South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-11-2012, 01:26 AM   #26
Evil Imports
Member#: 14732
+ 13 B8
So tonight Ken and I drilled out 2 broken bolts on my brembos and Helicoils all the mounting holes so i will not have to worry about the bolts getting stuck again (since it seems to happen a lot) In the next day or 2 i will drop them off to my powder coater
Brembo Mounting holes
Front M12x1.5
Rear M10x1.5
Evil Imports is offline   Reply With Quote
Old 10-11-2012, 01:44 AM   #27
05bluesti
Member#: 251804
05 WRB STi
Originally Posted by kpluiten View Post
Built because not bought?
I thought Ken died, good to see you alive Ken
05bluesti is offline   Reply With Quote
Old 10-11-2012, 03:12 AM   #28
Erik
Member#: 168774
You've got 19 days to finish this, better get going.
Erik is offline   Reply With Quote
Old 10-16-2012, 12:10 PM   #29
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
19??!
Z0rr0 is offline   Reply With Quote
Old 10-16-2012, 12:24 PM   #30
Evil Imports
Member#: 14732
+ 13 B8
Originally Posted by Z0rr0 View Post
19??!
before we goto sema, but the car isn't coming apart untill after that
Old 10-16-2012, 12:26 PM   #31
05bluesti
Member#: 251804
05 WRB STi
So it won't get done by then?...
Old 10-16-2012, 12:42 PM   #32
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Shut the **** up, Donnie.
Old 10-16-2012, 02:20 PM   #33
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
02blkwagn19 is offline   Reply With Quote
Old 10-16-2012, 09:32 PM   #34
chubbsub
Member#: 176944
06 STI
How did the heil-coils work out for you? Those things saved my a** when one of the timing belt tensioner bolt threads stripped out on my girlfriend's engine.
chubbsub is offline   Reply With Quote
Old 10-16-2012, 10:18 PM   #35
Evil Imports
Member#: 14732
+ 13 B8
Ken had them on his brembos with no problems, since he did his car
Old 10-17-2012, 12:11 AM   #36
amroof
Member#: 211224
2005 Saabaru
Who knows
Is about f***ing time you get on this project and make it a true lezbo wagon!
Old 10-18-2012, 05:39 PM   #37
Rabidsquirel
Member#: 299658
I love that model gen of forester lowered. You converting from Auto to manual? So hard to find XT's in manual...
Rabidsquirel is offline   Reply With Quote
Old 10-18-2012, 05:44 PM   #38
Erik
Member#: 168774
It's already manual.
Old 10-18-2012, 05:55 PM   #39
Rabidsquirel
Member#: 299658
Forester Sport XT in manual... ooo very nice,.
Old 10-21-2012, 01:08 PM   #40
.kyle
Member#: 174695
1983 antarctic blue
super sportswagon
i saw this thing on CL a while ago. i wanted to buy it but couldn't convince myself to sell my car to go forward. i'm jealous.
.kyle is offline   Reply With Quote
Old 10-21-2012, 01:15 PM   #41
Evil Imports
Member#: 14732
+ 13 B8
I was going to sell it, but then decided to just build it up and have a fun Daily driver
Old 10-24-2012, 09:56 PM   #42
Evil Imports
Member#: 14732
+ 13 B8
So today i decided to do my Viper alarm/remote start,
Points if you are going to do this on your own car
1 - Get a proper wiring diagram.
2 - Get some tools - cutters, el. tape , etc.
3 - READ INSTRUCTIONS !!!!!!!
4 - Multimeter (if you really understand what you are looking at, you can use a test light)
Viper 5901 Wiring into my 2008 Forester XT (5 speed) (DO NOT USE THIS WIRING FOR ANOTHER CAR)
H3 harness (10 pin connector)
Pink – Ignition – to Black (key side) or Green (car side) wire on ignition switch
Red/White – 12+ constant – to Black/White stripe (key side) or white (car side) at ignition switch
Orange – Accessory 1 – to Black/Blue (key side) or Yellow (car side) at ignition switch
Red – 12+ constant – to Black/White stripe (key side) or white (car side) at ignition switch
Pink/White – Ignition 2 – to Pin 85 of Relay
Red/Black - 12v constant – to Black/White stripe (key side) or white (car side) at ignition switch
Starter wire you need to Cut
Violet – Starter 1 – to KEY Side of Black/Yellow (key side) or White/blue (car side)
Green - Starter 1 - to STARTER Side of Black/Yellow (key side) or White/blue (car side)
Relay to bypass clutch during remote start only
Wire Pin 85 of Relay to Pink/White – Ignition 2 (see above in H3 harness)
Wire Pin 86 of Relay to Ground
Wire Pin 30 of Relay to Clutch wire A (Clutch wires are above the clutch pedal) White plug
Wire Pin 87 of Relay to Clutch wire B (Clutch wires are above the clutch pedal) White plug
H1 harness (12 pin connector)
Red – To 12+ constant
Brown - To + on Siren
Black – To chassis ground
Green - Door Trigger input - (diode isolate if you have multiple door triggers) (Drivers door trigger blue/orange at BIU, all other doors yellow at BIU in gray 20 pin plug)
White – Parking light output – (Orange/black wire at parking light switch)
H2 harness (18 pin connector)
Violet/white - Tachometer input (Green wire in 24 pin plug above fuse box)
Dark Blue - (Blue wire from 556u bypass)
Grey - Hood pin ( Mount hood pin and connect)
Brown - Brake shutdown (White/black at brake switch)
Black/White - Neutral Safety Wire ( Green/black at ECU in 35 pin plug) (this is so your car will NOT start if left in gear)
Door lock harness (3 pin)
Blue - Unlock output (Yellow/Red at BIU in gray 20 pin plug)
Green - Lock output (Red/White at BIU in gray 20 pin plug)
Old 10-26-2012, 01:10 AM   #43
fige
Member#: 312924
this is ncie. I approve
fige is offline   Reply With Quote
Old 10-26-2012, 01:31 AM   #44
kpluiten
Member#: 120273
06 WRBWRXWGN
Great. Now install one in my car.
Old 10-26-2012, 01:44 AM   #45
Evil Imports
Member#: 14732
+ 13 B8
Car needs to run first (need to be able to test)
Old 10-26-2012, 02:12 AM   #46
chubbsub
Member#: 176944
06 STI
Wow dude, that's a very detailed write-up, nice job!
Old 10-26-2012, 09:13 AM   #47
yellowjacket757
Member#: 296879
2003 Impreza WRX
Sonic Yellow
very nice, looking forward to seeing what happens after SEMA.
yellowjacket757 is offline   Reply With Quote
Old 10-26-2012, 04:46 PM   #48
FastS2k
Member#: 59577
04 fxt notansti
s2000 reallynotthatfast
The rear of that car would look so friggin sweet debadged....
Did you get the cargo cover yet?
FastS2k is offline   Reply With Quote
Old 10-26-2012, 05:00 PM   #49
Evil Imports
Member#: 14732
+ 13 B8
Cargo cover is on its way, should be here before sema
Rear of car will be debadged (well the trim piece with the emblem anyway) i started working on it yesterday and will post pics once i get it done (if i like how it comes out)
Old 10-26-2012, 05:27 PM   #50
Evil Imports
Member#: 14732
+ 13 B8
Just noticed that my thread title was edited, ****ing hate this forum these days
thinking about just deleting everything and saying forget it
