zip ties. the whole thing is painted flat black.
New DIY honeycomb grille, painted and nearly installed. debating what badge to use. thoughts about this old one i recovered VS the traditional blue stars...?
IMG_0445 by tommyburkart, on Flickr
Old 10-09-2012, 08:13 PM   #942
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
got bored and messed around a little today. I used to have a similar setup on my old 2.5RS so i thought I'd try again. Intake heat shield DIY.
What I used:
Small piece of sheet metal, cut to desired size needed for clearance and fit. Bent to fit. Painted to desired color, or left metal.
Found some random hardware- "c" bracket, and short screw with nut.
Test fit it on the intake, under the hose clamp, against the filter.
Test fit the hardware on the shield
painted the shield red, to match my other under hood goodies.
installed:
Cleaned up under the hood while the paint dried, the shield matches pretty well in my opinion.
Old 10-09-2012, 08:53 PM   #943
jozeppi
Member#: 247473
2007 wrx
wrb
What I used:
installed:
Nice job looks good
jozeppi is online now   Reply With Quote
Old 10-09-2012, 10:59 PM   #944
mechatricity
Member#: 290592
2006 WRX Wagon
2004 WRX Wagon
What I used:
Great looking engine bay!
mechatricity is offline   Reply With Quote
Old 10-10-2012, 12:03 AM   #945
omz
Member#: 232060
Interesting. I think I would rotate the whole contraption, on the same axis as the filter so that the shield were between the turbo and filter, but those are my thoughts. I'm not sure how hot return lines are on fmic, I could be overly wrong.
Looks good other wise!
Old 10-10-2012, 07:14 AM   #946
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
^ yes thatnks for that, it will be rotated back a little bit, it just barely fits under the fmic piping without rubbing. i may bend the c bracket a little bit so i can rotate back further, but for now i'm good with it. thanks for the feedback!
Old 10-18-2012, 01:53 AM   #947
armyssoldierboy
Member#: 109424
06 AW STI
Made my own radiator shroud out of aluminum with my dremel
My little man helping He looks slow lol
I'll get better pics tomorrow in the daylight.
Old 10-18-2012, 06:21 AM   #948
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
WRX 08+ triple gauge pod, vaccum formed:
cianuro is offline   Reply With Quote
Old 10-18-2012, 01:13 PM   #949
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Is there a slight bend in that? Not sure if this will work for you since it's a thick piece, but when I made mine out of sheet steel, I screwed it down onto an old speaker box so the bend line was at the edge, then used a block of wood and a hammer (wood to soften the blow) and gave it some good whacks to make a nice crease. Rubber mallet worked, too, but nicer with a block to make it smooth.
2point0 is offline   Reply With Quote
Old 10-18-2012, 03:43 PM   #950
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Originally Posted by cianuro View Post
That's the way that pod should be. Well done sir.
JourdanWithaU is online now   Reply With Quote
DIY Modifications cstratton04 Interior & Exterior Modification 135 02-21-2013 06:50 PM
It's out! My DIY swap thread... lancelucas North West Impreza Club Forum -- NWIC 71 11-28-2010 02:00 AM
1993 WRX Modification thread. clean 93 Pre-2002 Factory Turbo Powertrain 37 05-01-2010 03:30 PM
DIY Modifications txl146 Factory 2.0L Turbo Powertrain 6 03-27-2006 04:21 PM
The DIY audio thread. mattjk Off-Topic 29 06-21-2005 07:45 PM
Message Board Statistics All times are GMT -4. The time now is 07:05 PM.
